KCBench and KCBenchRate - What's the most monster kernel devops box? SW
Introduction
This goes with a video we’re working on where we build systems around the Xeon 8380 and various AMD Epyc CPUs to see how each system handles building the Linux kernel.
Note this is different than the build benchmark in the Phoronix Test Suite – we are using kcbench and building all the modules.
The primary thing to understand is this breaks down into:
Which is better? One hundred duck-sized kernel builds, or one hore-sized kernel build?
It turns out that one hundred duck-sized builds is the best for multi-socket systems. For single-socket systems it only slightly favors the duck-sized builds over the singular horse-sized build.
Huh?
OK so kcbench will build the kernel with a certain number of make jobs (make -j # ). This is not perfectly linear scaling – especially with the kernel.
BUT kcbenchrate will allow us to specify how many parallel kernel builds we want, with an arbitrary number of threads for make to use.
This is very interesting because kcbench underestimates the performance of two-socket systems, both team blue and team red.
Let’s see the numbers!
 kcbench -s 5.15 -m                                               ✔
Processor:           AMD EPYC 7713 64-Core Processor [128 CPUs]
Cpufreq; Memory:     performance [acpi-cpufreq]; 64209 MiB
Linux running:       5.15.16-1-MANJARO [x86_64]
Compiler:            gcc (GCC) 11.1.0
Linux compiled:      5.15.0 [/home/w/.cache/kcbench/linux-5.15/]
Config; Environment: allmodconfig; CCACHE_DISABLE="1"
Build command:       make vmlinux modules
Filling caches:      This might take a while... Done
Run 1 (-j 128):      281.52 seconds / 12.79 kernels/hour [P:11307%, 8673 maj. pagefaults]
Run 2 (-j 128):      281.69 seconds / 12.78 kernels/hour [P:11315%, 9014 maj. pagefaults]
Run 3 (-j 139):      280.99 seconds / 12.81 kernels/hour [P:11367%, 8969 maj. pagefaults]
Run 4 (-j 139):      361.59 seconds / 9.96 kernels/hour [P:8868%, 9538 maj. pagefaults]
Run 5 (-j 64):       321.06 seconds / 11.21 kernels/hour [P:6112%, 7854 maj. pagefaults]
Run 6 (-j 64):       320.78 seconds / 11.22 kernels/hour [P:6112%, 9128 maj. pagefaults]
kcbenchrate -s 5.15 -m -w 4 -j 32
                                       10m 35s w@wkctest
Processor:           AMD EPYC 75F3 32-Core Processor [128 CPUs]
Cpufreq; Memory:     performance [acpi-cpufreq]; 515885 MiB
Starting 4 workers (each compiling with '-j 32'): .... All launched, starting to measure.
4 workers completed 4 kernels so far (avrg: 750.07 s/run) with a rate of 19.20 kernels/hour (each compiling with '-j 32').
4 workers completed 8 kernels so far (avrg: 750.09 s/run) with a rate of 19.20 kernels/hour (each compiling with '-j 32').
rocessor:           AMD EPYC 7763 64-Core Processor [256 CPUs]
Cpufreq; Memory:     performance [acpi-cpufreq]; 515845 MiB
Linux running:       5.15.12-1-MANJARO [x86_64]
Run 1 (-j 256):      154.74 seconds / 23.26 kernels/hour [P:19352%, 16302 maj. pagefaults]
Run 2 (-j 256):      153.63 seconds / 23.43 kernels/hour [P:19576%, 15873 maj. pagefaults]
Run 3 (-j 271):      154.49 seconds / 23.30 kernels/hour [P:19434%, 16735 maj. pagefaults]
Run 4 (-j 271):      153.34 seconds / 23.48 kernels/hour [P:19632%, 15888 maj. pagefaults]
Run 5 (-j 128):      170.21 seconds / 21.15 kernels/hour [P:11004%, 17576 maj. pagefaults]
Run 6 (-j 128):      170.05 seconds / 21.17 kernels/hour [P:11005%, 18344 maj. pagefaults]
Run 7 (-j 140):      167.19 seconds / 21.53 kernels/hour [P:12001%, 15410 maj. pagefaults]
Run 8 (-j 140):      167.43 seconds / 21.50 kernels/hour [P:11953%, 16770 maj. pagefaults]
cbenchrate -s 5.15 -m -w 8 -j 32                                                 127 ✘  5m 58s 
WARNING: Rate run still experimental. Use at your own risk!
