Korean 1440p Monitor
i was looking at the monitors on ebay and they look really appealing BUT
i was looking at reviews and it says it needs a dual link dvi
i have a 290 and it doesn't have dual link so i want to know will it work ?
the 290 DOES have dual link dvi.
Ummmm, Yes it does...
thats dvi d not dual link
Are you dumb or just ignorant?
It is a DL DVI. If it has all the pins it is dual link. DVI-I and DVI-D only refer to the connector on the one end. DVI-I or DVI-D can be dual link or single link.
The card has a dual link connector. You will be fine.
Lol, little harsh, don't you think?  He confused a concept.  Happens to us all at some point.
thank you
Yeah it was a bit harsh I'm sorry for that. It just irritated me though because he clearly doesn't know yet is trying to correct people. But I suppose I took it a bit to far.
ok all good thanks for the help just ordered the monitor the shimian and it should be here on Friday
which one of these is the best for gaming ?
http://www.ebay.ie/itm/X-Star-DP2710-LED-Matte-27-2560x1440-SAMSUNG-PLS-Panel-27inch-DVI-PC-Monitor-/310715093684?pt=UK_Computing_ComputerComponents_Monitors&hash=item48581012b4
http://www.ebay.ie/itm/Perfect-Pixel-QNIX-QX2710-LED-Evolution-2-27-2560x1440-QHD-PLS-Monitor-Matte-/121306346985?pt=Computer_Monitors&hash=item1c3e6bf5e9
http://www.ebay.ie/itm/Achieva-Shimian-QH2700-IPSMS-Edge-Eco-27-LED-2560x1440-AH-IPS-DVI-PC-Monitor-/131033629039?pt=Computer_Monitors&hash=item1e8236816f
they all slower IPS/PLS WQHD panels. the primary difference between them is the coating on them.
I can't speak for the Qnix and the Shimian but as an Xstar owner the coating on it is AMAZING
