Jellyfin seems to keep on restarting
Solved
A newer version of Podman solved the issue.
I’m trying to figure out why my Jellyfin (Podman container) keeps on killing itself:
My server has the following specs:
Ubuntu Server 22.04
Ryzen 7 5700G
32GB RAM
podman version 3.4.4
$ cat .config/systemd/user/container-jellyfin.service
# container-jellyfin.service
# autogenerated by Podman 3.4.4
# Tue Sep  5 04:02:15 UTC 2023
[Unit]
Description=Podman container-jellyfin.service
Documentation=man:podman-generate-systemd(1)
Wants=network-online.target
After=network-online.target
RequiresMountsFor=/run/user/1001/containers
[Service]
Environment=PODMAN_SYSTEMD_UNIT=%n
Restart=on-failure
TimeoutStopSec=70
ExecStart=/usr/bin/podman run \
 --detach \
 --label "io.containers.autoupdate=registry" \
 --name jellyfin \
 --publish 8096:8096/tcp \
 --rm \
 --userns keep-id \
 --volume /opt/podvol/jellyfin/cache:/cache \
 --volume /opt/podvol/jellyfin/config:/config \
 --mount type=bind,source=/media,destination=/media,ro=false \
 docker.io/jellyfin/jellyfin:latest
#ExecStart=/usr/bin/podman start jellyfin
#ExecStop=/usr/bin/podman stop -t 10 jellyfin
#ExecStopPost=/usr/bin/podman stop -t 10 jellyfin
PIDFile=/run/user/1001/containers/overlay-containers/77fcf9ad0639aea929779484611c7b5c04c0b0aad3d82a314bcba0f9eb55642b/userdata/conmon.pid
Type=forking
[Install]
WantedBy=default.target
jellyfin@skarletsky:~$ podman -v
$ podman logs --tail 50 --follow --timestamps jellyfin
2023-09-05T06:12:45.962653000Z [06:12:45] [INF] [1] Main: Jellyfin version: 10.8.10
2023-09-05T06:12:45.967677000Z [06:12:45] [INF] [1] Main: Environment Variables: ["[DOTNET_SYSTEM_GLOBALIZATION_INVARIANT, 1]", "[JELLYFIN_FFMPEG, /usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_CONFIG_DIR, /config/config]", "[JELLYFIN_DATA_DIR, /config]", "[JELLYFIN_CACHE_DIR, /cache]", "[JELLYFIN_WEB_DIR, /jellyfin/jellyfin-web]", "[JELLYFIN_LOG_DIR, /config/log]"]
2023-09-05T06:12:45.967744000Z [06:12:45] [INF] [1] Main: Arguments: ["/jellyfin/jellyfin.dll"]
2023-09-05T06:12:45.968232000Z [06:12:45] [INF] [1] Main: Operating system: Linux
2023-09-05T06:12:45.968582000Z [06:12:45] [INF] [1] Main: Architecture: X64
2023-09-05T06:12:45.968621000Z [06:12:45] [INF] [1] Main: 64-Bit Process: True
2023-09-05T06:12:45.968655000Z [06:12:45] [INF] [1] Main: User Interactive: True
2023-09-05T06:12:45.968689000Z [06:12:45] [INF] [1] Main: Processor count: 16
2023-09-05T06:12:45.968719000Z [06:12:45] [INF] [1] Main: Program data path: /config
2023-09-05T06:12:45.968749000Z [06:12:45] [INF] [1] Main: Web resources path: /jellyfin/jellyfin-web
2023-09-05T06:12:45.968779000Z [06:12:45] [INF] [1] Main: Application directory: /jellyfin/
2023-09-05T06:12:46.084862000Z [06:12:46] [INF] [1] Emby.Server.Implementations.AppBase.BaseConfigurationManager: Setting cache path: /cache
2023-09-05T06:12:46.094399000Z [06:12:46] [INF] [1] Emby.Server.Implementations.ApplicationHost: Loading assemblies
2023-09-05T06:12:46.138065000Z [06:12:46] [ERR] [1] Jellyfin.Networking.Manager.NetworkManager: No interfaces information available. Resolving DNS name.
2023-09-05T06:12:46.145114000Z [06:12:46] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN addresses : [10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]
2023-09-05T06:12:46.145176000Z [06:12:46] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN exclusions : []
2023-09-05T06:12:46.145544000Z [06:12:46] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using LAN addresses: [10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]
2023-09-05T06:12:46.151068000Z [06:12:46] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind addresses: []
2023-09-05T06:12:46.151109000Z [06:12:46] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind exclusions: []
2023-09-05T06:12:47.587009000Z [06:12:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: TMDb 10.8.10.0
2023-09-05T06:12:47.587420000Z [06:12:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: Studio Images 10.8.10.0
2023-09-05T06:12:47.587574000Z [06:12:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: OMDb 10.8.10.0
2023-09-05T06:12:47.587725000Z [06:12:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: MusicBrainz 10.8.10.0
2023-09-05T06:12:47.587869000Z [06:12:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: AudioDB 10.8.10.0
2023-09-05T06:12:47.619982000Z [06:12:47] [INF] [1] Main: Kestrel listening on Any IP4 Address
2023-09-05T06:12:47.651045000Z [06:12:47] [WRN] [1] Microsoft.AspNetCore.DataProtection.Repositories.EphemeralXmlRepository: Using an in-memory repository. Keys will not be persisted to storage.
2023-09-05T06:12:47.651314000Z [06:12:47] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: Neither user profile nor HKLM registry available. Using an ephemeral key repository. Protected data will be unavailable when application exits.
2023-09-05T06:12:47.816602000Z [06:12:47] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: No XML encryptor configured. Key {38bdc876-2f52-49a1-ae88-75ad14ebf0a7} may be persisted to storage in unencrypted form.
2023-09-05T06:12:47.828809000Z [06:12:47] [INF] [1] Emby.Server.Implementations.ApplicationHost: Running startup tasks
2023-09-05T06:12:47.845608000Z [06:12:47] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for Extract Chapter Images set to fire at 2023-09-06 02:00:00.000 +00:00, which is 19:47:12.1546924 from now.
2023-09-05T06:12:47.890924000Z [06:12:47] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Found ffmpeg version 5.1.3
2023-09-05T06:12:47.917348000Z [06:12:47] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available decoders: ["libdav1d", "av1", "av1_cuvid", "av1_qsv", "h264", "h264_qsv", "h264_cuvid", "hevc", "hevc_qsv", "hevc_cuvid", "mpeg2video", "mpeg2_qsv", "mpeg2_cuvid", "mpeg4", "mpeg4_cuvid", "msmpeg4", "vc1_qsv", "vc1_cuvid", "vp8", "libvpx", "vp8_cuvid", "vp8_qsv", "vp9", "libvpx-vp9", "vp9_cuvid", "vp9_qsv", "aac", "ac3", "dca", "flac", "mp3", "truehd"]
2023-09-05T06:12:47.935018000Z [06:12:47] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available encoders: ["libx264", "h264_amf", "h264_nvenc", "h264_qsv", "h264_v4l2m2m", "h264_vaapi", "libx265", "hevc_amf", "hevc_nvenc", "hevc_qsv", "hevc_vaapi", "mpeg4", "msmpeg4", "libvpx", "libvpx-vp9", "aac", "libfdk_aac", "ac3", "dca", "flac", "libmp3lame", "libopus", "truehd", "libvorbis", "srt"]
2023-09-05T06:12:47.952698000Z [06:12:47] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available filters: ["deinterlace_qsv", "deinterlace_vaapi", "hwupload_cuda", "hwupload_vaapi", "overlay_opencl", "overlay_qsv", "overlay_vaapi", "overlay_cuda", "procamp_vaapi", "scale_cuda", "scale_opencl", "scale_qsv", "scale_vaapi", "tonemap_cuda", "tonemap_opencl", "tonemap_vaapi", "vpp_qsv", "yadif_cuda", "zscale", "alphasrc"]
2023-09-05T06:12:48.049279000Z [06:12:48] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available hwaccel types: ["cuda", "vaapi", "qsv", "drm", "opencl", "vulkan"]
2023-09-05T06:12:48.128069000Z [06:12:48] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: FFmpeg: /usr/lib/jellyfin-ffmpeg/ffmpeg
2023-09-05T06:12:48.128658000Z [06:12:48] [INF] [1] Emby.Server.Implementations.ApplicationHost: ServerId: 0f138af22ef047dab62b8dc4e4ea5a88
2023-09-05T06:12:48.210891000Z [06:12:48] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all pre-startup entry points in 0:00:00.0673957
2023-09-05T06:12:48.211020000Z [06:12:48] [INF] [1] Emby.Server.Implementations.ApplicationHost: Core startup complete
2023-09-05T06:12:48.312471000Z [06:12:48] [INF] [15] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /media/DATA/SHARED/Videos/Movies
2023-09-05T06:12:48.313134000Z [06:12:48] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all post-startup entry points in 0:00:00.1021734
2023-09-05T06:12:48.313206000Z [06:12:48] [INF] [1] Main: Startup complete 0:00:02.4701886
2023-09-05T06:12:48.315247000Z [06:12:48] [INF] [11] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /media/DATA/SHARED/Videos/Anime
2023-09-05T06:12:48.320562000Z [06:12:48] [INF] [10] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /media/DATA/SHARED/Videos/TV
2023-09-05T06:12:48.402080000Z [06:12:48] [INF] [13] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /media/DATA/SHARED/Music
2023-09-05T06:12:50.858342000Z [06:12:50] [INF] [13] Emby.Server.Implementations.ScheduledTasks.TaskManager: StartupTrigger fired for task: Update Plugins
2023-09-05T06:12:50.858810000Z [06:12:50] [INF] [13] Emby.Server.Implementations.ScheduledTasks.TaskManager: Queuing task PluginUpdateTask
2023-09-05T06:12:50.860548000Z [06:12:50] [INF] [10] Emby.Server.Implementations.ScheduledTasks.TaskManager: Executing Update Plugins
2023-09-05T06:12:51.154779000Z [06:12:51] [INF] [13] Emby.Server.Implementations.ScheduledTasks.TaskManager: Update Plugins Completed after 0 minute(s) and 0 seconds
2023-09-05T06:12:51.159889000Z [06:12:51] [INF] [13] Emby.Server.Implementations.ScheduledTasks.TaskManager: ExecuteQueuedTasks
2023-09-05T06:13:11.594452000Z [06:13:11] [INF] [26] Emby.Server.Implementations.HttpServer.WebSocketManager: WS 10.0.2.100 request
2023-09-05T06:13:16.271382000Z [06:13:16] [WRN] [19] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'AccessSchedule' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
2023-09-05T06:13:16.271699000Z [06:13:16] [WRN] [19] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'ActivityLog' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
2023-09-05T06:13:16.271766000Z [06:13:16] [WRN] [19] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'CustomItemDisplayPreferences' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
2023-09-05T06:13:16.271818000Z [06:13:16] [WRN] [19] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'DisplayPreferences' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
2023-09-05T06:13:16.271861000Z [06:13:16] [WRN] [19] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'HomeSection' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
2023-09-05T06:13:16.271903000Z [06:13:16] [WRN] [19] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'ImageInfo' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
2023-09-05T06:13:16.271949000Z [06:13:16] [WRN] [19] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'ItemDisplayPreferences' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
2023-09-05T06:13:16.271990000Z [06:13:16] [WRN] [19] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'Permission' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
2023-09-05T06:13:16.272029000Z [06:13:16] [WRN] [19] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'Preference' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
2023-09-05T06:13:16.272069000Z [06:13:16] [WRN] [19] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'ApiKey' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
2023-09-05T06:13:16.272110000Z [06:13:16] [WRN] [19] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'Device' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
2023-09-05T06:13:16.272153000Z [06:13:16] [WRN] [19] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'DeviceOptions' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
2023-09-05T06:13:16.272193000Z [06:13:16] [WRN] [19] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'User' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
2023-09-05T06:13:59.634391000Z [06:13:59] [INF] [29] Emby.Server.Implementations.Session.SessionWebSocketListener: Sending ForceKeepAlive message to 1 inactive WebSockets.
