https://www.one-tab.com/page/HjBaAIagSiGYA8zW66hs5Q
This is a companion discussion topic for the original entry at https://level1techs.com/video/level1-news-june-26-2018-kraznich-inside
If you can get 100 customers a day to sign up then 110 should be just as easy
I’m sorry. I know it’s a weird name, but here is a way to say it fairly well… Karzanich… I know, the slavic names are weird, but come on, Wendell, Tis not Kraznich…
You can easily say it Karzanich…
Does TLbleed affect any IBM power CPUs (or even ARM)?
“Its just being trolls isn’t it”… yes, yes it is, hence the story is titled AMD trolling Intel.
The BitTorrent story and the Token thing… what Ryan discribes is basically how most private trackers work. If you’re seeding stuff that isn’t really popular you get a lot of virtual whatever points on that tracker. Some trackers then have some premium features you can buy for those points.
I think that would really be the only way to make this feasable, but then again where does the actual value (i.e. monetary value) come from in this case? If media companies are to adopt this they gotta see cash.
For the TLBleed story… the OpenBSD people actually say the same thing (not running different security domains on 2 Threads on the same physical core), and are now disabling Hyper-Threading by default.
/edit
Should have watched the story to the end
