KVM Combo USB-C Power Delivery & DisplayPort 1.4 KVM - Dual Monitor incl usb-c combiner version
KVM Model:
Having issues with my keyboard. I use a Mac and pc. all works great, except my keyboard does not show up now and then on my Mac after switching. Had it connected on backside. Tried all 3 white ports, hid and the one non hid. But when I connect my keyboard (krytron) to the front one it works. Tried different cables, same issue.
USB Interface (10-gigbit):
type here
Problem:
type here
Other Notes:
type here
blue port on the back probably fine if the front one is also fine? the white ports are meant for hid devices and maybe the keyboard is not fully hid or has extra non-hid endpoints?
I use this for my mouse… high polling one…. would performance be the same if I use the mouse on the hid ones?
to 1khz yes. if above 1khz the blue is probably a better bet
Love your kvm. But I still have the issue of my keycron keyboard not working on any of the ports in the back (except blue) and I need that for the mouse. It is weird but for the keyboard I thought USB 1.1 should be fine… weird.
Can you disable NKRO and power cycle the KVM? The hotkey might be function + n