2023-09-05T06:14:11.636065000Z [06:14:11] [INF] [30] Emby.Server.Implementations.Session.SessionWebSocketListener: Lost 1 WebSockets.
2023-09-05T06:14:15.928167000Z [06:14:15] [INF] [2] Main: Received a SIGTERM signal, shutting down
2023-09-05T06:14:15.928762000Z [06:14:15] [INF] [2] Main: Running query planner optimizations in the database... This might take a while
2023-09-05T06:14:15.936628000Z [06:14:15] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing CoreAppHost
2023-09-05T06:14:15.937428000Z [06:14:15] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing RecordingNotifier
2023-09-05T06:14:15.938691000Z [06:14:15] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing MusicBrainzAlbumProvider
2023-09-05T06:14:15.938900000Z [06:14:15] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing ExternalPortForwarding
2023-09-05T06:14:15.939653000Z [06:14:15] [INF] [2] Emby.Server.Implementations.EntryPoints.ExternalPortForwarding: Stopping NAT discovery
2023-09-05T06:14:15.942619000Z [06:14:15] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing DeviceAccessEntryPoint
2023-09-05T06:14:15.942709000Z [06:14:15] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing NotificationEntryPoint
2023-09-05T06:14:15.943754000Z [06:14:15] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing UserDataChangeNotifier
2023-09-05T06:14:15.944194000Z [06:14:15] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing UdpServerEntryPoint
2023-09-05T06:14:15.944483000Z [06:14:15] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing EmbyTV
2023-09-05T06:14:15.945411000Z [06:14:15] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing DlnaEntryPoint
2023-09-05T06:14:15.945928000Z [06:14:15] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing PlayToManager
2023-09-05T06:14:15.946659000Z [06:14:15] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing DeviceDiscovery
2023-09-05T06:14:15.947339000Z [06:14:15] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing SsdpCommunicationsServer
2023-09-05T06:14:15.947659000Z [06:14:15] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: SsdpCommunicationsServer disposing _BroadcastListenSocket
2023-09-05T06:14:15.948985000Z [06:14:15] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: SsdpCommunicationsServer Disposing 3 sendSockets
2023-09-05T06:14:15.949098000Z [06:14:15] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: SsdpCommunicationsServer disposing sendSocket from 0.0.0.0
2023-09-05T06:14:15.949184000Z [06:14:15] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: SsdpCommunicationsServer disposing sendSocket from 10.0.2.100
2023-09-05T06:14:15.949448000Z [06:14:15] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: SsdpCommunicationsServer disposing sendSocket from 127.0.0.1
2023-09-05T06:14:15.949511000Z [06:14:15] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing EntryPoint
2023-09-05T06:14:15.949570000Z [06:14:15] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing EntryPoint
2023-09-05T06:14:15.949626000Z [06:14:15] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing LibraryMonitorStartup
2023-09-05T06:14:15.949687000Z [06:14:15] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing LibraryChangedNotifier
2023-09-05T06:14:15.950884000Z [06:14:15] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing SchedulesDirect
Can’t seem to stay up for more than a minute…
I also tried to comment out the docker run ExecStart, and uncomment docker start ExecStart line + this config:
$ cat .config/containers.old/systemd/jellyfin.container
[Container]
Image=docker.io/jellyfin/jellyfin:latest
Label=io.containers.autoupdate=registry
PublishPort=8096:8096/tcp
RemapUsers=keep-id
Volume=/opt/podvol/jellyfin/config:/config
Volume=/opt/podvol/jellyfin/cache:/cache
Volume=/media:/media
[Service]
# Inform systemd of additional exit status
SuccessExitStatus=0 143
[Install]
# Start by default on boot
Same issue, but only this time, it didn’t come back.
Does it keep running if you start it manually (not via systemd)?
I’ll give that a go overnight and will keep you posted
So far…so good.
I wonder why it kept crashing…?
Without posting JellyFin logs and all of Ubuntu Server’s logs no one will be able to figure out why JellyFin kept crashing.
It might be because you specified TimeoutStopSec without an ExecStop based off the wording in the documentation. Jellyfin is receiving a SIGTERM signal which coincides with what the documentation says and the timing is close to what you have configured. https://www.freedesktop.org/software/systemd/man/systemd.service.html#TimeoutStopSec=
Yeah, if it keeps running when started manually I’d look at the systemd unit file settings.
I also tried unquoting ExecStop, but no dice
From journal:
Sep 07 01:34:56 skarletsky conmon[9132]: [01:34:56] [INF] [11] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /media/DATA/SHARED/Videos/TV
Sep 07 01:34:56 skarletsky conmon[9132]: [01:34:56] [INF] [13] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /media/DATA/SHARED/Videos/Anime
Sep 07 01:34:56 skarletsky conmon[9132]: [01:34:56] [INF] [15] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /media/DATA/SHARED/Music
Sep 07 01:34:59 skarletsky conmon[9132]: [01:34:59] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: StartupTrigger fired for task: Update Plugins
Sep 07 01:34:59 skarletsky conmon[9132]: [01:34:59] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: Queuing task PluginUpdateTask
Sep 07 01:34:59 skarletsky conmon[9132]: [01:34:59] [INF] [13] Emby.Server.Implementations.ScheduledTasks.TaskManager: Executing Update Plugins
Sep 07 01:34:59 skarletsky conmon[9132]: [01:34:59] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: Update Plugins Completed after 0 minute(s) and 0 seconds
Sep 07 01:34:59 skarletsky conmon[9132]: [01:34:59] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: ExecuteQueuedTasks
Sep 07 01:35:01 skarletsky systemd[1032]: Started podman-9360.scope.
Sep 07 01:35:06 skarletsky systemd[1032]: Started podman-9419.scope.
Sep 07 01:35:11 skarletsky systemd[1032]: Started podman-9474.scope.
Sep 07 01:35:16 skarletsky systemd[1032]: Started podman-9528.scope.
Sep 07 01:35:21 skarletsky systemd[1032]: Started podman-9581.scope.
Sep 07 01:35:24 skarletsky systemd[1032]: Started /usr/bin/podman healthcheck run a8c77734136d45036521bac3d7b8619e8f860969bad7db39dbf36c4bb8a48b04.
