Level1 Minecraft
Maybe it won’t end badly this time? :smiley:
This is what we’re playing for the upcoming stream, community welcome.
Minecraft Galacticraft Instructions:
Install Minecraft
Install Forge
Install Client
Run Minecraft
Click the arrow next to Play to select the Forge profile.
Server IP: 216.244.80.130
Web map: http://216.244.80.130:8123/
Mods installed:
Galacticraft - Galacticraft - Galacticraft Wiki
Buildcraft - https://www.curseforge.com/minecraft/mc-mods/buildcraft
Just Enough Items (JEI) - https://minecraft.curseforge.com/projects/jei
DynmapForge - https://www.curseforge.com/minecraft/mc-mods/dynmapforge
[NARRATOR]: It ended badly.
Are all 3 of you playing or is kreestuh being handed the controls while you watch? XD
Also i would suggest looking into multimc as it makes managing mods and different minecraft installs easier
before anyone else asks it is version 1.12.2
may join later to build underground shindig
might have to dig out yee old minecraft and play for a bit
lol no
Manual modding always takes me to tha screen or similar.
I’m really put off by anything other than vanilla, I’ve had games that needed 10GB of ram before
I’ll see if I can make it work
bleeeehhh
Install the Forge Client and make sure the path is C:\Users\name\AppData\Roaming.minecraft
Galacticraft - https://micdoodle8.com/mods/galacticraft/downloads
you need to download the following for Galacticraft to work:
GalacticraftCore-1.12.2-4.0.1.181.jar
Galacticraft-Planets-1.12.2-4.0.1.181.jar
MicdoodleCore-1.12.2-4.0.1.181.jar
You need to install the 1.12.2 version of all these mods to your C:\Users\NAME\AppData\Roaming.minecraft\mods directory.
Run Minecraft
I read wendell’s post
I got in
Searched most popular mods on Curseforge (about 30 pages worth, found a few good recommendations for the server if the server op wishes, and no, none of these will break your server install, just check and double check all your configs)
https://minecraft.curseforge.com/mc-mods?filter-game-version=1738749986%3A628&filter-sort=4
ComputerCraft - mod that’s all about computer programming. Allows you to build in-game Computers and Turtle Robots, and write programs for them using the Lua programming language. Various turtles including a mining turtle which will tunnel mine or quarry mine. Some built in programs, be sure to read the wiki. It is also OPEN SOURCE http://www.computercraft.info/ ,
https://minecraft.curseforge.com/projects/computercraft
NetherPortalFix, this mod fixes the multiplayer server issue with Nether Portals https://minecraft.curseforge.com/projects/netherportalfix
Backpacks, allows more player inventory storage space and naming (Tool Bag, Blocks Bag, Food Bag, etc.) https://minecraft.curseforge.com/projects/forge-backpacks
Journey Map, needed client and server side, allows mini map and waypoint markers, only opped players can teleport https://minecraft.curseforge.com/projects/journeymap
Hammer Time! Allows vanilla versions of Tinkers Construct hammers (that mine 3x3 blocks at once for tunnel mining) , spades, lumber axes, and sickles, great for small packs that do not include Tinkers
https://minecraft.curseforge.com/projects/hammer-time
Iron chests, allows bigger chests in 1 block https://minecraft.curseforge.com/projects/iron-chests
Chest Transporter , allows you pick up a chest with its items and place it somewhere else (like the dolly from Open Blocks mod) https://minecraft.curseforge.com/projects/chest-transporter
Inventory Sorter, allows 1 button click sorting of opened chests by ID number or mod item for stacking to save space, amongst other useful things etc. (replacement for Inventory Tweaks mod) https://minecraft.curseforge.com/projects/inventory-sorter
OpenBlocks Elevator, block that when stood on top of, and spacebar activated transports player upwards up to 8 blocks to another Elevator block, when L shift (sneak) activated transports player downward up to 8 blocks to another Elevator block
https://minecraft.curseforge.com/projects/openblocks-elevator
Open Glider, adds a hang glider
https://minecraft.curseforge.com/projects/open-glider
Morpheus, good for servers in that it allows (in config set to 1%) 1 person sleeping in bed to change from night to day
https://minecraft.curseforge.com/projects/morpheus
Neat , adds mob health bar similar to RPG games
https://minecraft.curseforge.com/projects/neat
LagGoggles , profiler where you can see timings in the world, visually. It comes with a custom GUI using a configurable keybind
https://minecraft.curseforge.com/projects/laggoggles
VanillaFix , useful for server ops, not necessary but has some nice features and worth a look https://minecraft.curseforge.com/projects/vanillafix
Fullscreen Windowed (Borderless) for Minecraft, allows numpad selection of preset resolutions, read info.
https://minecraft.curseforge.com/projects/fullscreen-windowed-borderless-for-minecraft
Optifine is great for lower end computers struggling with bad performance / fps , allows much more control over video and rendering options, resource pack supported, install the proper version for the Forge version you are using
https://www.optifine.net/home
Official mod supported Faithful 32x resource pack (Forge loads only the modded textures for the mods you are loading no matter what modpack, so it is very lean with small packs, increase your launcher’s Java allocation to 4-6 GB maximum for best results) it is universal and community supported
http://www.f32.me/
I highly recommend using Multi MC for client loading (it is very very lean compared to Twitch app and other launchers and is what we modpack devs primarily use to make modpacks) , it has many extra options such as extended console logging and use of profilers etc. , very simple to use for beginners and powerful enough for advanced users, also allows drag and drop importing and exporting of modpack zip files (useful for easy pack distribution / download if you are running a community server). https://multimc.org/
Moved thread to the official servers category.
seems to be crashing on my laptop but desktop works fine huh
Most of these change the gameplay significantly, not sure if any of the team would want that.
I approve of
Edit: Seems like they accepted some of our mod requests:
Excellent I can shut mine down now LOL… I don’t mind keeping the world and firing up for personal things but nobody plays and it uses a virtual machine spot haha for not much reason now… Gonna come on and play. I was waiting for an official server forever
@wendell be careful with the web map… the high resolution… you want to see something that takes up some serious space haha put it at max LOL… I found that out the hard way… 784 GB of space used by dynmap haha OOPS…
Is it just me or is the server offline?
Server is up now. Went offline to install some mods and bump up the ram some more.
Updated mod links (all required):
https://minecraft.curseforge.com/projects/buildcraft/files/2560476
https://minecraft.curseforge.com/projects/jei/files/2591543
New as of 7/29/18 (required to play):
https://minecraft.curseforge.com/projects/journeymap/files/2498312
https://minecraft.curseforge.com/projects/inventory-sorter/files/2546769
https://minecraft.curseforge.com/projects/gravestone-mod/files/2524880
TreeCapitator Mod (1.12.2, 1.11.2) - Speed Up The Removal of Trees - 9Minecraft.Net (1.12.2 link near bottom, above comments)
also
also also, your mod folder should look like this (unless you have custom client side mods)
How did ya fix this?
Install the linked mod packs.
