Now that i have you here, Ty for everything.
Oh look what i just found from 2 months ago:
Same guy, Building it for Manjaro.
edit: turned out this was a 3 part series.
at least I am not a crazy person that thinks this should be a thing
Then i’m screwed becose i’ve bin using this setup for 6 months, Not to mention this German guy
I hope people give him some view and likes, becose my gearman is abit rusty and it would motivate him to make more english videos.
Maybe not for workstations, but being able to make a zfs clone read/write Cheaply after a botched upgrade has saved my bacon more than a half-dozen times. (Then cleanup after hours for various reasons: https://jrs-s.net/2017/03/15/zfs-clones-probably-not-what-you-really-want/ )
I don’t know that btrfs is the best choice for my level of paranoia, and number of disks, though. I thought it was pretty lol that every raid-in-a-box nas I’ve used puts btrfs on top of md arrays. lol.
I hate how BTRFS slows down significantly once you hit about 200 subvolumes. (and that’s trivial if you’re using docker at all)
I don’t have the cash for a separate workstation and dev machine, so… yolo
That’s why ZFS snapshotting would be nice for me. Not to mention, I run ZFS on my NAS, it’d be nice to be able to zfs send
to back up all my machines.
i was planning on building and trying to break a btrfs raid this spring, but my plans are delayed becose of an unsold house.
As a private consumer it would be quite benefical for me to be able to grow a raid over years. As filling up a 11 drive case with 8tb+ drives is not for the weak hearted.
The space usage would be limited by the 3 largest drives in a raid6. So it would allow me to buy drives in increments of 3.
And btrfs has everything i want from zfs except for the ability to set different properties on each dataset.
I got the idea when for a short moment raid5/6 was not marked unstable on btrfs. Last i checked it was unstable again.
And from looking at the kernel Opensuse is still pushing btrfs forward.
The only downside is that i would need to install btrfs on my backupserver aswell if i want to send datasets.
I think I adopted btrfs too early when I made a rockstor NAS and lost everything. I like the idea of extensability vs. how I’m building my freeNAS now (lots of drives, trying to for-see max growth so I do not have to mess around with rebuilds). Here is to hoping btrfs matures.
Throwing my hat in the ring to do code review if you guys ever get anywhere
It is a thing, someone just needs to port libbe to Linux
libbe:
bectl:
hmmmm this might be the right solution.
Good (late) news folks.
I really didn’t want a contest over whether this was worthwhile or not, I just wanted to mention about the possible issues.
Okay, so I’ve been doing some reading and it appears most of the heavy lifting for ZFS for Arch has been handled and it’s well documented here:
From what I gather here, it should be pretty simple to get ZFS partitions to work in Arch.
I’m not so sure about getting a root partition running it, have you been able to get this to launch successfully? would it be better to have ZFS partitions be separate and have the root / boot be standard?
Don’t have a snapshot tool on the dev laptop yet, so I had to SSH in:
So, yes. 100% working ZFS root on Arch.
Update:
I’ve successfully switched datasets via grub.
this is happening
This is quite impressive. How fast is it to switch? Have you seen any I/O errors?
Manual at the moment. Just getting the required actions down.
Zero. Running on a 970 Pro. When I had to send | recv
a dataset for testing, I was getting 1GB/s.
wowzers, that’s fast.
I’d be interested in some hdparm numbers.
Are you going to build this into a separate branch?