Sep 07 01:35:24 skarletsky podman[9631]: 2023-09-07 01:35:24.608038195 +0000 UTC m=+0.028682853 container exec a8c77734136d45036521bac3d7b8619e8f860969bad7db39dbf36c4bb8a48b04 (image=docker.io/jellyfin/jellyfin:latest, name=jellyfin, io.containers.autoupdate=registry, PODMAN_SYSTEMD_UNIT=container-jellyfin.service)
Sep 07 01:35:24 skarletsky conmon[9132]: [01:35:24] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'AccessSchedule' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
Sep 07 01:35:24 skarletsky conmon[9132]: [01:35:24] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'ActivityLog' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
Sep 07 01:35:24 skarletsky conmon[9132]: [01:35:24] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'CustomItemDisplayPreferences' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
Sep 07 01:35:24 skarletsky conmon[9132]: [01:35:24] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'DisplayPreferences' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
Sep 07 01:35:24 skarletsky conmon[9132]: [01:35:24] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'HomeSection' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
Sep 07 01:35:24 skarletsky conmon[9132]: [01:35:24] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'ImageInfo' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
Sep 07 01:35:24 skarletsky conmon[9132]: [01:35:24] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'ItemDisplayPreferences' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
Sep 07 01:35:24 skarletsky conmon[9132]: [01:35:24] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'Permission' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
Sep 07 01:35:24 skarletsky conmon[9132]: [01:35:24] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'Preference' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
Sep 07 01:35:24 skarletsky conmon[9132]: [01:35:24] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'ApiKey' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
Sep 07 01:35:24 skarletsky conmon[9132]: [01:35:24] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'Device' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
Sep 07 01:35:24 skarletsky conmon[9132]: [01:35:24] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'DeviceOptions' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
Sep 07 01:35:24 skarletsky conmon[9132]: [01:35:24] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type 'User' is configured to use schema 'jellyfin', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
Sep 07 01:35:24 skarletsky podman[9631]: 2023-09-07 01:35:24.78558 +0000 UTC m=+0.206224648 container exec_died a8c77734136d45036521bac3d7b8619e8f860969bad7db39dbf36c4bb8a48b04 (image=docker.io/jellyfin/jellyfin:latest, name=jellyfin, execID=3188588a6379e936eed9bd6e4df8031557a84713884fb864bfcd3f2da872a1e3)
Sep 07 01:35:26 skarletsky systemd[1032]: Started podman-9686.scope.
Sep 07 01:35:31 skarletsky systemd[1032]: Started podman-9745.scope.
Sep 07 01:35:37 skarletsky systemd[1032]: Started podman-9825.scope.
Sep 07 01:35:42 skarletsky systemd[1032]: Started podman-9878.scope.
Sep 07 01:35:47 skarletsky systemd[1032]: Started podman-9932.scope.
Sep 07 01:35:52 skarletsky systemd[1032]: Started podman-9985.scope.
Sep 07 01:35:55 skarletsky systemd[1032]: Started /usr/bin/podman healthcheck run a8c77734136d45036521bac3d7b8619e8f860969bad7db39dbf36c4bb8a48b04.
Sep 07 01:35:55 skarletsky podman[10034]: 2023-09-07 01:35:55.600628499 +0000 UTC m=+0.029099190 container exec a8c77734136d45036521bac3d7b8619e8f860969bad7db39dbf36c4bb8a48b04 (image=docker.io/jellyfin/jellyfin:latest, name=jellyfin, PODMAN_SYSTEMD_UNIT=container-jellyfin.service, io.containers.autoupdate=registry)
Sep 07 01:35:55 skarletsky podman[10034]: 2023-09-07 01:35:55.611797653 +0000 UTC m=+0.040268344 container exec_died a8c77734136d45036521bac3d7b8619e8f860969bad7db39dbf36c4bb8a48b04 (image=docker.io/jellyfin/jellyfin:latest, name=jellyfin, execID=29102b357713c60a1b1a684efd3db320dfe0da4611be3d3874ddcc311c74662b)
Sep 07 01:35:57 skarletsky systemd[1032]: Started podman-10095.scope.
Sep 07 01:36:02 skarletsky systemd[1032]: Started podman-10156.scope.
Sep 07 01:36:07 skarletsky systemd[1032]: Started podman-10295.scope.
Sep 07 01:36:12 skarletsky systemd[1032]: Started podman-10348.scope.
Sep 07 01:36:18 skarletsky systemd[1032]: Started podman-10402.scope.
Sep 07 01:36:23 skarletsky systemd[1032]: Started podman-10454.scope.
Sep 07 01:36:23 skarletsky systemd[1032]: container-jellyfin.service: start operation timed out. Terminating.
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Main: Received a SIGTERM signal, shutting down
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Main: Running query planner optimizations in the database... This might take a while
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing CoreAppHost
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing ExternalPortForwarding
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Server.Implementations.EntryPoints.ExternalPortForwarding: Stopping NAT discovery
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing LibraryChangedNotifier
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing DlnaEntryPoint
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing PlayToManager
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing DeviceDiscovery
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing SsdpCommunicationsServer
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: SsdpCommunicationsServer disposing _BroadcastListenSocket
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: SsdpCommunicationsServer Disposing 3 sendSockets
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: SsdpCommunicationsServer disposing sendSocket from 0.0.0.0
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: SsdpCommunicationsServer disposing sendSocket from 10.0.2.100
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: SsdpCommunicationsServer disposing sendSocket from 127.0.0.1
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing UdpServerEntryPoint
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing MusicBrainzAlbumProvider
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing RecordingNotifier
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing EntryPoint
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing SchedulesDirect
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing LibraryMonitorStartup
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing NotificationEntryPoint
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing EmbyTV
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing DeviceAccessEntryPoint
Sep 07 01:36:23 skarletsky conmon[9132]: [01:36:23] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing UserDataChangeNotifier
Sep 07 01:36:23 skarletsky systemd[1032]: libpod-a8c77734136d45036521bac3d7b8619e8f860969bad7db39dbf36c4bb8a48b04.scope: Consumed 4.439s CPU time.
Sep 07 01:36:23 skarletsky podman[10505]: 2023-09-07 01:36:23.958450184 +0000 UTC m=+0.020666180 container died a8c77734136d45036521bac3d7b8619e8f860969bad7db39dbf36c4bb8a48b04 (image=docker.io/jellyfin/jellyfin:latest, name=jellyfin)
Sep 07 01:36:23 skarletsky systemd[1032]: Stopped /usr/bin/podman healthcheck run a8c77734136d45036521bac3d7b8619e8f860969bad7db39dbf36c4bb8a48b04.
Sep 07 01:36:23 skarletsky podman[10505]: 2023-09-07 01:36:23.971171522 +0000 UTC m=+0.033387518 container remove a8c77734136d45036521bac3d7b8619e8f860969bad7db39dbf36c4bb8a48b04 (image=docker.io/jellyfin/jellyfin:latest, name=jellyfin, io.containers.autoupdate=registry, PODMAN_SYSTEMD_UNIT=container-jellyfin.service)
Sep 07 01:36:24 skarletsky podman[10552]: Error: no container with name or ID "jellyfin" found: no such container
Sep 07 01:36:24 skarletsky systemd[1032]: container-jellyfin.service: Control process exited, code=exited, status=125/n/a
Sep 07 01:36:24 skarletsky systemd[1032]: container-jellyfin.service: Failed with result 'timeout'.
Sep 07 01:36:24 skarletsky systemd[1032]: Failed to start Podman container-jellyfin.service.
Sep 07 01:36:24 skarletsky systemd[1032]: container-jellyfin.service: Scheduled restart job, restart counter is at 3.
Sep 07 01:36:24 skarletsky systemd[1032]: Stopped Podman container-jellyfin.service.
Sep 07 01:36:24 skarletsky systemd[1032]: Starting Podman container-jellyfin.service...
Sep 07 01:36:24 skarletsky podman[10593]:
Sep 07 01:36:24 skarletsky podman[10593]: 2023-09-07 01:36:24.349732212 +0000 UTC m=+0.030484995 container create 6557b6a8f6687ea70310007c576354f0a59460341b811d6b3f5a0877cbd69f13 (image=docker.io/jellyfin/jellyfin:latest, name=jellyfin, PODMAN_SYSTEMD_UNIT=container-jellyfin.service, io.containers.autoupdate=registry)
Sep 07 01:36:24 skarletsky kernel: overlayfs: fs on '/home/.jellyfin/.local/share/containers/storage/overlay/l/QDALCZ77EANPWW7UPHRXJQ6ZMJ' does not support file handles, falling back to xino=off.
Sep 07 01:36:24 skarletsky systemd[1032]: Started libcrun container.
Sep 07 01:36:24 skarletsky systemd[1032]: Started /usr/bin/podman healthcheck run 6557b6a8f6687ea70310007c576354f0a59460341b811d6b3f5a0877cbd69f13.
Sep 07 01:36:24 skarletsky podman[10593]: 2023-09-07 01:36:24.399024092 +0000 UTC m=+0.079776905 container init 6557b6a8f6687ea70310007c576354f0a59460341b811d6b3f5a0877cbd69f13 (image=docker.io/jellyfin/jellyfin:latest, name=jellyfin, PODMAN_SYSTEMD_UNIT=container-jellyfin.service, io.containers.autoupdate=registry)
Sep 07 01:36:24 skarletsky podman[10593]: 2023-09-07 01:36:24.403676789 +0000 UTC m=+0.084429582 container start 6557b6a8f6687ea70310007c576354f0a59460341b811d6b3f5a0877cbd69f13 (image=docker.io/jellyfin/jellyfin:latest, name=jellyfin, io.containers.autoupdate=registry, PODMAN_SYSTEMD_UNIT=container-jellyfin.service)
Sep 07 01:36:24 skarletsky podman[10593]: 6557b6a8f6687ea70310007c576354f0a59460341b811d6b3f5a0877cbd69f13
Sep 07 01:36:24 skarletsky audit[10644]: SECCOMP auid=1001 uid=1001 gid=1001 ses=1 subj=unconfined pid=10644 comm="jellyfin" exe="/jellyfin/jellyfin" sig=0 arch=c000003e syscall=324 compat=0 ip=0x7f0d51c732e9 code=0x50000
Sep 07 01:36:24 skarletsky kernel: audit: type=1326 audit(1694050584.404:73): auid=1001 uid=1001 gid=1001 ses=1 subj=unconfined pid=10644 comm="jellyfin" exe="/jellyfin/jellyfin" sig=0 arch=c000003e syscall=324 compat=0 ip=0x7f0d51c732e9 code=0x50000
Sep 07 01:36:24 skarletsky podman[10593]: 2023-09-07 01:36:24.337494326 +0000 UTC m=+0.018247129 image pull  docker.io/jellyfin/jellyfin:latest
Sep 07 01:36:24 skarletsky systemd[1032]: container-jellyfin.service: Can't open PID file /run/user/1001/containers/overlay-containers/e18be9e055369e62b96cccaa89d15215f54f0f3914839921392eb35bae12e72e/userdata/conmon.pid (yet?) after start: Operation not permitted
Sep 07 01:36:24 skarletsky podman[10680]: 2023-09-07 01:36:24.435130625 +0000 UTC m=+0.029529139 container exec 6557b6a8f6687ea70310007c576354f0a59460341b811d6b3f5a0877cbd69f13 (image=docker.io/jellyfin/jellyfin:latest, name=jellyfin, PODMAN_SYSTEMD_UNIT=container-jellyfin.service, io.containers.autoupdate=registry)
Sep 07 01:36:24 skarletsky podman[10680]: 2023-09-07 01:36:24.440313923 +0000 UTC m=+0.034712437 container exec_died 6557b6a8f6687ea70310007c576354f0a59460341b811d6b3f5a0877cbd69f13 (image=docker.io/jellyfin/jellyfin:latest, name=jellyfin, execID=ee5520e360abf376392b2941531876e72391e511bdb964b37eb12e258e89aed9)
Sep 07 01:36:24 skarletsky podman[10680]: unhealthy
Sep 07 01:36:24 skarletsky systemd[1032]: 6557b6a8f6687ea70310007c576354f0a59460341b811d6b3f5a0877cbd69f13.service: Main process exited, code=exited, status=1/FAILURE
Sep 07 01:36:24 skarletsky systemd[1032]: 6557b6a8f6687ea70310007c576354f0a59460341b811d6b3f5a0877cbd69f13.service: Failed with result 'exit-code'.
