Yeah, I use Windows, so maybe I am not an authority, but…
I set my RGB once a couple years ago, then removed all RGB software and the board works just fine. Asrock B350 Pro4. So unless you want to be able to constantly change the RGB you can do it once in Windows and then do whatever you want in Linux. The board will remember your choice. Maybe the memory won’t…
The memory strobes with the motherboard and it’s supported memory, I checked. I may do this as last ditch effort. I’m waiting on 3x3tb HDD’s, so I may use one to install a win10 unregistered just for the setup. My whole room is blue light from the Smart lights to the monitor ambiance. If I can set the RGB to strobe rainbow, that may be my only RGB setting, and the rest would be soft blue.
I’m considering writing my own. I have some stuff in python but I don’t know exactly where to go. I can get systemps and fanspeeds, but I don’t know what to look for or how to set RGB
