I succeded in getting KVM with VGA passthough on an AMD APU and MSI Radeon 390 after the advice given to me from my previous topic:
https://forum.teksyndicate.com/t/getting-kvm-vga-passthrough-to-work-with-amd-apu-and-dedicated-gpu-on-arch-linux/87817
So now I have the latest Radeon driver installed and a basic Windows system running with a few games.
The issue though is when in-game. It plays flawlessly at better performance than my old system (probably because there was so many background processes sloing them down) but occasionally freezes for a few seconds. Say Geralt is mid-sentence and he freezes with this horrible buzzing sound in my headphones. Are there and settings I am missing, doing wrong or is it just an issue I'll have to deal with?
My QEMU Script:
QEMU_PA_SAMPLES=128 QEMU_AUDIO_DRV=pa
qemu-system-x86_64 \
-serial none \
-parallel none \
-nodefaults \
-nodefconfig \
-enable-kvm \
-name Windows \
-cpu host,kvm=off,check \
-smp sockets=1,cores=4,threads=1 \
-m 6144 \
-rtc base=localtime \
-drive if=pflash,format=raw,readonly,file=/usr/share/ovmf/x64/ovmf_code_x64.bin \
-drive if=pflash,format=raw,file=/usr/share/ovmf/x64/ovmf_vars_x64.bin \
-device vfio-pci,host=01:00.0,multifunction=on \
-device vfio-pci,host=01:00.1 \
-soundhw hda \
-netdev user,id=user.0 -device e1000,netdev=user.0 \
-usb -usbdevice host:046d:c537 -usbdevice host:2516:0011 \
-boot menu=on \
-nographic \
-vga none \
-device virtio-scsi-pci,id=scsi \
-device ide-cd,bus=ide.1,drive=virtiocd \
-drive file=/usr/share/virtio/virtio-win.iso,id=virtiocd,if=none \
-hda ./windows/win.qcow2
System Specs:
AMD A10 6800K
MSI R9 390 8GB
AsRock FM2A85X-ITX
Arch Linux running Windows 8.1 with UEFI BIOS(s) from https://www.kraxel.org/repos/jenkins/edk2/
I can cope it most of the time, but it definitely is immmersion breaking and online games will be near unplayable if I lock mid game. I already have terrible ping times as it is! I'm also having trouble getting the pulseaudio to work as I have to run the script as root..
Update
I also get a few blue screens (CRITICAL_PROCESS_ERROR) in which I can only fix by going into safe mode, uninstalling the graphics driver and rebooting. The graphics then reinstalls and I can reboot a few times until another
blue screen.
It can also be kind of random. It can restart after a blue screen and the system is working fine again..
Is this an issue with KVM or something I am doing wrong? I also
cannot get an arch linux guest to run. It completely freezes after a few of the bootup messages...
