Hello everyone!
I’m planning to set up my workspace and need some advice regarding KVM switches, particularly from Level1Tech. Here’s the setup I’m aiming for:
My hardware:
1 Gaming PC (NVIDIA RTX 4090 GPU)
1 MacBook Air M3
3 Monitors:
KVM switch: A KVM that supports DisplayPort 1.4 and can handle these three monitors plus USB peripherals.
My Ultimate Goal
I’m planning to move to the Apple ecosystem and use Macbook air for my day-to-day computing tasks and use the PC purely for gaming or any CPU-intensive tasks.
My Questions
KVM Selection: I’m looking into the KVM options from Level1Tech, but I’m not sure which model would suit my needs. Which one would you recommend for managing this setup?
MacBook Air M3 with 3 Monitors: I know the MacBook Air M3 doesn’t support three monitors out of the box. Are there any good workarounds, like docking stations or adapters, that could enable this? Or should I consider scaling back my setup to two monitors for the Mac?
Alternative Setup: If the 3-monitor setup for the Mac is too complicated or not possible, I’m considering a fallback option:
- Use 3 monitors on the Gaming PC (2 through the KVM, 1 directly connected).
- Use 2 monitors on the MacBook (through the KVM).
- Connect the Samsung LS32B30 directly to the PC and exclude it from the KVM for the Mac. Would this be a more straightforward approach, and would the KVM handle the switching seamlessly in this scenario?
- Software Solution: Is there a reliable software-based solution that would allow one of the machines to be directly connected to the monitors while accessing the other machine via a remote desktop connection? Ideally, it would support 1440p 175Hz HDR over a 1 Gigabit LAN. This might help simplify my setup by reducing the reliance on physical KVM switching.
I’m open to suggestions, and I appreciate any advice on which Level1Tech KVM model to go with and how best to optimize this dual-PC, multi-monitor setup!
I believe I should use one of these two:
Combo USB-C Power Delivery & DisplayPort 1.4 KVM - Triple Monitor — Level1Techs Store
1.4 Display Port KVM Switch - Triple Monitor - Two Computer — Level1Techs Store
Thanks in advance! ![]()