Processor:           AMD EPYC 7763 64-Core Processor [256 CPUs]
Starting 8 workers (each compiling with '-j 32'): ........ All launched, starting to measure.
8 workers completed 8 kernels so far (avrg: 990.62 s/run) with a rate of 29.07 kernels/hour (each compiling with '-j 32').
8 workers completed 16 kernels so far (avrg: 991.16 s/run) with a rate of 29.06 kernels/hour (each compiling with '-j 32').
    ~  kcbench -s 5.15 -m         ✔  7s 
Can a workstation work?
Yes, but for this job if you only care about max # kernels/hour, then you need two sockets. Best value? One socket system by a wide margin. [Can you use distcc for max performance / $? oh probably … ]
kcbenchrate -s 5.15 -m -w 4 -j 32         ✔
Processor:           AMD Ryzen Threadripper PRO 3995WX 64-Cores [128 CPUs]
Cpufreq; Memory:     performance [acpi-cpufreq]; 515676 MiB
4 workers completed 4 kernels so far (avrg: 927.43 s/run) with a rate of 15.53 kernels/hour (each compiling with '-j
32').
4 workers completed 8 kernels so far (avrg: 927.08 s/run) with a rate of 15.53 kernels/hour (each compiling with '-j
32').
    ~  kcbench -s 5.15 -m         ✔  25s 
Run 1 (-j 128):      251.49 seconds / 14.31 kernels/hour [P:11182%, 8233 maj. pagefaults]
Run 2 (-j 128):      251.33 seconds / 14.32 kernels/hour [P:11197%, 8465 maj. pagefaults]
Run 3 (-j 139):      250.54 seconds / 14.37 kernels/hour [P:11261%, 8571 maj. pagefaults]
Run 4 (-j 139):      250.84 seconds / 14.35 kernels/hour [P:11236%, 8255 maj. pagefaults]
Run 5 (-j 64):       294.60 seconds / 12.22 kernels/hour [P:6096%, 6148 maj. pagefaults]
Run 6 (-j 64):       295.11 seconds / 12.20 kernels/hour [P:6093%, 6375 maj. pagefaults]
Run 7 (-j 72):       289.05 seconds / 12.45 kernels/hour [P:6816%, 6805 maj. pagefaults]
Run 8 (-j 72):       289.13 seconds / 12.45 kernels/hour [P:6813%, 7088 maj. pagefaults]
Notice that even in a single socket system, we get a small but measurable underestimate of compile rate with multiple parallel jobs.
Yes, there is work underway to speed this up however with things like LTS kernels.. we’re going to be doing it this way for at least 6 more years.
What abou Dual Xeon 8380s for this job?!
Here’s the Xeon 8380 – very impressive for 80 cores/160 threads:
Processor:           Intel(R) Xeon(R) Platinum 8380 CPU @ 2.30GHz [160 CPUs]
powersave [intel_pstate]; 515605 MiB
Run 1 (-j 160):      218.45 seconds / 16.48 kernels/hour [P:13747%, 9128 maj. pagefaults]
Run 2 (-j 160):      220.40 seconds / 16.33 kernels/hour [P:13785%, 9134 maj. pagefaults]
Run 3 (-j 172):      220.84 seconds / 16.30 kernels/hour [P:13836%, 9146 maj. pagefaults]
Run 4 (-j 172):      221.20 seconds / 16.27 kernels/hour [P:13840%, 8680 maj. pagefaults]
Run 5 (-j 80):       245.99 seconds / 14.63 kernels/hour [P:7511%, 7638 maj. pagefaults]
Run 6 (-j 80):       246.10 seconds / 14.63 kernels/hour [P:7508%, 7478 maj. pagefaults]
Run 7 (-j 89):       240.70 seconds / 14.96 kernels/hour [P:8303%, 8166 maj. pagefaults]
Run 8 (-j 89):       240.88 seconds / 14.95 kernels/hour [P:8293%, 8026 maj. pagefaults]
    ~  kcbenchrate -s 5.15 -m -w 4 -j 32                                                      ✔  34m 44s 
Cpufreq; Memory:     performance [intel_pstate]; 515605 MiB
4 workers completed 4 kernels so far (avrg: 828.40 s/run) with a rate of 17.38 kernels/hour (each compiling with '-j 32').
4 workers completed 8 kernels so far (avrg: 829.02 s/run) with a rate of 17.37 kernels/hour (each compiling with '-j 32').
