L1Techs KVM and Razer Mouse Dock Pro Issue
KVM Model:
1.4 Display Port KVM Switch - Dual Monitor - Four Computer
5-gigabit
Problem:
Razer Basilisk V3 Pro with Razer Mouse Dock Pro
When the mouse dock is plugged into the USB 3.0 ports it usually works okay, however at random times the mouse will just stop responding. It will only start working if I unplug the mouse dock from the KVM and also turn off the mouse. Then plug in the mouse dock, wait for it to light up, and then turn the mouse back on.
If I put the mouse dock into the HID port, it actually works flawlessly, however I lose the ability to control any features of the mouse, it runs at a lower Hz level, and it reports 0% battery status. I suspect this is due to Razer running non standard HID.
With the mouse dock in the USB 3.0 port on the KVM this behaviour might happen once a day, twice a day, or 5-30s after unplugging turning off, re-plugging, and turning on. To the point where I give up and just plug it into the HID port and be done with it.
This happens on my two personal Windows 11 based computers with the Razer software loaded. It also happens on my Windows 11 work laptop where the Razer software is not loaded. And it happens on my M1 Mac Mini where there is no Razer software compatible.
If I direct plug the mouse into any of the computers it works without issue.
Other Notes:
I have managed to get a work around. I purchased a cheap 4 port Orico USB Hub off Amazon. I took the advice to get a low port count one so I avoid USB depth issues with my Mac Mini.
I now have this plugged into the USB 3.0 port on the KVM and my Razer Mouse Dock Pro/Basilisk V3 Pro connected to this. For the last week now it has been stable and the issue hasn’t reoccurred.
Could this be some sort of power level / incompatibility issue between the Razer Mouse Dock and the Leve1Techs KVM? Or just dodgy Razer behaviour in general?
I’m not expecting any resolution. I just thought I’d post this so if anyone else has the same issue, they have a potential fix.
if the mouse plus dock needs over 1a then powered hubs are the way to go for sure.
Going by USB Device Tree Viewer it only wants 500 mA. Interestingly it report that it is self powered, but I don’t think this is correct. With no power cord / AC adapter, it must be bus powered, right?
I’ve dumped the USB Device Tree Viewer output below.
The Orico hub is doing well. Not a drop out on any system since.
    =========================== USB Port3 ===========================
Connection Status        : 0x01 (Device is connected)
Port Chain               : 2-1-4-3
Properties               : 0x01
 IsUserConnectable       : yes
 PortIsDebugCapable      : no
 PortHasMultiCompanions  : no
 PortConnectorIsTypeC    : no
ConnectionIndex          : 0x03 (Port 3)
CompanionIndex           : 0
 CompanionHubSymLnk      : USB#VID_2109&PID_0822#MSFT30000000001#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
 CompanionPortNumber     : 0x03 (Port 3)
 -> CompanionPortChain   : 2-5-4-3
      ========================== Summary =========================
Vendor ID                : 0x1532 (Razer (Asia-Pacific) Pte Ltd.)
