Kingston or Adata?
I recently decided to get an SSD because I am a stickler about my loading times. I decided to go with a 120gb SSD because my budget is limited and usually after a 120gb SSD, prices beging to skyrocket. But, I am suck between two products.
I've heard great things about Kingston and Adata when it comes to their SSD's. I understand Logan is quite the fan of Kingston's HyperX SSD's, but Newegg is currently doing a Shellshocker sale on Adata's 128gb SSD. So which leads me to my question, which one should I get?
The Adata sx900 and Hyperx 3k are almost completely identical. Take advantage of the sale and get the Adata.
Both are sweet products, so it basically comes down to price :)
I prefer Adata, but I don't have personal experience with them, my friends have them. No problems to report thus far. Just avoid Crucial like the plague.
I have an adata sx900 and love it
With SSDs, you have to shop according to use.
For instance, SandForce controllers have some benefits, especially with regards to speed on hugely compressible systems like Windows. But on linux systems for instance, especially when using full disk encryption (which makes the data non-compressible), they suck bigtime. Also TRIM-performance is a big factor, TRIM is not necessary in linux because if you want to trim an SSD, you just tell the system to not do something instead of telling it to do extra stuff like on Windows.
Samsung SSDs pretty much rule: they are bloody fast, also with non-comressible data, they support ATA-encryption (hardware encryption linked to the BIOS), which is safer and faster, they keep their performance very well with linux "TRIM" systems, and Samsung has an open source super fast SSD-filesystem for linux that breaks records in terms of performance. Samsung SSDs are also well supported in Windows, and although they will lose some long term performance due to the legacy filesystem and the handicapped TRIM-implementation in Windows, they will still outperform pretty much everything.
both are great indeed, the A-data sx900  got a mounting bracked included.
