Lag spikes on 2 tb Seagate Firecuda SSHD
hey guys about a week ago I started getting huge lag spikes while using my 2 tb sshd. According to speccy, it’s been up only 550 days total, so I don’t think it’s worn out, I’ve run scans of the drive show everything good, but it continues to act weird, any help would be appreciated, as it’s making gaming impossible. I have run anti virus and it reports no malware.
Maybe you could start with switching out the sata and powercable.
Still if you have important data on the said drive,
then i would highly recommend to start make a backup from it.
I already have backups on multiple drives of critical information, Just medical files and my writing, Stuff that’s important to me. I have noticed there is some damage to the plastic around the SATA connection, but all that seems to do is not allow the sata cable to lock into place.
It is just a though, but what kind of filesystem are you using? Have you checked if the disk is heavily fragmented or almost full? The SSD part of the drive will cache data for you, but during the initial request of data the hard drive will still have to read it from disk. If it has a hard time doing that you could encounter choppyness.
Is it SMR?
What were you doing that experienced these lag spikes? Could it be you got through the SSD cache and the spike is switching to HDD write?
it’s pretty full but only 1% fragmented. I’m just using the drive as my main drive, Zibob, so all tasks, but it is especially noticeable while gaming. I’ll be playing at 60 fps, then all of a sudden the game will freeze and it’ll show 1 fps for maybe 1-15 seconds. It’s really annoying, cause it didn’t used to do that ever.