Product ID               : 0x00A4
USB version              : 2.00
Port maximum Speed       : High-Speed (Companion Port 2-5-4-3 supports SuperSpeed)
Device maximum Speed     : High-Speed
Device Connection Speed  : High-Speed
Self Powered             : yes
Demanded Current         : 500 mA
Used Endpoints           : 4
      ======================== USB Device ========================
        +++++++++++++++++ Device Information ++++++++++++++++++
Device Description       : USB Composite Device
Device Path              : \\?\USB#VID_1532&PID_00A4#7&2e5f6fa0&1&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
Kernel Name              : \Device\USBPDO-23
Device ID                : USB\VID_1532&PID_00A4\7&2E5F6FA0&1&3
Hardware IDs             : USB\VID_1532&PID_00A4&REV_0101 USB\VID_1532&PID_00A4
Driver KeyName           : {36fc9e60-c465-11cf-8056-444553540000}\0067 (GUID_DEVCLASS_USB)
Driver                   : \SystemRoot\System32\drivers\usbccgp.sys (Version: 10.0.22621.3672  Date: 2024-05-31)
Driver Inf               : C:\WINDOWS\inf\usb.inf
Legacy BusType           : PNPBus
Class                    : USB
Class GUID               : {36fc9e60-c465-11cf-8056-444553540000} (GUID_DEVCLASS_USB)
Service                  : usbccgp
Enumerator               : USB
Location Info            : Port_#0003.Hub_#0015
Location IDs             : PCIROOT(0)#PCI(0801)#PCI(0003)#USBROOT(0)#USB(1)#USB(4)#USB(3), ACPI(_SB_)#ACPI(PCI0)#ACPI(GP13)#ACPI(XHC0)#ACPI(RHUB)#ACPI(PRT1)#USB(4)#USB(3)
Container ID             : {4bd75563-458a-11ef-9ac9-dc41a9e5217f}
Manufacturer Info        : (Standard USB Host Controller)
Capabilities             : 0x84 (Removable, SurpriseRemovalOK)
Status                   : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code             : 0
Address                  : 3
HcDisableSelectiveSuspend: 0
EnableSelectiveSuspend   : 0
SelectiveSuspendEnabled  : 0
EnhancedPowerMgmtEnabled : 0
IdleInWorkingState       : 0
WakeFromSleepState       : 0
Power State              : D0 (supported: D0, D1, D2, D3, wake from D0, wake from D1, wake from D2)
 Child Device 1          : USB Input Device
  Device ID              : USB\VID_1532&PID_00A4&MI_00\9&E1624B6&0&0000
  Class                  : HIDClass
  Driver KeyName         : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0260 (GUID_DEVCLASS_HIDCLASS)
  Service                : HidUsb
  LocationPaths          : PCIROOT(0)#PCI(0801)#PCI(0003)#USBROOT(0)#USB(1)#USB(4)#USB(3)#USBMI(0)  PCIROOT(0)#PCI(0801)#PCI(0003)#USBROOT(0)#USB(1)#USB(4)#USB(3)#USB(3)  ACPI(_SB_)#ACPI(PCI0)#ACPI(GP13)#ACPI(XHC0)#ACPI(RHUB)#ACPI(PRT1)#USB(4)#USB(3)#USBMI(0)  ACPI(_SB_)#ACPI(PCI0)#ACPI(GP13)#ACPI(XHC0)#ACPI(RHUB)#ACPI(PRT1)#USB(4)#USB(3)#USB(3)
   Child Device 1        : Razer Mouse Dock Pro
    Device Path 1        : \\?\HID#VID_1532&PID_00A4&MI_00#a&17e979fb&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd} (GUID_DEVINTERFACE_MOUSE)
    Device Path 2        : \\?\HID#VID_1532&PID_00A4&MI_00#a&17e979fb&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030} (GUID_DEVINTERFACE_HID)
    Kernel Name          : \Device\000000ff
    Device ID            : HID\VID_1532&PID_00A4&MI_00\A&17E979FB&0&0000
    Class                : Mouse
    Driver KeyName       : {4d36e96f-e325-11ce-bfc1-08002be10318}\0019 (GUID_DEVCLASS_MOUSE)
    Service              : mouhid
 Child Device 2          : Razer Mouse Dock Pro
  Device ID              : USB\VID_1532&PID_00A4&MI_01\9&E1624B6&0&0001
  Class                  : HIDClass
  Driver KeyName         : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0261 (GUID_DEVCLASS_HIDCLASS)
