Any Kaveri OC Guide out?
wouldnt it just be like a regular cpu? I think that the gpu core clock is locked though.
pretty much do it like the piledrive, the CPU side has the same exact architecture as bulldozer and piledriver, just adjustments on the fetch strings.
http://sites.amd.com/us/Documents/AMD_FX_Performance_Tuning_Guide.pdf
that should help, it may differ a little bit but the methodology is pretty much the same. The GPU core can't be adjusted directly but you can do a workaround by focusing your overclocking through the FSB over multipliers and it will benefit the RAM,CPU, GPU all at the same time.