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Main: Jellyfin version: 10.8.10
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Main: Environment Variables: ["[JELLYFIN_FFMPEG, /usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_WEB_DIR, /jellyfin/jellyfin-web]", "[DOTNET_SYSTEM_GLOBALIZATION_INVARIANT, 1]", "[JELLYFIN_DATA_DIR, /config]", "[JELLYFIN_CONFIG_DIR, /config/config]", "[JELLYFIN_LOG_DIR, /config/log]", "[JELLYFIN_CACHE_DIR, /cache]"]
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Main: Arguments: ["/jellyfin/jellyfin.dll"]
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Main: Operating system: Linux
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Main: Architecture: X64
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Main: 64-Bit Process: True
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Main: User Interactive: True
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Main: Processor count: 16
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Main: Program data path: /config
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Main: Web resources path: /jellyfin/jellyfin-web
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Main: Application directory: /jellyfin/
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Emby.Server.Implementations.AppBase.BaseConfigurationManager: Setting cache path: /cache
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Emby.Server.Implementations.ApplicationHost: Loading assemblies
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [ERR] [1] Jellyfin.Networking.Manager.NetworkManager: No interfaces information available. Resolving DNS name.
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN addresses : [10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN exclusions : []
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using LAN addresses: [10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind addresses: []
Sep 07 01:36:24 skarletsky conmon[10640]: [01:36:24] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind exclusions: []
Sep 07 01:36:26 skarletsky conmon[10640]: [01:36:26] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: TMDb 10.8.10.0
Sep 07 01:36:26 skarletsky conmon[10640]: [01:36:26] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: Studio Images 10.8.10.0
Sep 07 01:36:26 skarletsky conmon[10640]: [01:36:26] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: OMDb 10.8.10.0
Sep 07 01:36:26 skarletsky conmon[10640]: [01:36:26] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: MusicBrainz 10.8.10.0
Sep 07 01:36:26 skarletsky conmon[10640]: [01:36:26] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: AudioDB 10.8.10.0
Sep 07 01:36:26 skarletsky conmon[10640]: [01:36:26] [INF] [1] Main: Kestrel listening on Any IP4 Address
Sep 07 01:36:26 skarletsky conmon[10640]: [01:36:26] [WRN] [1] Microsoft.AspNetCore.DataProtection.Repositories.EphemeralXmlRepository: Using an in-memory repository. Keys will not be persisted to storage.
Sep 07 01:36:26 skarletsky conmon[10640]: [01:36:26] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: Neither user profile nor HKLM registry available. Using an ephemeral key repository. Protected data will be unavailable when application exits.
Sep 07 01:36:26 skarletsky conmon[10640]: [01:36:26] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: No XML encryptor configured. Key {4a1eddf6-d80c-48d0-a3e6-5f9a5798ea42} may be persisted to storage in unencrypted form.
Sep 07 01:36:26 skarletsky conmon[10640]: [01:36:26] [INF] [1] Emby.Server.Implementations.ApplicationHost: Running startup tasks
Sep 07 01:36:26 skarletsky conmon[10640]: [01:36:26] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for Extract Chapter Images set to fire at 2023-09-07 02:00:00.000 +00:00, which is 00:23:33.1551502 from now.
Sep 07 01:36:26 skarletsky conmon[10640]: [01:36:26] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Found ffmpeg version 5.1.3
Sep 07 01:36:26 skarletsky conmon[10640]: [01:36:26] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available decoders: ["libdav1d", "av1", "av1_cuvid", "av1_qsv", "h264", "h264_qsv", "h264_cuvid", "hevc", "hevc_qsv", "hevc_cuvid", "mpeg2video", "mpeg2_qsv", "mpeg2_cuvid", "mpeg4", "mpeg4_cuvid", "msmpeg4", "vc1_qsv", "vc1_cuvid", "vp8", "libvpx", "vp8_cuvid", "vp8_qsv", "vp9", "libvpx-vp9", "vp9_cuvid", "vp9_qsv", "aac", "ac3", "dca", "flac", "mp3", "truehd"]
Sep 07 01:36:26 skarletsky conmon[10640]: [01:36:26] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available encoders: ["libx264", "h264_amf", "h264_nvenc", "h264_qsv", "h264_v4l2m2m", "h264_vaapi", "libx265", "hevc_amf", "hevc_nvenc", "hevc_qsv", "hevc_vaapi", "mpeg4", "msmpeg4", "libvpx", "libvpx-vp9", "aac", "libfdk_aac", "ac3", "dca", "flac", "libmp3lame", "libopus", "truehd", "libvorbis", "srt"]
Sep 07 01:36:26 skarletsky conmon[10640]: [01:36:26] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available filters: ["deinterlace_qsv", "deinterlace_vaapi", "hwupload_cuda", "hwupload_vaapi", "overlay_opencl", "overlay_qsv", "overlay_vaapi", "overlay_cuda", "procamp_vaapi", "scale_cuda", "scale_opencl", "scale_qsv", "scale_vaapi", "tonemap_cuda", "tonemap_opencl", "tonemap_vaapi", "vpp_qsv", "yadif_cuda", "zscale", "alphasrc"]
Sep 07 01:36:27 skarletsky conmon[10640]: [01:36:27] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available hwaccel types: ["cuda", "vaapi", "qsv", "drm", "opencl", "vulkan"]
Sep 07 01:36:27 skarletsky conmon[10640]: [01:36:27] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: FFmpeg: /usr/lib/jellyfin-ffmpeg/ffmpeg
Sep 07 01:36:27 skarletsky conmon[10640]: [01:36:27] [INF] [1] Emby.Server.Implementations.ApplicationHost: ServerId: 0f138af22ef047dab62b8dc4e4ea5a88
Sep 07 01:36:27 skarletsky conmon[10640]: [01:36:27] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all pre-startup entry points in 0:00:00.0681177
Sep 07 01:36:27 skarletsky conmon[10640]: [01:36:27] [INF] [1] Emby.Server.Implementations.ApplicationHost: Core startup complete
Sep 07 01:36:27 skarletsky conmon[10640]: [01:36:27] [INF] [10] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /media/DATA/SHARED/Videos/Movies
Sep 07 01:36:27 skarletsky conmon[10640]: [01:36:27] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all post-startup entry points in 0:00:00.0995339
Sep 07 01:36:27 skarletsky conmon[10640]: [01:36:27] [INF] [1] Main: Startup complete 0:00:02.8332103
Sep 07 01:36:27 skarletsky conmon[10640]: [01:36:27] [INF] [13] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /media/DATA/SHARED/Videos/Anime
Sep 07 01:36:27 skarletsky conmon[10640]: [01:36:27] [INF] [8] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /media/DATA/SHARED/Videos/TV
Sep 07 01:36:27 skarletsky conmon[10640]: [01:36:27] [INF] [15] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /media/DATA/SHARED/Music
Sep 07 01:36:28 skarletsky systemd[1032]: Started podman-10811.scope.