  Service                : HidUsb
  LocationPaths          : PCIROOT(0)#PCI(0801)#PCI(0003)#USBROOT(0)#USB(1)#USB(4)#USB(3)#USBMI(1)  ACPI(_SB_)#ACPI(PCI0)#ACPI(GP13)#ACPI(XHC0)#ACPI(RHUB)#ACPI(PRT1)#USB(4)#USB(3)#USBMI(1)
   Child Device 1        : HID Keyboard Device
    Device Path 1        : \\?\HID#VID_1532&PID_00A4&MI_01&Col01#a&2b199639&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd} (GUID_DEVINTERFACE_KEYBOARD)
    Device Path 2        : \\?\HID#VID_1532&PID_00A4&MI_01&Col01#a&2b199639&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd (GUID_DEVINTERFACE_HID)
    Device Path 3        : \\?\HID#VID_1532&PID_00A4&MI_01&Col01#a&2b199639&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd (GUID_DEVINTERFACE_HID)
    Kernel Name          : \Device\00000101
    Device ID            : HID\VID_1532&PID_00A4&MI_01&COL01\A&2B199639&0&0000
    Class                : Keyboard
    Driver KeyName       : {4d36e96b-e325-11ce-bfc1-08002be10318}\0021 (GUID_DEVCLASS_KEYBOARD)
    Service              : kbdhid
   Child Device 2        : HID-compliant mouse
    Device Path 1        : \\?\HID#VID_1532&PID_00A4&MI_01&Col02#a&2b199639&0&0001#{378de44c-56ef-11d1-bc8c-00a0c91405dd} (GUID_DEVINTERFACE_MOUSE)
    Device Path 2        : \\?\HID#VID_1532&PID_00A4&MI_01&Col02#a&2b199639&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030} (GUID_DEVINTERFACE_HID)
    Kernel Name          : \Device\00000102
    Device ID            : HID\VID_1532&PID_00A4&MI_01&COL02\A&2B199639&0&0001
    Class                : Mouse
    Driver KeyName       : {4d36e96f-e325-11ce-bfc1-08002be10318}\0020 (GUID_DEVCLASS_MOUSE)
    Service              : mouhid
   Child Device 3        : HID-compliant consumer control device
    Device Path          : \\?\HID#VID_1532&PID_00A4&MI_01&Col03#a&2b199639&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030} (GUID_DEVINTERFACE_HID)
    Kernel Name          : \Device\00000103
    Device ID            : HID\VID_1532&PID_00A4&MI_01&COL03\A&2B199639&0&0002
    Class                : HIDClass
    Driver KeyName       : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0270 (GUID_DEVCLASS_HIDCLASS)
   Child Device 4        : HID-compliant system controller
    Device Path 1        : \\?\HID#VID_1532&PID_00A4&MI_01&Col04#a&2b199639&0&0003#{4afa3d53-74a7-11d0-be5e-00a0c9062857} (GUID_DEVICE_SYS_BUTTON)
    Device Path 2        : \\?\HID#VID_1532&PID_00A4&MI_01&Col04#a&2b199639&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030} (GUID_DEVINTERFACE_HID)
    Kernel Name          : \Device\00000104
    Device ID            : HID\VID_1532&PID_00A4&MI_01&COL04\A&2B199639&0&0003
    Class                : HIDClass
    Driver KeyName       : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0271 (GUID_DEVCLASS_HIDCLASS)
   Child Device 5        : HID-compliant device
    Device Path          : \\?\HID#VID_1532&PID_00A4&MI_01&Col05#a&2b199639&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030} (GUID_DEVINTERFACE_HID)
    Kernel Name          : \Device\00000105
    Device ID            : HID\VID_1532&PID_00A4&MI_01&COL05\A&2B199639&0&0004
    Class                : HIDClass
    Driver KeyName       : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0272 (GUID_DEVCLASS_HIDCLASS)
   Child Device 6        : HID-compliant device
    Device Path          : \\?\HID#VID_1532&PID_00A4&MI_01&Col06#a&2b199639&0&0005#{4d1e55b2-f16f-11cf-88cb-001111000030} (GUID_DEVINTERFACE_HID)
    Kernel Name          : \Device\00000106
    Device ID            : HID\VID_1532&PID_00A4&MI_01&COL06\A&2B199639&0&0005
    Class                : HIDClass
