K so I've decided to just replace my motherboard. It works without the side panel and as soon as I put it back on it restarts. So I'll consider this motherboard (http://www.newegg.com/Product/Product.aspx?Item=N82E16813130790) unless anyone has any other suggestions?
Maybe this one???
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
So thermal throttling. A cpu cooler like this would help some ? http://www.newegg.com/Product/Product.aspx?Item=N82E16835608025 but as you see from the price its not that cheap. While it would certainly help some, It will not solve the issues, completely . You will always be doomed to be throttled by the mb design, as it was never really designed for an overclocking fx cpu.
Much better! You got the right idea. Believe me when is say once you get the better mb, you will notice the difference. https://en.wikipedia.org/wiki/List_of_AMD_chipsets This will help with understanding amd chipsets. The 970, 990x, and 990fx is what you need depending on how you plan on using pc.
