Hi everyone, I've been getting some kernel panics when ever I try to boot into linux using a USB stick. I can boot into windows fine and I can also play video games, but linux doesn't seem to work. I miss Linux so much.
It doesn't seem to be my memory. I've done a memtest on both RAM sticks (both, and individually). Also done the intel diagnostics tool, and it passed there. I'm not sure how accurate that test is.
I have been off windows since my windows 7 gaming rig was forced to have window 10 during their big push. I'v never looked back! I hope this clears up for you.
Is booting from a particular USB stick the only way you start Linux? Is that particular USB stick itself still healthy? If you're not sure about the last question, buy a new USB stick and put a bootable Linux distro on it. Does that new stick start up normally? If so, that would isolate the fault to that particular stick or the binaries on it.
Another tack: mce = Machine Check Error. The phrase "Machine check events logged" is hopeful. Has a /var/log/mcelog.out file been written on the logging folder of the USB-stick linux? Can you pastbin it anywhere for us to see?
The address ranges make me thing there is a failure related to the bootloader or a bootloader handoff. In which case, your system may be unable to boot from USB, or there is a failure related to the USB drive you are using. Check your USB drive integrity before continuing.
Hey everyone. Sorry for the slow replies. My brain is usually fried during the week.
Secure Boot, Fast Boot, and the BIOS says "Other OS". There's no overclocking from what I'm gathering as well.
I used Rufus (that was recommended to me on the ubuntu website), also tried unetbootin, since that worked a while ago but I've read that it's not recommended to use these days
I tried a different USB stick, and different USB port, different distro (Mint. I can also try Fedora soon) and plugging out all my harddrives before booting and they all give me a kernel panic.
Could it be some sort of motherboard issue?
Just wanted to say thank you for being so patient in helping me. It's kind of nerve wrecking to ask for advice for these things lol, it's nice to know that people are so friendly and helpful when it comes to these things.
Hi tkoham! * I checked the ISO file using MD5 and it matched with the hash provided on the ubuntu website. Hope that's fine. * Makes total sense. I'll give Fedora a try * Currently only on Windows. I think the equivalent would be DD for windows or Win32DiskImager.