    Driver KeyName       : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0273 (GUID_DEVCLASS_HIDCLASS)
   Child Device 7        : HID-compliant device
    Device Path          : \\?\HID#VID_1532&PID_00A4&MI_01&Col07#a&2b199639&0&0006#{4d1e55b2-f16f-11cf-88cb-001111000030} (GUID_DEVINTERFACE_HID)
    Kernel Name          : \Device\00000107
    Device ID            : HID\VID_1532&PID_00A4&MI_01&COL07\A&2B199639&0&0006
    Class                : HIDClass
    Driver KeyName       : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0274 (GUID_DEVCLASS_HIDCLASS)
   Child Device 8        : HID-compliant device
    Device Path          : \\?\HID#VID_1532&PID_00A4&MI_01&Col08#a&2b199639&0&0007#{4d1e55b2-f16f-11cf-88cb-001111000030} (GUID_DEVINTERFACE_HID)
    Kernel Name          : \Device\00000108
    Device ID            : HID\VID_1532&PID_00A4&MI_01&COL08\A&2B199639&0&0007
    Class                : HIDClass
    Driver KeyName       : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0275 (GUID_DEVCLASS_HIDCLASS)
 Child Device 3          : Razer Mouse Dock Pro
  Device ID              : USB\VID_1532&PID_00A4&MI_02\9&E1624B6&0&0002
  Class                  : HIDClass
  Driver KeyName         : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0282 (GUID_DEVCLASS_HIDCLASS)
  Service                : HidUsb
  LocationPaths          : PCIROOT(0)#PCI(0801)#PCI(0003)#USBROOT(0)#USB(1)#USB(4)#USB(3)#USBMI(2)  ACPI(_SB_)#ACPI(PCI0)#ACPI(GP13)#ACPI(XHC0)#ACPI(RHUB)#ACPI(PRT1)#USB(4)#USB(3)#USBMI(2)
    Device Path 1        : \\?\HID#VID_1532&PID_00A4&MI_02#a&2aee870&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd (GUID_DEVINTERFACE_HID)
    Device Path 2        : \\?\HID#VID_1532&PID_00A4&MI_02#a&2aee870&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd} (GUID_DEVINTERFACE_KEYBOARD)
    Device Path 3        : \\?\HID#VID_1532&PID_00A4&MI_02#a&2aee870&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd (GUID_DEVINTERFACE_HID)
    Kernel Name          : \Device\00000109
    Device ID            : HID\VID_1532&PID_00A4&MI_02\A&2AEE870&0&0000
    Class                : Keyboard
    Driver KeyName       : {4d36e96b-e325-11ce-bfc1-08002be10318}\0022 (GUID_DEVCLASS_KEYBOARD)
    Service              : kbdhid
        +++++++++++++++++ Registry USB Flags +++++++++++++++++
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\usbflags\153200A40101
 osvc                    : REG_BINARY 00 00
 NewInterfaceUsage       : REG_DWORD 00000000 (0)
        ---------------- Connection Information ---------------
Connection Index         : 0x03 (Port 3)
Connection Status        : 0x01 (DeviceConnected)
Current Config Value     : 0x01 (Configuration 1)
Device Address           : 0x0E (14)
Is Hub                   : 0x00 (no)
Device Bus Speed         : 0x02 (High-Speed)
Number Of Open Pipes     : 0x03 (3 pipes to data endpoints)
Pipe[0]                  : EndpointID=1  Direction=IN   ScheduleOffset=0  Type=Interrupt
Pipe[1]                  : EndpointID=2  Direction=IN   ScheduleOffset=0  Type=Interrupt
Pipe[2]                  : EndpointID=3  Direction=IN   ScheduleOffset=0  Type=Interrupt
Data (HexDump)           : 03 00 00 00 12 01 00 02 00 00 00 40 32 15 A4 00   ...........@2...
                           01 01 01 02 00 01 01 02 00 0E 00 03 00 00 00 01   ................
                           00 00 00 07 05 81 03 08 00 01 00 00 00 00 07 05   ................
                           82 03 10 00 01 00 00 00 00 07 05 83 03 08 00 01   ................
                           00 00 00 00                                       ....