Sep 07 01:36:29 skarletsky conmon[10640]: [01:36:29] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: StartupTrigger fired for task: Update Plugins
Sep 07 01:36:29 skarletsky conmon[10640]: [01:36:29] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: Queuing task PluginUpdateTask
Sep 07 01:36:29 skarletsky conmon[10640]: [01:36:29] [INF] [8] Emby.Server.Implementations.ScheduledTasks.TaskManager: Executing Update Plugins
Sep 07 01:36:30 skarletsky conmon[10640]: [01:36:30] [INF] [19] Emby.Server.Implementations.ScheduledTasks.TaskManager: Update Plugins Completed after 0 minute(s) and 0 seconds
Sep 07 01:36:30 skarletsky conmon[10640]: [01:36:30] [INF] [19] Emby.Server.Implementations.ScheduledTasks.TaskManager: ExecuteQueuedTasks
From Jellyfin:
[2023-09-07 00:43:11.463 +00:00] [INF] [59] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "10.0.2.100" request
[2023-09-07 01:13:44.151 +00:00] [INF] [49] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "10.0.2.100" closed
[2023-09-07 01:13:44.555 +00:00] [INF] [134] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "10.0.2.100" request
[2023-09-07 01:15:44.533 +00:00] [INF] [105] Jellyfin.Api.Controllers.ItemLookupController: Setting provider id's to item 429992d5-9c19-a535-326a-f5c252270667-"Justice.Society.World.War.II.2021.2160p.UHD.BluRay.x265.10bit.HDR.DTS-HD.MA.5.1-SWTYBLZ": "{\"Tmdb\":\"736069\"}"
[2023-09-07 01:15:59.816 +00:00] [ERR] [50] MediaBrowser.Providers.Manager.ProviderManager: UnauthorizedAccessException - Access to path "/media/DATA/SHARED/Videos/Movies/DC/DC Animated/2021 Justice Society World War II/folder.jpg" is denied. Will retry saving to "/config/metadata/library/42/429992d59c19a535326af5c252270667/poster.jpg"
[2023-09-07 01:15:59.827 +00:00] [ERR] [103] MediaBrowser.Providers.Manager.ProviderManager: UnauthorizedAccessException - Access to path "/media/DATA/SHARED/Videos/Movies/DC/DC Animated/2021 Justice Society World War II/logo.png" is denied. Will retry saving to "/config/metadata/library/42/429992d59c19a535326af5c252270667/logo.png"
[2023-09-07 01:15:59.870 +00:00] [ERR] [50] MediaBrowser.Providers.Manager.ProviderManager: UnauthorizedAccessException - Access to path "/media/DATA/SHARED/Videos/Movies/DC/DC Animated/2021 Justice Society World War II/backdrop.jpg" is denied. Will retry saving to "/config/metadata/library/42/429992d59c19a535326af5c252270667/backdrop.jpg"
[2023-09-07 01:16:00.429 +00:00] [ERR] [38] MediaBrowser.Providers.Manager.ProviderManager: Error in metadata saver
System.UnauthorizedAccessException: Access to the path '/media/DATA/SHARED/Videos/Movies/DC/DC Animated/2021 Justice Society World War II/Justice.Society.World.War.II.2021.2160p.UHD.BluRay.x265.10bit.HDR.DTS-HD.MA.5.1-SWTYBLZ.nfo' is denied.
 ---> System.IO.IOException: Permission denied
   --- End of inner exception stack trace ---
   at Interop.CheckIo(Error error, String path, Boolean isDirectory, Func`2 errorRewriter)
   at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode)
   at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize)
   at System.IO.Strategies.OSFileStreamStrategy..ctor(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize)
   at System.IO.Strategies.FileStreamHelpers.ChooseStrategy(FileStream fileStream, String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, Int64 preallocationSize)
   at System.IO.FileStream..ctor(String path, FileStreamOptions options)
   at MediaBrowser.XbmcMetadata.Savers.BaseNfoSaver.SaveToFileAsync(Stream stream, String path)
   at MediaBrowser.XbmcMetadata.Savers.BaseNfoSaver.SaveAsync(BaseItem item, CancellationToken cancellationToken)
   at MediaBrowser.Providers.Manager.ProviderManager.SaveMetadataAsync(BaseItem item, ItemUpdateType updateType, IEnumerable`1 savers)
[2023-09-07 01:16:00.552 +00:00] [WRN] [38] Jellyfin.Server.Middleware.ResponseTimeMiddleware: Slow HTTP Response from "http://192.168.100.13:8096/Items/RemoteSearch/Apply/429992d59c19a535326af5c252270667?ReplaceAllImages=true" to "10.0.2.100" in 0:00:16.0206691 with Status Code 204
[2023-09-07 01:16:13.795 +00:00] [WRN] [81] Jellyfin.Server.Middleware.ResponseTimeMiddleware: Slow HTTP Response from "http://192.168.100.13:8096/Items/429992d59c19a535326af5c252270667/Images/Backdrop/0?maxWidth=3840&tag=3b3b151868000a2a69e85b91fbf3dd5a&quality=80" to "10.0.2.100" in 0:00:01.0897037 with Status Code 200
[2023-09-07 01:16:46.542 +00:00] [WRN] [57] Jellyfin.Server.Middleware.ResponseTimeMiddleware: Slow HTTP Response from "http://192.168.100.13:8096/Users/83e519405cd648c383181ece9607f4e4/Items?SortBy=SeriesName%2CSortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Episode" to "10.0.2.100" in 0:00:00.6111043 with Status Code 200
[2023-09-07 01:16:46.686 +00:00] [WRN] [88] Jellyfin.Server.Middleware.ResponseTimeMiddleware: Slow HTTP Response from "http://192.168.100.13:8096/Users/83e519405cd648c383181ece9607f4e4/Items?SortBy=SeriesName%2CSortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Series" to "10.0.2.100" in 0:00:00.7554308 with Status Code 200
[2023-09-07 01:24:55.392 +00:00] [INF] [1] Main: Jellyfin version: "10.8.10"
[2023-09-07 01:24:55.405 +00:00] [INF] [1] Main: Environment Variables: ["[JELLYFIN_CONFIG_DIR, /config/config]", "[JELLYFIN_WEB_DIR, /jellyfin/jellyfin-web]", "[JELLYFIN_LOG_DIR, /config/log]", "[JELLYFIN_FFMPEG, /usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_DATA_DIR, /config]", "[JELLYFIN_CACHE_DIR, /cache]", "[DOTNET_SYSTEM_GLOBALIZATION_INVARIANT, 1]"]
[2023-09-07 01:24:55.406 +00:00] [INF] [1] Main: Arguments: ["/jellyfin/jellyfin.dll"]
[2023-09-07 01:24:55.407 +00:00] [INF] [1] Main: Operating system: "Linux"
[2023-09-07 01:24:55.407 +00:00] [INF] [1] Main: Architecture: X64
[2023-09-07 01:24:55.408 +00:00] [INF] [1] Main: 64-Bit Process: True
[2023-09-07 01:24:55.408 +00:00] [INF] [1] Main: User Interactive: True
[2023-09-07 01:24:55.408 +00:00] [INF] [1] Main: Processor count: 16
[2023-09-07 01:24:55.408 +00:00] [INF] [1] Main: Program data path: "/config"
[2023-09-07 01:24:55.408 +00:00] [INF] [1] Main: Web resources path: "/jellyfin/jellyfin-web"
[2023-09-07 01:24:55.408 +00:00] [INF] [1] Main: Application directory: "/jellyfin/"
[2023-09-07 01:24:55.553 +00:00] [INF] [1] Emby.Server.Implementations.AppBase.BaseConfigurationManager: Setting cache path: "/cache"
[2023-09-07 01:24:55.570 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Loading assemblies
[2023-09-07 01:24:55.631 +00:00] [ERR] [1] Jellyfin.Networking.Manager.NetworkManager: No interfaces information available. Resolving DNS name.
[2023-09-07 01:24:55.638 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN addresses : "[10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]"
[2023-09-07 01:24:55.638 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN exclusions : "[]"
[2023-09-07 01:24:55.639 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using LAN addresses: "[10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]"
[2023-09-07 01:24:55.645 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind addresses: "[]"
[2023-09-07 01:24:55.645 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind exclusions: "[]"
[2023-09-07 01:24:59.034 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "TMDb" "10.8.10.0"
[2023-09-07 01:24:59.034 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "Studio Images" "10.8.10.0"
[2023-09-07 01:24:59.034 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "OMDb" "10.8.10.0"
[2023-09-07 01:24:59.034 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "MusicBrainz" "10.8.10.0"
[2023-09-07 01:24:59.034 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "AudioDB" "10.8.10.0"
[2023-09-07 01:24:59.071 +00:00] [INF] [1] Main: Kestrel listening on "Any IP4 Address"
[2023-09-07 01:24:59.110 +00:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.Repositories.EphemeralXmlRepository: Using an in-memory repository. Keys will not be persisted to storage.
[2023-09-07 01:24:59.110 +00:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: Neither user profile nor HKLM registry available. Using an ephemeral key repository. Protected data will be unavailable when application exits.
[2023-09-07 01:24:59.276 +00:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: No XML encryptor configured. Key {8b4ab339-9aee-4d1c-b8c1-fe6087f70bd4} may be persisted to storage in unencrypted form.
[2023-09-07 01:24:59.289 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Running startup tasks
[2023-09-07 01:24:59.316 +00:00] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for "Extract Chapter Images" set to fire at 2023-09-07 02:00:00.000 +00:00, which is 00:35:00.6831479 from now.
