Keyboard and Mouse won't work [solved]
I read online to reinstall my usb hubs and now when I restarted my PC I can't login to Windows so I'm screwed. Also I'm on Windows 10j
I moved this to the windows category for you where i might get more appropriate attention.
Stating the obvious probably but have you tried all your USB ports? windows treats them separately (generally). If your computer has a PS/2 port you could get a PS/2 mouse or USB adapter that would give you back your mouse and keyboard (if you have two ports).
That's about as far as my knowledge on this goes for Windows.
Thanks. And I fixed it i turned my computer on and went to chipotle and came back and it worked xD
