Lenovo M720q as homelab sever. BIG PROBLEM
I came across a few Lenovo M720q that were discarded as scrap and thought to myself, That would be an awesome little training server setup. And happy as a schoolboy, I started to install Server 2025.
Worked as a charm, no hiccups, fast-ish, until I needed a network connection. And all hell broke loose. I’ve tried everything I can think of. To a new Server version… nope skipped backwards all the way to 2016 still no go. I’ve tried custom drivers, customising them myself, ChatGPT… nothing works.
If anyone has any suggestions for Microsoft Server… anything, I’d be grateful for the assistance.
The foremost step is determining whether it’s a hardware or software issue. Obtain a Sysrescue image, install the ISO file on a flash drive or optical disk and boot the machine(s) from that. During boot you’ll get a menu to select how to boot before booting into the default mode. The menu includes a desktop environment and if you’ve never used Linux before, that’s a good start. Once fully booted and you have a GUI on the screen (you did attach a screen, right? :wink: ) it automagically launches a terminal. Don’t close it, it’ll be useful. Type in this command (or copy/paste)
ping -c 3 4.4.4.4
This sends 3 ping requests to the server at IP address 4.4.4.4 which is a Google server. It will respond and tell you how much latency each request has. If the network works as it should, you will get a response. If not, time to pull out another useful tool: traceroute.
traceroute 4.4.4.4
This will tell you latency for each hop between your Lenovo machine and the server.
Post the output of the above commands (use the code tags, like I did) if it fails to connect to said server. You can replace 4.4.4.4 with 8.8.8.8 (which is another Google server) as a backup target.
Should the above show the network is actually connecting to the web, the issue is most likely a driver problem in Win-OS. To be sure, you can launch a webbrowser from the desktop and hit google.com and go from there.
HTH!
The problem is definitely a driver issue. Out of frustration, I installed Windows 11 on it, and it works fine, just not on server. I219 V driver needed, but suited for server. There doesn’t seem to be one available that works; plenty don’t, but I’m stuck.
It wouldn’t surprise me if Lenovo made it special in one way or another.
@Rune_Jonassen
Maybe try here:
https://www.catalog.update.microsoft.com/Search.aspx?q=I219&scol=Products&sdir=asc
@Rune_Jonassen if it’s a driver error, you can manually force the Windows 11 driver to Windows Server. I got mine working fine just like that.
I stumbled over Thomas Maurer’s site (Install Intel NUC Windows Server 2019 Network Adapter Driver) and found the correct way to do it, thanks to him. It wasn’t hard once pointed in the right direction.
Thank you for your input tho. Much appreciated.