[2023-09-07 01:24:59.401 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Found ffmpeg version "5.1.3"
[2023-09-07 01:24:59.432 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available "decoders": ["libdav1d", "av1", "av1_cuvid", "av1_qsv", "h264", "h264_qsv", "h264_cuvid", "hevc", "hevc_qsv", "hevc_cuvid", "mpeg2video", "mpeg2_qsv", "mpeg2_cuvid", "mpeg4", "mpeg4_cuvid", "msmpeg4", "vc1_qsv", "vc1_cuvid", "vp8", "libvpx", "vp8_cuvid", "vp8_qsv", "vp9", "libvpx-vp9", "vp9_cuvid", "vp9_qsv", "aac", "ac3", "dca", "flac", "mp3", "truehd"]
[2023-09-07 01:24:59.451 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available "encoders": ["libx264", "h264_amf", "h264_nvenc", "h264_qsv", "h264_v4l2m2m", "h264_vaapi", "libx265", "hevc_amf", "hevc_nvenc", "hevc_qsv", "hevc_vaapi", "mpeg4", "msmpeg4", "libvpx", "libvpx-vp9", "aac", "libfdk_aac", "ac3", "dca", "flac", "libmp3lame", "libopus", "truehd", "libvorbis", "srt"]
[2023-09-07 01:24:59.469 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available filters: ["deinterlace_qsv", "deinterlace_vaapi", "hwupload_cuda", "hwupload_vaapi", "overlay_opencl", "overlay_qsv", "overlay_vaapi", "overlay_cuda", "procamp_vaapi", "scale_cuda", "scale_opencl", "scale_qsv", "scale_vaapi", "tonemap_cuda", "tonemap_opencl", "tonemap_vaapi", "vpp_qsv", "yadif_cuda", "zscale", "alphasrc"]
[2023-09-07 01:24:59.568 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available hwaccel types: ["cuda", "vaapi", "qsv", "drm", "opencl", "vulkan"]
[2023-09-07 01:24:59.656 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: FFmpeg: "/usr/lib/jellyfin-ffmpeg/ffmpeg"
[2023-09-07 01:24:59.657 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: ServerId: "0f138af22ef047dab62b8dc4e4ea5a88"
[2023-09-07 01:24:59.716 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all pre-startup entry points in 0:00:00.0525741
[2023-09-07 01:24:59.716 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Core startup complete
[2023-09-07 01:25:00.702 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all post-startup entry points in 0:00:00.9861192
[2023-09-07 01:25:00.702 +00:00] [INF] [1] Main: Startup complete 0:00:05.4902397
[2023-09-07 01:25:02.321 +00:00] [INF] [19] Emby.Server.Implementations.ScheduledTasks.TaskManager: "StartupTrigger" fired for task: "Update Plugins"
[2023-09-07 01:25:02.322 +00:00] [INF] [19] Emby.Server.Implementations.ScheduledTasks.TaskManager: Queuing task "PluginUpdateTask"
[2023-09-07 01:25:02.324 +00:00] [INF] [14] Emby.Server.Implementations.ScheduledTasks.TaskManager: Executing "Update Plugins"
[2023-09-07 01:25:02.750 +00:00] [INF] [22] Emby.Server.Implementations.ScheduledTasks.TaskManager: "Update Plugins" Completed after 0 minute(s) and 0 seconds
[2023-09-07 01:25:02.755 +00:00] [INF] [22] Emby.Server.Implementations.ScheduledTasks.TaskManager: ExecuteQueuedTasks
[2023-09-07 01:25:03.962 +00:00] [INF] [14] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "10.0.2.100" request
[2023-09-07 01:25:04.020 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"AccessSchedule"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:25:04.020 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ActivityLog"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:25:04.020 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"CustomItemDisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:25:04.020 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"DisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:25:04.020 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"HomeSection"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:25:04.020 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ImageInfo"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:25:04.020 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ItemDisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:25:04.020 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"Permission"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:25:04.020 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"Preference"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:25:04.020 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ApiKey"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:25:04.020 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"Device"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:25:04.020 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"DeviceOptions"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:25:04.020 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"User"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:25:10.009 +00:00] [INF] [15] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Videos/Movies"
[2023-09-07 01:25:18.149 +00:00] [INF] [10] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Videos/Anime"
[2023-09-07 01:25:18.591 +00:00] [INF] [13] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Videos/TV"
[2023-09-07 01:25:29.140 +00:00] [INF] [11] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Music"
[2023-09-07 01:26:24.924 +00:00] [INF] [2] Main: Received a SIGTERM signal, shutting down
[2023-09-07 01:26:24.925 +00:00] [INF] [2] Main: Running query planner optimizations in the database... This might take a while
[2023-09-07 01:26:24.934 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "CoreAppHost"
[2023-09-07 01:26:24.935 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "ExternalPortForwarding"
[2023-09-07 01:26:24.935 +00:00] [INF] [2] Emby.Server.Implementations.EntryPoints.ExternalPortForwarding: Stopping NAT discovery
[2023-09-07 01:26:24.938 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "LibraryChangedNotifier"
[2023-09-07 01:26:24.940 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "DlnaEntryPoint"
[2023-09-07 01:26:24.941 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing PlayToManager
[2023-09-07 01:26:24.941 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing DeviceDiscovery
[2023-09-07 01:26:24.942 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing SsdpCommunicationsServer
[2023-09-07 01:26:24.942 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing _BroadcastListenSocket
[2023-09-07 01:26:24.944 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" Disposing 3 sendSockets
[2023-09-07 01:26:24.944 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing sendSocket from "0.0.0.0"
[2023-09-07 01:26:24.944 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing sendSocket from "10.0.2.100"
[2023-09-07 01:26:24.944 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing sendSocket from "127.0.0.1"
[2023-09-07 01:26:24.944 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "UdpServerEntryPoint"
[2023-09-07 01:26:24.944 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "MusicBrainzAlbumProvider"
[2023-09-07 01:26:24.944 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "RecordingNotifier"
[2023-09-07 01:26:24.945 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "EntryPoint"
[2023-09-07 01:26:24.945 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "SchedulesDirect"
[2023-09-07 01:26:24.946 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "LibraryMonitorStartup"
[2023-09-07 01:26:24.946 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "NotificationEntryPoint"
[2023-09-07 01:26:24.946 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "EmbyTV"
[2023-09-07 01:26:24.947 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "EntryPoint"
[2023-09-07 01:26:24.947 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "DeviceAccessEntryPoint"
[2023-09-07 01:26:24.947 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "UserDataChangeNotifier"
[2023-09-07 01:31:52.553 +00:00] [INF] [1] Main: Jellyfin version: "10.8.10"
[2023-09-07 01:31:52.564 +00:00] [INF] [1] Main: Environment Variables: ["[JELLYFIN_CACHE_DIR, /cache]", "[JELLYFIN_FFMPEG, /usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_DATA_DIR, /config]", "[JELLYFIN_CONFIG_DIR, /config/config]", "[JELLYFIN_WEB_DIR, /jellyfin/jellyfin-web]", "[JELLYFIN_LOG_DIR, /config/log]", "[DOTNET_SYSTEM_GLOBALIZATION_INVARIANT, 1]"]
[2023-09-07 01:31:52.566 +00:00] [INF] [1] Main: Arguments: ["/jellyfin/jellyfin.dll"]
[2023-09-07 01:31:52.567 +00:00] [INF] [1] Main: Operating system: "Linux"
[2023-09-07 01:31:52.567 +00:00] [INF] [1] Main: Architecture: X64
[2023-09-07 01:31:52.567 +00:00] [INF] [1] Main: 64-Bit Process: True
[2023-09-07 01:31:52.567 +00:00] [INF] [1] Main: User Interactive: True
[2023-09-07 01:31:52.567 +00:00] [INF] [1] Main: Processor count: 16
[2023-09-07 01:31:52.567 +00:00] [INF] [1] Main: Program data path: "/config"
[2023-09-07 01:31:52.567 +00:00] [INF] [1] Main: Web resources path: "/jellyfin/jellyfin-web"
[2023-09-07 01:31:52.567 +00:00] [INF] [1] Main: Application directory: "/jellyfin/"
[2023-09-07 01:31:52.714 +00:00] [INF] [1] Emby.Server.Implementations.AppBase.BaseConfigurationManager: Setting cache path: "/cache"
[2023-09-07 01:31:52.729 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Loading assemblies
[2023-09-07 01:31:52.788 +00:00] [ERR] [1] Jellyfin.Networking.Manager.NetworkManager: No interfaces information available. Resolving DNS name.
[2023-09-07 01:31:52.795 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN addresses : "[10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]"
[2023-09-07 01:31:52.795 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN exclusions : "[]"
[2023-09-07 01:31:52.796 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using LAN addresses: "[10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]"
[2023-09-07 01:31:52.801 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind addresses: "[]"
[2023-09-07 01:31:52.801 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind exclusions: "[]"
[2023-09-07 01:31:54.705 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "TMDb" "10.8.10.0"
[2023-09-07 01:31:54.706 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "Studio Images" "10.8.10.0"
[2023-09-07 01:31:54.706 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "OMDb" "10.8.10.0"
[2023-09-07 01:31:54.706 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "MusicBrainz" "10.8.10.0"
[2023-09-07 01:31:54.706 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "AudioDB" "10.8.10.0"
[2023-09-07 01:31:54.742 +00:00] [INF] [1] Main: Kestrel listening on "Any IP4 Address"
[2023-09-07 01:31:54.780 +00:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.Repositories.EphemeralXmlRepository: Using an in-memory repository. Keys will not be persisted to storage.
[2023-09-07 01:31:54.780 +00:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: Neither user profile nor HKLM registry available. Using an ephemeral key repository. Protected data will be unavailable when application exits.
[2023-09-07 01:31:54.939 +00:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: No XML encryptor configured. Key {63f1bf34-eda3-461a-98f5-f013edf9cd6f} may be persisted to storage in unencrypted form.
[2023-09-07 01:31:54.952 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Running startup tasks
[2023-09-07 01:31:54.978 +00:00] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for "Extract Chapter Images" set to fire at 2023-09-07 02:00:00.000 +00:00, which is 00:28:05.0212664 from now.