3970X Threadripper, Older Intel Broadwell and 7402P Comparison Systems
$ ./kcbench -s 5.15 -o /dev/shm/ -m
Processor:           AMD EPYC 7502P 32-Core Processor [48 CPUs]
Cpufreq; Memory:     Unknown; 257618 MiB
Linux running:       4.19.0-17-amd64 [x86_64]
Compiler:            gcc (Debian 8.3.0-6) 8.3.0
Linux compiled:      5.15.0 [/home/gregkh/.cache/kcbench/linux-5.15/]
Run 1 (-j 48):       401.67 seconds / 8.96 kernels/hour [P:4428%]
Run 2 (-j 48):       401.83 seconds / 8.96 kernels/hour [P:4427%]
Run 3 (-j 54):       401.65 seconds / 8.96 kernels/hour [P:4452%]
Run 4 (-j 54):       401.49 seconds / 8.97 kernels/hour [P:4454%]
Run 5 (-j 24):       560.51 seconds / 6.42 kernels/hour [P:2391%]
Run 6 (-j 24):       558.85 seconds / 6.44 kernels/hour [P:2399%]
Run 7 (-j 29):       505.41 seconds / 7.12 kernels/hour [P:2876%]
Run 8 (-j 29):       505.59 seconds / 7.12 kernels/hour [P:2878%]
$ ./kcbench -o ~/tmp/ -s 5.15 -m
Processor:           Intel Core Processor (Broadwell) [40 CPUs]
Cpufreq; Memory:     Unknown; 120740 MiB
Linux running:       5.15.11-200.fc35.x86_64 [x86_64]
Compiler:            gcc (GCC) 11.2.1 20211203 (Red Hat 11.2.1-7)
Run 1 (-j 40):       1087.33 seconds / 3.31 kernels/hour [P:3662%, 8851 maj. pagefaults]
Run 2 (-j 40):       1091.40 seconds / 3.30 kernels/hour [P:3649%, 9283 maj. pagefaults]
Run 3 (-j 46):       1088.90 seconds / 3.31 kernels/hour [P:3690%, 7156 maj. pagefaults]
Run 4 (-j 46):       1093.40 seconds / 3.29 kernels/hour [P:3681%, 7469 maj. pagefaults]
Processor:           AMD Ryzen Threadripper 3970X 32-Core Processor [64 CPUs]
Cpufreq; Memory:     schedutil [acpi-cpufreq]; 257679 MiB
Linux running:       5.16.2-arch1-1 [x86_64]
Run 1 (-j 64):       390.46 seconds / 9.22 kernels/hour [P:5806%, 12974 maj. pagefaults]
Run 2 (-j 64):       391.27 seconds / 9.20 kernels/hour [P:5803%, 12972 maj. pagefaults]
Run 3 (-j 71):       399.18 seconds / 9.02 kernels/hour [P:5725%, 11822 maj. pagefaults]
Run 4 (-j 71):       391.20 seconds / 9.20 kernels/hour [P:5844%, 11629 maj. pagefaults]
Run 5 (-j 32):       488.53 seconds / 7.37 kernels/hour [P:3156%, 9134 maj. pagefaults]
Run 6 (-j 32):       488.95 seconds / 7.36 kernels/hour [P:3150%, 8448 maj. pagefaults]
Run 7 (-j 38):       461.76 seconds / 7.80 kernels/hour [P:3722%, 8009 maj. pagefaults]
Run 8 (-j 38):       461.32 seconds / 7.80 kernels/hour [P:3723%, 7662 maj. pagefaults]
It is worth noting that depending on your motherboard and bios version you might see between 2.3 and 2.91 boost clocks running this job. I was running a later bios with better performance – the earlier bios wasn’t as good because the CPUs would taper off to 2.3ghz after a short time and this test usually runs for ~2 hours.
Wendell
Here’s for an Epyc 7443P
root@pve:~/kcbench# ./kcbench -s 5.15 -m
[NOTE] Downloading source of Linux 5.15; this might take a while...
