Hi ppl,
I’m looking for a tool to get all licenses and serial numbers of my pc before reseting it.
Best would be something that I can throw on a usb stick that saves files to a txt on the usb stick.
Greetings,
Lighto
Hi ppl,
Greetings,
Lighto
I am pretty sure aida64 does that. But it’s paid
Portable has to be paid for (only have used free).
Couldn’t you just install it onto a usb drive? And then run it on another system? Or is it smart enough to noticed that and not work
Yea you could just download the installer on the flash drive and run it on the computer that way. (wouldn’t see why not)