[2023-09-07 01:31:55.062 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Found ffmpeg version "5.1.3"
[2023-09-07 01:31:55.093 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available "decoders": ["libdav1d", "av1", "av1_cuvid", "av1_qsv", "h264", "h264_qsv", "h264_cuvid", "hevc", "hevc_qsv", "hevc_cuvid", "mpeg2video", "mpeg2_qsv", "mpeg2_cuvid", "mpeg4", "mpeg4_cuvid", "msmpeg4", "vc1_qsv", "vc1_cuvid", "vp8", "libvpx", "vp8_cuvid", "vp8_qsv", "vp9", "libvpx-vp9", "vp9_cuvid", "vp9_qsv", "aac", "ac3", "dca", "flac", "mp3", "truehd"]
[2023-09-07 01:31:55.112 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available "encoders": ["libx264", "h264_amf", "h264_nvenc", "h264_qsv", "h264_v4l2m2m", "h264_vaapi", "libx265", "hevc_amf", "hevc_nvenc", "hevc_qsv", "hevc_vaapi", "mpeg4", "msmpeg4", "libvpx", "libvpx-vp9", "aac", "libfdk_aac", "ac3", "dca", "flac", "libmp3lame", "libopus", "truehd", "libvorbis", "srt"]
[2023-09-07 01:31:55.132 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available filters: ["deinterlace_qsv", "deinterlace_vaapi", "hwupload_cuda", "hwupload_vaapi", "overlay_opencl", "overlay_qsv", "overlay_vaapi", "overlay_cuda", "procamp_vaapi", "scale_cuda", "scale_opencl", "scale_qsv", "scale_vaapi", "tonemap_cuda", "tonemap_opencl", "tonemap_vaapi", "vpp_qsv", "yadif_cuda", "zscale", "alphasrc"]
[2023-09-07 01:31:55.230 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available hwaccel types: ["cuda", "vaapi", "qsv", "drm", "opencl", "vulkan"]
[2023-09-07 01:31:55.316 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: FFmpeg: "/usr/lib/jellyfin-ffmpeg/ffmpeg"
[2023-09-07 01:31:55.317 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: ServerId: "0f138af22ef047dab62b8dc4e4ea5a88"
[2023-09-07 01:31:55.413 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all pre-startup entry points in 0:00:00.0806573
[2023-09-07 01:31:55.413 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Core startup complete
[2023-09-07 01:31:55.515 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all post-startup entry points in 0:00:00.1019782
[2023-09-07 01:31:55.515 +00:00] [INF] [1] Main: Startup complete 0:00:03.1057353
[2023-09-07 01:31:55.516 +00:00] [INF] [10] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Videos/TV"
[2023-09-07 01:31:55.519 +00:00] [INF] [13] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Videos/Movies"
[2023-09-07 01:31:55.522 +00:00] [INF] [11] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Videos/Anime"
[2023-09-07 01:31:55.603 +00:00] [INF] [15] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Music"
[2023-09-07 01:31:57.983 +00:00] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: "StartupTrigger" fired for task: "Update Plugins"
[2023-09-07 01:31:57.984 +00:00] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: Queuing task "PluginUpdateTask"
[2023-09-07 01:31:57.986 +00:00] [INF] [11] Emby.Server.Implementations.ScheduledTasks.TaskManager: Executing "Update Plugins"
[2023-09-07 01:31:58.316 +00:00] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: "Update Plugins" Completed after 0 minute(s) and 0 seconds
[2023-09-07 01:31:58.325 +00:00] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: ExecuteQueuedTasks
[2023-09-07 01:32:22.654 +00:00] [WRN] [8] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"AccessSchedule"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:32:22.655 +00:00] [WRN] [8] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ActivityLog"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:32:22.655 +00:00] [WRN] [8] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"CustomItemDisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:32:22.655 +00:00] [WRN] [8] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"DisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:32:22.655 +00:00] [WRN] [8] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"HomeSection"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:32:22.655 +00:00] [WRN] [8] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ImageInfo"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:32:22.655 +00:00] [WRN] [8] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ItemDisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:32:22.655 +00:00] [WRN] [8] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"Permission"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:32:22.655 +00:00] [WRN] [8] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"Preference"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:32:22.655 +00:00] [WRN] [8] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ApiKey"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:32:22.655 +00:00] [WRN] [8] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"Device"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:32:22.655 +00:00] [WRN] [8] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"DeviceOptions"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:32:22.655 +00:00] [WRN] [8] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"User"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:33:22.304 +00:00] [INF] [2] Main: Received a SIGTERM signal, shutting down
[2023-09-07 01:33:22.305 +00:00] [INF] [2] Main: Running query planner optimizations in the database... This might take a while
[2023-09-07 01:33:22.311 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "CoreAppHost"
[2023-09-07 01:33:22.311 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "ExternalPortForwarding"
[2023-09-07 01:33:22.311 +00:00] [INF] [2] Emby.Server.Implementations.EntryPoints.ExternalPortForwarding: Stopping NAT discovery
[2023-09-07 01:33:22.313 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "LibraryChangedNotifier"
[2023-09-07 01:33:22.314 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "DlnaEntryPoint"
[2023-09-07 01:33:22.314 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing PlayToManager
[2023-09-07 01:33:22.315 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing DeviceDiscovery
[2023-09-07 01:33:22.315 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing SsdpCommunicationsServer
[2023-09-07 01:33:22.315 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing _BroadcastListenSocket
[2023-09-07 01:33:22.316 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" Disposing 3 sendSockets
[2023-09-07 01:33:22.316 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing sendSocket from "0.0.0.0"
[2023-09-07 01:33:22.316 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing sendSocket from "10.0.2.100"
[2023-09-07 01:33:22.316 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing sendSocket from "127.0.0.1"
[2023-09-07 01:33:22.316 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "UdpServerEntryPoint"
[2023-09-07 01:33:22.316 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "MusicBrainzAlbumProvider"
[2023-09-07 01:33:22.316 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "RecordingNotifier"
[2023-09-07 01:33:22.317 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "EntryPoint"
[2023-09-07 01:33:22.317 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "SchedulesDirect"
[2023-09-07 01:33:22.317 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "LibraryMonitorStartup"
[2023-09-07 01:33:22.317 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "NotificationEntryPoint"
[2023-09-07 01:33:22.318 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "EmbyTV"
[2023-09-07 01:33:22.318 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "EntryPoint"
[2023-09-07 01:33:22.318 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "DeviceAccessEntryPoint"
[2023-09-07 01:33:22.318 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "UserDataChangeNotifier"
[2023-09-07 01:33:23.104 +00:00] [INF] [1] Main: Jellyfin version: "10.8.10"
[2023-09-07 01:33:23.115 +00:00] [INF] [1] Main: Environment Variables: ["[JELLYFIN_FFMPEG, /usr/lib/jellyfin-ffmpeg/ffmpeg]", "[DOTNET_SYSTEM_GLOBALIZATION_INVARIANT, 1]", "[JELLYFIN_WEB_DIR, /jellyfin/jellyfin-web]", "[JELLYFIN_DATA_DIR, /config]", "[JELLYFIN_CONFIG_DIR, /config/config]", "[JELLYFIN_LOG_DIR, /config/log]", "[JELLYFIN_CACHE_DIR, /cache]"]
[2023-09-07 01:33:23.116 +00:00] [INF] [1] Main: Arguments: ["/jellyfin/jellyfin.dll"]
[2023-09-07 01:33:23.117 +00:00] [INF] [1] Main: Operating system: "Linux"
[2023-09-07 01:33:23.117 +00:00] [INF] [1] Main: Architecture: X64
[2023-09-07 01:33:23.117 +00:00] [INF] [1] Main: 64-Bit Process: True
[2023-09-07 01:33:23.117 +00:00] [INF] [1] Main: User Interactive: True
[2023-09-07 01:33:23.117 +00:00] [INF] [1] Main: Processor count: 16
[2023-09-07 01:33:23.117 +00:00] [INF] [1] Main: Program data path: "/config"
[2023-09-07 01:33:23.117 +00:00] [INF] [1] Main: Web resources path: "/jellyfin/jellyfin-web"
[2023-09-07 01:33:23.117 +00:00] [INF] [1] Main: Application directory: "/jellyfin/"
[2023-09-07 01:33:23.234 +00:00] [INF] [1] Emby.Server.Implementations.AppBase.BaseConfigurationManager: Setting cache path: "/cache"
[2023-09-07 01:33:23.244 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Loading assemblies
[2023-09-07 01:33:23.287 +00:00] [ERR] [1] Jellyfin.Networking.Manager.NetworkManager: No interfaces information available. Resolving DNS name.
[2023-09-07 01:33:23.294 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN addresses : "[10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]"
[2023-09-07 01:33:23.294 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN exclusions : "[]"
[2023-09-07 01:33:23.294 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using LAN addresses: "[10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]"
[2023-09-07 01:33:23.300 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind addresses: "[]"
[2023-09-07 01:33:23.300 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind exclusions: "[]"
[2023-09-07 01:33:25.113 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "TMDb" "10.8.10.0"
[2023-09-07 01:33:25.114 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "Studio Images" "10.8.10.0"
[2023-09-07 01:33:25.114 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "OMDb" "10.8.10.0"
[2023-09-07 01:33:25.114 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "MusicBrainz" "10.8.10.0"
[2023-09-07 01:33:25.114 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "AudioDB" "10.8.10.0"
[2023-09-07 01:33:25.146 +00:00] [INF] [1] Main: Kestrel listening on "Any IP4 Address"
[2023-09-07 01:33:25.176 +00:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.Repositories.EphemeralXmlRepository: Using an in-memory repository. Keys will not be persisted to storage.
[2023-09-07 01:33:25.176 +00:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: Neither user profile nor HKLM registry available. Using an ephemeral key repository. Protected data will be unavailable when application exits.
[2023-09-07 01:33:25.336 +00:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: No XML encryptor configured. Key {0480d98d-2cfb-483f-abd9-4734669ab488} may be persisted to storage in unencrypted form.
[2023-09-07 01:33:25.348 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Running startup tasks
[2023-09-07 01:33:25.374 +00:00] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for "Extract Chapter Images" set to fire at 2023-09-07 02:00:00.000 +00:00, which is 00:26:34.6251083 from now.