Processor:           AMD EPYC 7443P 24-Core Processor [48 CPUs]
Cpufreq; Memory:     performance [acpi-cpufreq]; 515851 MiB
Linux running:       5.13.19-4-pve [x86_64]
Compiler:            gcc (Debian 10.2.1-6) 10.2.1 20210110
Linux compiled:      5.15.0 [/root/.cache/kcbench/linux-5.15]
Run 1 (-j 48):       434.53 seconds / 8.28 kernels/hour [P:4435%, 259906 maj. pagefaults]
Run 2 (-j 48):       434.00 seconds / 8.29 kernels/hour [P:4436%, 259409 maj. pagefaults]
Run 3 (-j 54):       434.67 seconds / 8.28 kernels/hour [P:4466%, 256543 maj. pagefaults]
Run 4 (-j 54):       435.44 seconds / 8.27 kernels/hour [P:4466%, 255991 maj. pagefaults]
Run 5 (-j 24):       553.16 seconds / 6.51 kernels/hour [P:2400%, 268312 maj. pagefaults]
Run 6 (-j 24):       552.05 seconds / 6.52 kernels/hour [P:2399%, 268217 maj. pagefaults]
Run 7 (-j 29):       500.24 seconds / 7.20 kernels/hour [P:2881%, 266347 maj. pagefaults]
Run 8 (-j 29):       500.29 seconds / 7.20 kernels/hour [P:2882%, 266917 maj. pagefaults]
root@pve:~/kcbench# ./kcbenchrate -s 5.15 -m -w 4 -j 32
Linux compiled:      5.15.0 [/root/.cache/kcbench/linux-5.15/]
4 workers completed 4 kernels so far (avrg: 1693.60 s/run) with a rate of 8.50 kernels/hour (each compiling with '-j 32').
4 workers completed 8 kernels so far (avrg: 1692.93 s/run) with a rate of 8.51 kernels/hour (each compiling with '-j 32').
If this question isn’t appropriate for this thread, please let me know. I’m truly curious as to what the end goal of this is? Why would someone need to compile the kernels so quickly and so often? Or is this purely to see just how fast you can make something go? This might be a dumb question but I’m not sure how else to ask it.
its a kind of worst case scenario. If you build some CI/CD infrastructure around an LTS kernel you dont necessarily get to cache intermediate build products, depending on what you’re changing.
So the more load this can handle (either 1 kernel job end to end or X kernel jobs at once) scaling down the time it takes 1 kernel and/or scaling up the # kernels done at once, it fits nicely with a devops system where you
compile kernel, run tests against kernel, report result. You might have several users on your dev team trying different things to see what effect it has. The linux kernel supports modules, but is still monolithic in a lot of respects. So this is an easy way to approximate what the (much more complex in reality) devops workflow is going to be.
ah gotcha. i think that makes sense to my non-devops brain. maybe… :slight_smile: thanks!
I suspected that got drowned out by the middle of the video.
But the key message is depending on your workload (be it CI/CD or application runtime) the “output capacity” changes. I think the most dramatic one (unless i misunderstood) was how the xeon’s out-performed despite having significantly “less cores”
This applies even outside bare metal compute, and applies to cloud computing, for different CPU generations.
While there are some assumptions and guesses u can make. You will not truely know the difference until you have tried it. And that is part of the process.
Kinda how 4Ghz in one cpu != 4Ghz in another, way more complicated - once u add cache hit/misses. It may not matter that much for most smaller scale infra (<32 vCPU), but once you hit the (~>200 vCPU) scale, test and iterating your setup is pretty much something the infra / devops admins needs to be doing. To avoid burning through wasted dollars.
The most direct analogy to kernel compiling, i am guessing would game dev compiling - which i am sure some of those admins would be really glad to have this video haha. :rofl:
ps: Im amused that youtube, caption the “server fan” as “music” - I guess it was right?
I wonder if this workload is hitting memory bandwidth limits.
Without revealing too much, it’s been a thing we’ve started running into and needed to start being mindful of at work on my team, starting at about 88thread broadwell xeons era - where we noticed a performance decrease from Haswell for some workloads. Then, things were better with Skylake xeons, but then things are worse again with recent AMD epycs. (256 threads / 16 channels vs. 112 threads / 12 channels … and the AMD cache topology is not as nice as Skylake 2d mesh). Basically, there’re all these threads that look really good and shiny on paper, but performance goes down significantly as soon as you put decent load on it.
The other thing I’m wondering is whether modern GCC or clang have some “server” mode… where the same process would stay running in the same address space and just handle compiling one translation unit after the other, perhaps by using threads to maximize sharing of memory address space for this.
This would avoid the need for TLB swapping and would maximize the utility of any branch predictors and other micro caches, as they could be reused across sources and shared across threads.
