Kde neon for me is borker - enter (TUXEDO) SETUP ADVICE NEEDED
i need some info an advice on using TUXEDO os for my custom build ryzen pc
right now i cant seem to get kde neon to install even with the latest stable release
a script fail at 89% keps f’ing me up
so i wanted a os that had kde base that supports wayland & vrr an hdr the way neon does
so i went with tuxedo but id like to know some things an get some advice so i dont have to go back to
to Ubuntu
i want to know a few things
does it support vrr ?
does it support gpt with btrfs filing system ?
does it have zram enabled or can i install it an enable ?
can i add an enable btrfs with force compression with zstd to the custom partitions
an in fstab how should that per partition string look ?
is this a custom fstab string that will work in tuxedo
btrfs defaults,compress-force=zstd:4,nodiratime,space_cache=v2,discard=async,commit=90
So I don’t know the things on the list.
But for kde with plasma(I am new to this)
VRR
Zram
I use nobara.
I am currently not using the more customized weebara one(I messed up after getting rid of Windows).
One issue to point out for me.
On the non weeb nobara I get more kde plasma crashes. Don’t know if there is a major difference between the two versions of nobara.
Have you connected network or wifi?
for the native kde neon no just offline installer , but for tuxedo yes although something went wrong when updating vi the the discovery app after reboot the network can access the internet but can still access the home network it printer an nas
Try connecting LAN or wifi before running the installer. I’ve seen similar errors just resolve themselves that way.
ill try that , but also any infi an advice on what i asked about the tuxedo install ?
Haven’t used it, so no. Read the docs you can yourself.
Last time I tried using KDE neon a few times it shit itself after a few minor updates and something was constantly broken.
I’d like to recommend something else to you - have you considered just using kubuntu or just any other linux distro with KDE as an option?
Any distribution, except the weird embedded ones supports this, and RHEL - since they support very little custom options.
Judging by this thread on reddit it appears to be not installed by default
https://old.reddit.com/r/kdeneon/comments/1fmly7q/help_needed_wtinstall_zram_corectrl/
space_cache=v2 afaik is deprecated as of latest kernels.
compress-force is questionable choice because it asks the filesystem implementation to not give up on compressing data it can obviously detect is not compressable
can’t comment about the other ones
here is official wiki you can read:
https://docs.kernel.org/filesystems/btrfs.html
and here are secondary sources in order of my preference:
https://wiki.archlinux.org/title/Btrfs
https://btrfs.readthedocs.io/en/latest/btrfs-filesystem.html
I recommend taking a quick look at all of them.
Also here is what I’m using:
rw,relatime,ssd,space_cache=v2,subvolid=260,subvol=/@rootfs
two questions
1 does kubuntu have working vrr
2 “space_cache=v2 afaik is deprecated as of latest kernels” then whats the latest space command to use
It’s not deprecated, it’s the new default. So there’s no point specifying it explicitly.
You’re overthinking the btrfs parameters IMO. The developers have a pretty good sense what good defaults are, there’s usually no point changing them unless you have a specific reason and know what you’re doing. E.g. async discard is default too (if an ssd is detected). commit=90 will only risk losing more data in a crash, and I fail to see the point especially for a desktop system; you use nodiratime (why?), while still having access times for files. Compress-force is rarely a good idea, since it will even compress uncompressible data (e.g. video/audio that’s already compressed), etc.
I don’t use KDE personally but I think it has vrr support. But linux being linux that may depend on your GPU as well.
Can’t tell you, you have to try it out, they have a live cd image you can boot without installing
btw, I also second what quilt is saying
thanks for the info about space an async i didnt know that
