TL;DR
My Keychron Q6 Max suddenly stopped triggering my KVM’s Ctrl+Ctrl+[1-4] hotkeys. A Bus Hound comparison showed the Keychron was sending a leading report ID byte (01) that my working keyboard didn’t send. Keychron support gave me custom firmware for the keyboard (fixes wired) and test firmware for the 2.4 GHz receiver (fixes the dongle). Both are now working through the KVM.
Setup
Keyboard: Keychron Q6 HE
KVM: Level1Techs HDMI 2.1 KVM, dual monitor, four computer
Hotkey: Ctrl + Ctrl + input number (1-4), set up as macros on the four top-right keys
Tools: Bus Hound (Perisoft) to capture USB HID reports (I just used the free version, its sufficient)
Symptoms
The hotkeys worked for a long time, then stopped with no change I could identify.
A replacement KVM from Level1Techs didn’t fix it.
A separate wired Lenovo keyboard switched inputs fine on the same KVM.
Resetting the Keychron didn’t help.
Diagnosis
Amber here at Level 1 Techs first suggested NKRO was the cause. Keychron explained to me that the board uses mixed reporting; normal typing goes through a standard 6KRO interface, and extra keys go through NKRO only when many keys are held. There was no way to turn NKRO off on my keyboard. Bus Hound exhibited what Keychron told me.
I captured the Left Control press from my Keychron and from a Lenovo keyboard that works with the KVM. The reports were identical except for the first byte:
Lenovo:
00 01 00 00 00 00 00 00 -
Keychron:
01 01 00 00 00 00 00 00
Keychron suggested that the leftmost
01is the report ID. It’s a normal part of how the keyboard reports over USB and isn’t an error by itself. In my case, though, the KVM seemed to not cooperate with that.
What was tried
Updating all devices to the latest firmware.
Replacing the KVM: Thank you so much Level One Techs for being so accommodating!
Custom keyboard firmware from Keychron (
q6_he_ansi_encoder_v1.2.1) got wired switching working again. The wired report now sends00. -
Test receiver firmware from Keychron (
keychron_link_type_d_fw_d.3.2_4.kfw): This fixed the keyboard when using the dongle which is really what I cared about, I prefer a wireless setup.
Solution
Use the files I was provided and flash the keyboard and the reciever following the steps here (skip step 3): https://www.keychron.com/pages/how-to-flash-the-firmware-for-the-keychron-receiver
Test both wired and wireless with Bus Hound to make sure there is no
01. -
Test hotkey switching while wired, then through the dongle, with the KVM.
Notes
Bluetooth: The KVM doesn’t accept Bluetooth, so I didnt push for a firmware fix on that one. If I ever use Bluetooth, it would be direct with a computer, so whatever.
This is custom/test firmware, not public releases; I AM NOT RESPONSIBLE IF YOU BRICK YOUR HARDWARE WITH THE FIRMWARE. USE AT YOUR OWN RISK.
Yes, I used AI to summarize my many emails and steps for this post; I fact-checked what it wrote out and read over it twice.
I am not able to post the files as I am a new user. I sent them to Amber, hoping she can pin them below.