        --------------- Connection Information V2 -------------
Connection Index         : 0x03 (3)
Length                   : 0x10 (16 bytes)
SupportedUsbProtocols    : 0x03
 Usb110                  : 1 (yes, port supports USB 1.1)
 Usb200                  : 1 (yes, port supports USB 2.0)
 Usb300                  : 0 (no, port not supports USB 3.0) -> but Companion Port 2-5-4-3 does
 ReservedMBZ             : 0x00
Flags                    : 0x00
 DevIsOpAtSsOrHigher     : 0 (Device is not operating at SuperSpeed or higher)
 DevIsSsCapOrHigher      : 0 (Device is not SuperSpeed capable or higher)
 DevIsOpAtSsPlusOrHigher : 0 (Device is not operating at SuperSpeedPlus or higher)
 DevIsSsPlusCapOrHigher  : 0 (Device is not SuperSpeedPlus capable or higher)
 ReservedMBZ             : 0x00
Data (HexDump)           : 03 00 00 00 10 00 00 00 03 00 00 00 00 00 00 00   ................
    ---------------------- Device Descriptor ----------------------
bLength                  : 0x12 (18 bytes)
bDescriptorType          : 0x01 (Device Descriptor)
bcdUSB                   : 0x200 (USB Version 2.00)
bDeviceClass             : 0x00 (defined by the interface descriptors)
bDeviceSubClass          : 0x00
bDeviceProtocol          : 0x00
bMaxPacketSize0          : 0x40 (64 bytes)
idVendor                 : 0x1532 (Razer (Asia-Pacific) Pte Ltd.)
idProduct                : 0x00A4
bcdDevice                : 0x0101
iManufacturer            : 0x01 (String Descriptor 1)
 Language 0x0409         : "Razer"
iProduct                 : 0x02 (String Descriptor 2)
 Language 0x0409         : "Razer Mouse Dock Pro"
iSerialNumber            : 0x00 (No String Descriptor)
bNumConfigurations       : 0x01 (1 Configuration)
Data (HexDump)           : 12 01 00 02 00 00 00 40 32 15 A4 00 01 01 01 02   .......@2.......
                           00 01                                             ..
    ------------------ Configuration Descriptor -------------------
bLength                  : 0x09 (9 bytes)
bDescriptorType          : 0x02 (Configuration Descriptor)
wTotalLength             : 0x0054 (84 bytes)
bNumInterfaces           : 0x03 (3 Interfaces)
bConfigurationValue      : 0x01 (Configuration 1)
iConfiguration           : 0x00 (No String Descriptor)
bmAttributes             : 0xE0
 D7: Reserved, set 1     : 0x01
 D6: Self Powered        : 0x01 (yes)
 D5: Remote Wakeup       : 0x01 (yes)
 D4..0: Reserved, set 0  : 0x00
MaxPower                 : 0xFA (500 mA)
Data (HexDump)           : 09 02 54 00 03 01 00 E0 FA 09 04 00 00 01 03 01   ..T.............
                           02 00 09 21 00 01 00 01 22 5E 00 07 05 81 03 08   ...!...."^......
                           00 01 09 04 01 00 01 03 00 01 00 09 21 00 01 00   ............!...
                           01 22 3A 01 07 05 82 03 10 00 01 09 04 02 00 01   .":.............
                           03 01 01 00 09 21 11 01 00 01 22 3D 00 07 05 83   .....!...."=....
                           03 08 00 01                                       ....
        ---------------- Interface Descriptor -----------------
bDescriptorType          : 0x04 (Interface Descriptor)
bInterfaceNumber         : 0x00
bAlternateSetting        : 0x00
bNumEndpoints            : 0x01 (1 Endpoint)
bInterfaceClass          : 0x03 (HID - Human Interface Device)
bInterfaceSubClass       : 0x01 (Boot Interface)
bInterfaceProtocol       : 0x02 (Mouse)
iInterface               : 0x00 (No String Descriptor)
Data (HexDump)           : 09 04 00 00 01 03 01 02 00                        .........
        ------------------- HID Descriptor --------------------
bDescriptorType          : 0x21 (HID Descriptor)
bcdHID                   : 0x0100 (HID Version 1.00)
bCountryCode             : 0x00 (00 = not localized)
bNumDescriptors          : 0x01
Data (HexDump)           : 09 21 00 01 00 01 22 5E 00                        .!...."^.
