So I've been attempting to follow Tpc 010's tutorial on passing through a gpu to a windows 7 virtual machine. I'm on Devian 8.2, using the ovmf packages from sid. I' m using the integrated graphics on my i7 4790k for debian, and a gtx 970 for my windows 7 kvm.
Whenever I run the script shown below, it posts and then boots into the UEFI interactive shell. I'm assuming there is an issue within the script, but I cant seem to find it. By the way, I am getting video output from the monitor attached to the gtx 970.
#!/bin/sh
INSTALLFILE=win7-uefi-x64_system.qcow2
FILESIZE=50G
INSTALLCD=/home/tahj/Downloads/W.iso
# if you use a hardware CD-ROM drive, check for the device. In most cases it's /dev/sr0
#INSTALLCD=/dev/sr0
DRIVERCD=/home/tahj/Downloads/virtio-win-0.1.102.iso
# PCI address of the passthrough devices
DEVICE1="01:00.0"
DEVICE2="01:00.1"
# load vfio-pci module
modprobe vfio-pci
for dev in "0000:$DEVICE1" "0000:$DEVICE2"; do
vendor=$(cat /sys/bus/pci/devices/$dev/vendor)
device=$(cat /sys/bus/pci/devices/$dev/device)
if [ -e /sys/bus/pci/devices/$dev/driver ]; then
echo $dev > /sys/bus/pci/devices/$dev/driver/unbind
fi
echo $vendor $device > /sys/bus/pci/drivers/vfio-pci/new_id
done
# create installation file if not exist
if [ ! -e $INSTALLFILE ]; then
qemu-img create -f qcow2 $INSTALLFILE $FILESIZE
fi
QEMU_PA_SAMPLES=4096 QEMU_AUDIO_DRV=pa \
qemu-system-x86_64 \
-enable-kvm \
-m 8192 \
-cpu host,kvm=off \
-smp 4,sockets=1,cores=4,threads=2 \
-machine pc-i440fx-2.1,accel=kvm \
-soundhw hda \
-bios /usr/share/ovmf/OVMF.fd `# SID version of OVMF` \
-device vfio-pci,host=$DEVICE1,addr=0x8.0x0,multifunction=on \
-device vfio-pci,host=$DEVICE2,addr=0x8.0x1 \
-vga qxl \
-device virtio-net-pci,netdev=user.0,mac=52:54:00:a0:66:43 \
-netdev user,id=user.0 \
-drive file=$INSTALLCD,if=none,id=drive-ide0-0-0,readonly=on,format=raw \
-device ide-cd,bus=ide.0,unit=0,drive=drive-ide0-0-0,id=ide0-0-0,bootindex=1 \
-drive file=$INSTALLFILE,if=none,id=drive-virtio-disk0,format=qcow2,cache=unsafe \
-device virtio-blk-pci,scsi=off,addr=0x7,drive=drive-virtio-disk0,id=virtio-disk0,bootindex=2 \
-drive file=$DRIVERCD,if=none,id=drive-ide0-1-0,readonly=on,format=raw \
-device ide-cd,bus=ide.0,unit=1,drive=drive-ide0-1-0,id=ide0-1-0,bootindex=3 \
-rtc base=localtime,driftfix=slew \
-smb /home/tahj/Downloads/toinstall \
-usb \
-device usb-tablet \
-device usb-kbd
I've seen different answers for what should be placed under smp, but I think this is correct?
And this is hopefully correct for a gtx 970?
Any advice would be greatly appreciated.
Here is a screenshot:
