In an ideal world, I would like to just pull my drives from my current build and plonk them in with the new kit then boot up. Alas I know this is not possible. Are there any tried and tested methods of converting a boot/system drive from MBR to GPT without data loss?
I don’t know of a way to do it without a reinstall. GPT and MBR are different kinds of partition tables, by converting a disk to GPT you lose all of the partitions, and thus lose your windows install.
I have the same mobo, but with an i7-950. Incidentally, I only recently updated the BIOS to FH to get better AHCI support, but I digress. Unfortunately, you can’t change the partition type without deleting the old partition first.
You wont be able to convert them and keep the data on them, but why bother converting. You can still use your MBR drives the way they are with the CSM option in bios. Hell, you might not even have to reinstall. Unless you are dead set on UEFI, I would just do that and save myself the hassle. If you are dead set on UEFI then as @Dynamic_Gravity said…back up, wipe, reinstall, restore.
@Automobili3XF.
My mate is moving to YankLand next week, so I bought his pc for ÂŁ250 including a Fury 4gb.
I couldn’t resist that deal and a very swanky 40" 60hz 4k LCD telly for £100
I will be demoting my 1st Gen i7 to HTPC use.
