Hi, I’ve tried to use my Falcon 20 RGB with the HID port to control my KVM, and it works until I switch a machine, and then breaks in the weirdest way. After switching, the keys stop working and some of the LED’s randomly turn on and others off. So far the LED lights are non-deterministic in what turns on/off, but the keys always stop working.
I investigated a tiny bit, and I think when swapping devices there might be issues because it seems like the Falcon 20 RGB presents itself as two separate HID devices, and I wonder if that breaks the switching logic. The board seems to go into a weird state after swapping machines, and I have to unplug it, wait for power to it to die, and then plug it back in.
@wendell has mentioned that they use a Falcon 8 RGB, and I was also hoping the Falcon 20 RGB would work (I already had it before the KVM)