This is on a Bare Metal E4 instance in Oracle cloud, sporting a dual EPYC 7J13 …
[opc@instance-20220407-1950 kcbench]$ kcbench -s 5.15 -m
-bash: kcbench: command not found
[opc@instance-20220407-1950 kcbench]$ bash kcbench -s 5.15 -m
Processor:           AMD EPYC 7J13 64-Core Processor [256 CPUs]
Cpufreq; Memory:     performance [acpi-cpufreq]; 2051469 MiB
Linux running:       5.4.17-2136.304.4.1.el8uek.x86_64 [x86_64]
Compiler:            gcc (GCC) 8.5.0 20210514 (Red Hat 8.5.0-4.0.2)
Linux compiled:      5.15.0 [/home/opc/.cache/kcbench/linux-5.15]
Run 1 (-j 256):      135.56 seconds / 26.56 kernels/hour [P:18139%]
Run 2 (-j 256):      136.38 seconds / 26.40 kernels/hour [P:17599%]
Run 3 (-j 271):      135.05 seconds / 26.66 kernels/hour [P:18295%]
Run 4 (-j 271):      135.87 seconds / 26.50 kernels/hour [P:18309%]
Run 5 (-j 128):      165.52 seconds / 21.75 kernels/hour [P:9075%]
Run 6 (-j 128):      161.27 seconds / 22.32 kernels/hour [P:9399%]
Run 7 (-j 140):      158.91 seconds / 22.65 kernels/hour [P:9828%]
Run 8 (-j 140):      160.73 seconds / 22.40 kernels/hour [P:9656%]
[opc@instance-20220407-1950 kcbench]$ bash kcbenchrate -s 5.15 -m -w 8 -j 32 -o /mnt/kcbench/tmp
Linux compiled:      5.15.0 [/home/opc/.cache/kcbench/linux-5.15/]
8 workers completed 8 kernels so far (avrg: 875.12 s/run) with a rate of 32.91 kernels/hour (each compiling with '-j 32').
8 workers completed 16 kernels so far (avrg: 874.15 s/run) with a rate of 32.95 kernels/hour (each compiling with '-j 32').
about the same as the milan x cpus, interestingly.
Looks like a non-X SKU:
governor was set to performance, all 128 cores clocked at least 3.1Ghz, some turboed at 3.3, ram is 2TB …
And this is on an ARM Ampere Bare Metal machine, 160 cores@3Ghz - 1TB RAM:
[opc@instance-20220407-2309 kcbench]$ bash kcbench -s 5.15 -m
Processor:           Neoverse-N1 [160 CPUs]
Cpufreq; Memory:     performance [cppc_cpufreq]; 1044607 MiB
Linux running:       5.4.17-2136.304.4.3.el8uek.aarch64 [aarch64]
Run 1 (-j 160):      198.16 seconds / 18.17 kernels/hour [P:10477%]
Run 2 (-j 160):      205.45 seconds / 17.52 kernels/hour [P:10065%]
Run 3 (-j 172):      207.74 seconds / 17.33 kernels/hour [P:9999%]
Run 4 (-j 172):      207.15 seconds / 17.38 kernels/hour [P:10007%]
The ARM architecture sure has come a very long way …
I wouldn’t say it underestimates if you just have 1 kernel to compile at the time, if the workload can be split up into bits I’ve found 1 per numa is where it’s at, so 4 jobs per socket on 64c epycs. I’ve seen 100% speed increase going from 256 threads on one task vs 8 tasks confined to each Numas thread and memory. Not sure how Numa optimized these benches are but I am sure you could improve these numbers quite a bit.
here are the numbers
-j 256 24 kernels/h
-w 8 -j 32 31.5 kernels/h
-w 1 -j 32 40kernels/hour if you run 8 instances with Numactl cpubind and membind
kcbench -s 5.15 -m
Processor:           AMD Eng Sample: 100-000000053-04_32/20_N [256 CPUs]
Cpufreq; Memory:     performance [acpi-cpufreq]; 386557 MiB
Linux running:       5.16.0-051600rc3-generic [x86_64]
Compiler:            gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0
Linux compiled:      5.15.0 [/home/epyc/.cache/kcbench/linux-5.15/]
Run 1 (-j 256):      147.93 seconds / 24.34 kernels/hour [P:18173%, 18675 maj. pagefaults]
Run 2 (-j 256):      147.08 seconds / 24.48 kernels/hour [P:18286%, 18662 maj. pagefaults
8 workers completed 8 kernels so far (avrg: 913.26 s/run) with a rate of 31.54 kernels/hour (each compiling with '-j 32')
numactl --cpubind=0 --membind=0 bash kcbenchrate -s 5.15 -m -w 1 -j 32
Starting 1 workers (each compiling with '-j 32'): . All launched, starting to measure.
1 workers completed 1 kernels so far (avrg: 709.44 s/run) with a rate of 5.07 kernels/hour (each compiling with '-j 32')