Descriptor 1:
bDescriptorType          : 0x22 (Class=Report)
wDescriptorLength        : 0x005E (94 bytes)
Error reading descriptor : ERROR_INVALID_PARAMETER (due to a obscure limitation of the Win32 USB API, see UsbTreeView.txt)
        ----------------- Endpoint Descriptor -----------------
bLength                  : 0x07 (7 bytes)
bDescriptorType          : 0x05 (Endpoint Descriptor)
bEndpointAddress         : 0x81 (Direction=IN EndpointID=1)
bmAttributes             : 0x03 (TransferType=Interrupt)
wMaxPacketSize           : 0x0008
 Bits 15..13             : 0x00 (reserved, must be zero)
 Bits 12..11             : 0x00 (0 additional transactions per microframe -> allows 1..1024 bytes per packet)
 Bits 10..0              : 0x08 (8 bytes per packet)
bInterval                : 0x01 (1 ms)
Data (HexDump)           : 07 05 81 03 08 00 01                              .......
bInterfaceNumber         : 0x01
bInterfaceSubClass       : 0x00 (None)
bInterfaceProtocol       : 0x01 (Keyboard)
Data (HexDump)           : 09 04 01 00 01 03 00 01 00                        .........
Data (HexDump)           : 09 21 00 01 00 01 22 3A 01                        .!....":.
Descriptor 1:
wDescriptorLength        : 0x013A (314 bytes)
bEndpointAddress         : 0x82 (Direction=IN EndpointID=2)
wMaxPacketSize           : 0x0010
 Bits 10..0              : 0x10 (16 bytes per packet)
Data (HexDump)           : 07 05 82 03 10 00 01                              .......
bInterfaceNumber         : 0x02
Data (HexDump)           : 09 04 02 00 01 03 01 01 00                        .........
bcdHID                   : 0x0111 (HID Version 1.11)
Data (HexDump)           : 09 21 11 01 00 01 22 3D 00                        .!...."=.
Descriptor 1:
wDescriptorLength        : 0x003D (61 bytes)
bEndpointAddress         : 0x83 (Direction=IN EndpointID=3)
Data (HexDump)           : 07 05 83 03 08 00 01                              .......
    ----------------- Device Qualifier Descriptor -----------------
Error                    : ERROR_GEN_FAILURE
      -------------------- String Descriptors -------------------
             ------ String Descriptor 0 ------
bLength                  : 0x04 (4 bytes)
bDescriptorType          : 0x03 (String Descriptor)
Language ID[0]           : 0x0409 (English - United States)
Data (HexDump)           : 04 03 09 04                                       ....
             ------ String Descriptor 1 ------
bLength                  : 0x0C (12 bytes)
Data (HexDump)           : 0C 03 52 00 61 00 7A 00 65 00 72 00               ..R.a.z.e.r.
             ------ String Descriptor 2 ------
bLength                  : 0x2A (42 bytes)
Data (HexDump)           : 2A 03 52 00 61 00 7A 00 65 00 72 00 20 00 4D 00   *.R.a.z.e.r. .M.
                           6F 00 75 00 73 00 65 00 20 00 44 00 6F 00 63 00   o.u.s.e. .D.o.c.
                           6B 00 20 00 50 00 72 00 6F 00                     k. .P.r.o.
sounds like its lying about self powered and the demand current both. no shocker there I suppose. some of these is not actually the demand current but absurdly high transients… but powered hubs are the fix regardless
I have the same issue with the same peripherals but connecting to a powered hub connected to the USB 3.0 port causes the mouse to disconnect whenever I switch between computers on the KVM. Did you ever solve this?
The mouse otherwise works fine but usb3 peripherals will disconnect/reconnect when switching ports?
HID compliant devices don’t have to connect/disconnect but not much we can do if Razer is off-script here. It should work on both hosts but their devices’ design only permits connection to one host at a time (i.e. they didn’t bother with the dynamic device mapping part of the usb spec).
Oh I’m sure this is a Razer issue, just hoping to find a solution. Going to try a few more things before just giving up and sticking with a mouse that works.
Sometimes the mouse disconnects when changing inputs. All I do is change it to Bluetooth or Off and back to 2.4 and it reconnects quick. At least it doesn’t drop out while using it now. This issue may happen once every few days so tolerable compared to before.
