Keyboard sticking and mouse disconnecting randomly
KVM Model:
1.4 DisplayPort KVM - Dual Monitor - Dual Computer
10 gbps (USB 3.2 Gen2)
Problem:
The problem is with both the keyboard and mouse, but specifically on PC2 (PC1 is completely fine). The keyboard will occasionally just freeze up and repeat the last key pressed for about a second, then resume working normally. The mouse will simply disconnect entirely and requires that I either unplug and replug it, or switch it off for a second and then switch it back on.
Things I’ve tried:
  • Disabling power-saving features on the USB root hub
  • Unplugging everything from the KVM including power and leaving it overnight
  • Uninstalling / reinstalling Logitech mouse software
The keyboard is a Keychron Q6 Max, the mouse a Logitech G900. The mouse is plugged into the front USB port (not the HID), the keyboard into the rear USB input port (again not the HID). PC1 is a custom Ryzen build running Windows 11, PC2 is a Dell Precision 5860 running Windows 11. Again PC1 works totally fine, it’s just PC2 that’s having these disconnections. Any ideas?
Other Notes:
type here
This sounds so familiar… I had these issues but without a KVM. In my case it was because of the crappy USB3 implementation on my motherboard. Heavy wifi, bt or file transfers over USB would also cause it to hang…
I would try to check if it works better in other ports/controllers of PC2. Or try swapping cables, you never know if it’s a bad one, it happens :slight_smile:
These two devices should be fine in the HID ports. Power cycle the kvm:
unplug everything and and wait for about 5 minutes, then plug the keyboard and mouse into the HID ports.
Then just make sure n-key rollover is disabled on the Keychron.
Try that and lmk how it goes?
