Well here a Lexus is200 with an ls400 1UZ-FE v8 slapped into it running on a speeduino. I’ve since extended the loom through the firewall and tidied it all up. Having some issues with noise on the crank/cam triggers causing sync issues but nothing too major.
Had a bit of bad luck while swapping my winter tires on to my 2006 Dodge ram 1500. I torqued the nuts to 110 ft/lbs. The last torque is supposed to be 135. Pulled a stud apart…
I’m not a fan of seat covers. I’d suggest taking a trip to your local junkyard and see if you can find a matching seat that’s in good condition (probably after it warms back up a bit).
