Hello! Never been active here but might aswell start now (better late than never, right?) I acquired an used Lenovo thinkstation S30 with e5-1650V2, 32gb ram for the price of 149 € here in Finland, a steal in my mind as I have been looking for an used server or a workstation for my much wanted not needed homeserver build, I do have an synology DS420+ with 4x 4Tb WD red’s in syno’s SHR but ofc it has it’s limitations for plex etc.
So I was thinking that I finally would build an homeserver around truenas with this system and I have nearly zero expirence with truenas or with freebsd, just have installed it played very little with it, with some random hardware, never anything serious like now.
Plan:
homeserver inc plex, mail notifications aka retain the capability of the synology but enhance it.
Hardware:
As told the base is a s30 workstation, has just 3x 3.5" drive bays (would have liked 4 atleast) but might get an 2x5.25" to 3x3.5" in the future, right now I would like to put my bluray player into the station and I could rip blurays if it is possible.
Thinking of getting 3x10tb N300 nas drive’s in zraid1 or couple of 14Tb MG08ACA14TE in mirror as atleast I need 10.5Tb~ to move all files from the synology to this machine.
That inmind is 32Gb ram enough? Prob going to use compression and deduplication, atleast in theory it sounds very nice, the system max is 256Gb with RDIMM’s so atleast I have headroom, I don’t have the system yet so no idea what ram config it has atm, just that it has 32gb.
In the cpu front I could get a 2690v2/97v2 but don’t know if it is needed…
Also if anybody has any expirence with these systems can you replace the fans with no hassle, I know that some HP’s will freak out.
Oh also my budget is somewhat limited to what to do.
As I am a noob I have prob missed quite a few things or just don’t know what I should do, that’s why I am here, any advice appreciated =)
8 GB would be fine for a NAS. That said, you should have the amount of RAM equal to the largest single file in your collection of media for optimal performance + half a gig for OS overhead. So if you have media files that are less than 32 GiB in size you’ll be fine.
Compress = Good
De-Dup = Bad
Don’t do deup on media. You will tank your performance. Dedeup is not worth it for 99.999% of people.
In the BIOS there are settings that check for fans, and so long as you reset the chassis intrusion reset switch back to OFF (if applicable) then your fans won’t blast at 100% constantly once you open the unit. As far as buying replacements, be sure to buy a couple from ebay. They usually have proprietary connectors so its good to have spares. They usually just slot right in.
I agree. I guess I have to check Suomi websites for my next discount deal.
The GUI covers pretty much everything you need to do. I’m running TrueNAS for 4 months now and only had to use the FreeBSD command line two times (for reading specific stats from my HDDs via smartctl and for editing some config file because some iSCSI-logs freaked out). No problem if you have a basic Unix/Linux experience.
TrueNAS has PLEX-plugin. Worked fine for me when I was testing stuff, but I didn’t do any GPU encoding or such things. YMMV.
I found the N300 to be too expensive per TB and went with 4x 16TB Toshiba MG08 instead and bought a spare/backup drive from the saved budget. Other than being rather noisy, I can totally recommend those drives. I can replicate the advertised 245MB/s read and write in daily operation, they’re really fast (for a HDD). No drive problems of any kind after 4 months of 24/7.
Compression doesn’t use memory. Compression needs cpu cycles. Always use compression. And about dedup…usually it’s not worth it, but if you really want it, dig into the matter to see if your use case fits into that dedup-niche.
I’d keep that 32GB and see how hit ARC hitrate develops (TrueNAS has fancy graphs for that). But really depends on how much other data besides media files you want to store on that server.
What I recommend is getting an SSD for the readcache (L2ARC). Really any old SATA SSDs will do, which will naturally extent your main memory. Sizing is difficult, but I wouldn’t go bigger than a TB. But definitely 2xSSD if you go for 10Gbit networking.
Get the TrueNAS ISO and check out the GUI in a VM. Make like 4 or 8 virtual disks and play around, create your first ZFS pool and see how TrueNAS feels. Performance will be atrocious, but you can test drive your new “home” like that.
Congrats on the purchase. I use two of these exact models for my homelab. A couple of thoughts:
Generally been rock solid, have both running 24x7 and they are stable (a bit power hungry).
If you swap the RAM you may need to clear Cmos This is a physical jumper on the mobo and threw me the first time and I thought I’d bricked it. Guides on lenovo forums for Bios recovery are useful.
I have 2690v1 and 2630L as the CPUs and they work well. Check RAM compatibility though.
64GB RAM is easy, 256GB is harder as those modules are less available. 64GB is plenty for what you need.
Answered by @Exard3k but to flag - don’t use noise reducers if using Noctua fans, as it will get a fan failure error. I use Noctua and BeQuiet fans.
Oh thanks for the heads up! should be receiving it tomorrow, hoping for 4x8 on the ram config so can go and buy a matching kit from ebay as some of my files are over 32Gb.
Is the performance hit big if the file is larger than 32Gb? Just in case if the system has 8x4 config, as those 4x8 kit’s are pretty recenably priced.
Can I have a diffrent share with dedup or is it in the volume level?
As for cpu side going to stick with the 1650v2 and see how it manages, unless I find a deal on a more powerful cpu even tho it is kinda marginal.
Oh and read about Realtek / Aquantia/Marvell NIC support is quite bad and I belive it is still? Was just thinking of 2.5Gbe nic’s as it would be nice to have, the price hike to higher just dosen’t make sense for me atleast now.
That’s it for now, thanks for the replies and when I recive the unit more questions are bound to happen.
It means that the file won’t fit in ARC so it will have to do extra reads. It will probably be fine unless you like to use plex to skip around while watching large media files. If its just use using it shouldn’t be a problem.
IIRC de-dup is at the pool level and once set there is not reversing it.
Better CPU’s make certain computational things faster, like if you do RAIDZX. So long as you use a CPU from 2013 or greater it will work just fine for most configurations. If you’re on a limited budget then you want to prioritize RAM and disk space. The more of each you have the better the perf (usually).
TBH IDK, I just stick with Intel or Supermicro because they work out of the box. Life is simpler.
So this is the interesting bit. Let’s take two configs with the same raw storage capacity.
Config A: 8 x 4 TiB
Config B: 4 x 8 TiB
They’re both the same raw capacity, however the one with the smaller size drives will outperform the larger capacity ones in both resilvering and IOPS. This is because the secret to more performance is more VDEV’s in your pool.
Conservatively estimating 125 MBps per VDEV in a mirror config for a HDD is not unreasonable for what is usually expected (at least once drives start to fill up). Config A would have ~500MBps while config B would have ~250 MBps.
When you create a VDEV you are limited by the slowest drive in the VDEV. This is important to remember when deciding your topology. Hypothetically, if you were to take config A and make it RAIDZ1 then you’d have a higher capacity when compared to a mirror, but you’d only have the performance of 1 drive!
