I’m looking to buy an AMD GPU. I was leaning towards the Sapphire RX 580 limited edition, however, it has LEDs all over it (which are in my opinion a completely unnecessary distraction and source of heat). Looking at different models, it’s hard to tell whether or not those glow as well.
Is there any way to disable the LEDs without needing to use Windows for the included software? (Wine, maybe?) And if not, will changing the setting through Windows make it stay off permanently, or will it simply reset after turning off the computer?
If this can’t be done, I may need to settle for NVidia. (The reason I want an AMD card is mainly for 10-bit color display support.)
for just unplugging a cable it shouldn’t, you can even get it without removing the shroud just as long as you put it back in before sending it for warranty.