[2023-09-07 01:33:25.411 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Found ffmpeg version "5.1.3"
[2023-09-07 01:33:25.437 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available "decoders": ["libdav1d", "av1", "av1_cuvid", "av1_qsv", "h264", "h264_qsv", "h264_cuvid", "hevc", "hevc_qsv", "hevc_cuvid", "mpeg2video", "mpeg2_qsv", "mpeg2_cuvid", "mpeg4", "mpeg4_cuvid", "msmpeg4", "vc1_qsv", "vc1_cuvid", "vp8", "libvpx", "vp8_cuvid", "vp8_qsv", "vp9", "libvpx-vp9", "vp9_cuvid", "vp9_qsv", "aac", "ac3", "dca", "flac", "mp3", "truehd"]
[2023-09-07 01:33:25.456 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available "encoders": ["libx264", "h264_amf", "h264_nvenc", "h264_qsv", "h264_v4l2m2m", "h264_vaapi", "libx265", "hevc_amf", "hevc_nvenc", "hevc_qsv", "hevc_vaapi", "mpeg4", "msmpeg4", "libvpx", "libvpx-vp9", "aac", "libfdk_aac", "ac3", "dca", "flac", "libmp3lame", "libopus", "truehd", "libvorbis", "srt"]
[2023-09-07 01:33:25.474 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available filters: ["deinterlace_qsv", "deinterlace_vaapi", "hwupload_cuda", "hwupload_vaapi", "overlay_opencl", "overlay_qsv", "overlay_vaapi", "overlay_cuda", "procamp_vaapi", "scale_cuda", "scale_opencl", "scale_qsv", "scale_vaapi", "tonemap_cuda", "tonemap_opencl", "tonemap_vaapi", "vpp_qsv", "yadif_cuda", "zscale", "alphasrc"]
[2023-09-07 01:33:25.575 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available hwaccel types: ["cuda", "vaapi", "qsv", "drm", "opencl", "vulkan"]
[2023-09-07 01:33:25.654 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: FFmpeg: "/usr/lib/jellyfin-ffmpeg/ffmpeg"
[2023-09-07 01:33:25.655 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: ServerId: "0f138af22ef047dab62b8dc4e4ea5a88"
[2023-09-07 01:33:25.719 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all pre-startup entry points in 0:00:00.0559657
[2023-09-07 01:33:25.719 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Core startup complete
[2023-09-07 01:33:25.821 +00:00] [INF] [10] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Videos/Movies"
[2023-09-07 01:33:25.822 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all post-startup entry points in 0:00:00.1020822
[2023-09-07 01:33:25.822 +00:00] [INF] [1] Main: Startup complete 0:00:02.8420805
[2023-09-07 01:33:25.823 +00:00] [INF] [11] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Videos/TV"
[2023-09-07 01:33:25.824 +00:00] [INF] [13] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Videos/Anime"
[2023-09-07 01:33:25.903 +00:00] [INF] [15] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Music"
[2023-09-07 01:33:28.378 +00:00] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: "StartupTrigger" fired for task: "Update Plugins"
[2023-09-07 01:33:28.379 +00:00] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: Queuing task "PluginUpdateTask"
[2023-09-07 01:33:28.381 +00:00] [INF] [13] Emby.Server.Implementations.ScheduledTasks.TaskManager: Executing "Update Plugins"
[2023-09-07 01:33:28.632 +00:00] [INF] [20] Emby.Server.Implementations.ScheduledTasks.TaskManager: "Update Plugins" Completed after 0 minute(s) and 0 seconds
[2023-09-07 01:33:28.642 +00:00] [INF] [20] Emby.Server.Implementations.ScheduledTasks.TaskManager: ExecuteQueuedTasks
[2023-09-07 01:33:53.745 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"AccessSchedule"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:33:53.746 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ActivityLog"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:33:53.746 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"CustomItemDisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:33:53.746 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"DisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:33:53.746 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"HomeSection"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:33:53.746 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ImageInfo"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:33:53.746 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ItemDisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:33:53.746 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"Permission"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:33:53.746 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"Preference"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:33:53.746 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ApiKey"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:33:53.746 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"Device"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:33:53.746 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"DeviceOptions"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:33:53.746 +00:00] [WRN] [25] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"User"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:34:53.054 +00:00] [INF] [2] Main: Received a SIGTERM signal, shutting down
[2023-09-07 01:34:53.055 +00:00] [INF] [2] Main: Running query planner optimizations in the database... This might take a while
[2023-09-07 01:34:53.101 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "CoreAppHost"
[2023-09-07 01:34:53.101 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "ExternalPortForwarding"
[2023-09-07 01:34:53.102 +00:00] [INF] [2] Emby.Server.Implementations.EntryPoints.ExternalPortForwarding: Stopping NAT discovery
[2023-09-07 01:34:53.103 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "LibraryChangedNotifier"
[2023-09-07 01:34:53.104 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "DlnaEntryPoint"
[2023-09-07 01:34:53.105 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing PlayToManager
[2023-09-07 01:34:53.105 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing DeviceDiscovery
[2023-09-07 01:34:53.105 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing SsdpCommunicationsServer
[2023-09-07 01:34:53.106 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing _BroadcastListenSocket
[2023-09-07 01:34:53.106 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" Disposing 3 sendSockets
[2023-09-07 01:34:53.106 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing sendSocket from "0.0.0.0"
[2023-09-07 01:34:53.106 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing sendSocket from "10.0.2.100"
[2023-09-07 01:34:53.106 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing sendSocket from "127.0.0.1"
[2023-09-07 01:34:53.106 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "UdpServerEntryPoint"
[2023-09-07 01:34:53.107 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "MusicBrainzAlbumProvider"
[2023-09-07 01:34:53.107 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "RecordingNotifier"
[2023-09-07 01:34:53.107 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "EntryPoint"
[2023-09-07 01:34:53.107 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "SchedulesDirect"
[2023-09-07 01:34:53.107 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "LibraryMonitorStartup"
[2023-09-07 01:34:53.107 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "NotificationEntryPoint"
[2023-09-07 01:34:53.108 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "EmbyTV"
[2023-09-07 01:34:53.108 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "EntryPoint"
[2023-09-07 01:34:53.109 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "DeviceAccessEntryPoint"
[2023-09-07 01:34:53.109 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "UserDataChangeNotifier"
[2023-09-07 01:34:53.874 +00:00] [INF] [1] Main: Jellyfin version: "10.8.10"
[2023-09-07 01:34:53.885 +00:00] [INF] [1] Main: Environment Variables: ["[JELLYFIN_CACHE_DIR, /cache]", "[JELLYFIN_CONFIG_DIR, /config/config]", "[JELLYFIN_WEB_DIR, /jellyfin/jellyfin-web]", "[DOTNET_SYSTEM_GLOBALIZATION_INVARIANT, 1]", "[JELLYFIN_LOG_DIR, /config/log]", "[JELLYFIN_FFMPEG, /usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_DATA_DIR, /config]"]
[2023-09-07 01:34:53.887 +00:00] [INF] [1] Main: Arguments: ["/jellyfin/jellyfin.dll"]
[2023-09-07 01:34:53.887 +00:00] [INF] [1] Main: Operating system: "Linux"
[2023-09-07 01:34:53.887 +00:00] [INF] [1] Main: Architecture: X64
[2023-09-07 01:34:53.888 +00:00] [INF] [1] Main: 64-Bit Process: True
[2023-09-07 01:34:53.888 +00:00] [INF] [1] Main: User Interactive: True
[2023-09-07 01:34:53.888 +00:00] [INF] [1] Main: Processor count: 16
[2023-09-07 01:34:53.888 +00:00] [INF] [1] Main: Program data path: "/config"
[2023-09-07 01:34:53.888 +00:00] [INF] [1] Main: Web resources path: "/jellyfin/jellyfin-web"
[2023-09-07 01:34:53.888 +00:00] [INF] [1] Main: Application directory: "/jellyfin/"
[2023-09-07 01:34:54.005 +00:00] [INF] [1] Emby.Server.Implementations.AppBase.BaseConfigurationManager: Setting cache path: "/cache"
[2023-09-07 01:34:54.015 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Loading assemblies
[2023-09-07 01:34:54.058 +00:00] [ERR] [1] Jellyfin.Networking.Manager.NetworkManager: No interfaces information available. Resolving DNS name.
[2023-09-07 01:34:54.065 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN addresses : "[10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]"
[2023-09-07 01:34:54.065 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN exclusions : "[]"
[2023-09-07 01:34:54.065 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using LAN addresses: "[10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]"
[2023-09-07 01:34:54.071 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind addresses: "[]"
[2023-09-07 01:34:54.071 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind exclusions: "[]"
[2023-09-07 01:34:55.881 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "TMDb" "10.8.10.0"
[2023-09-07 01:34:55.881 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "Studio Images" "10.8.10.0"
[2023-09-07 01:34:55.881 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "OMDb" "10.8.10.0"
[2023-09-07 01:34:55.882 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "MusicBrainz" "10.8.10.0"
[2023-09-07 01:34:55.882 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "AudioDB" "10.8.10.0"
[2023-09-07 01:34:55.913 +00:00] [INF] [1] Main: Kestrel listening on "Any IP4 Address"
[2023-09-07 01:34:55.944 +00:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.Repositories.EphemeralXmlRepository: Using an in-memory repository. Keys will not be persisted to storage.
[2023-09-07 01:34:55.944 +00:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: Neither user profile nor HKLM registry available. Using an ephemeral key repository. Protected data will be unavailable when application exits.
[2023-09-07 01:34:56.106 +00:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: No XML encryptor configured. Key {db45973b-0084-4566-98b0-2bc3ed033f1e} may be persisted to storage in unencrypted form.
[2023-09-07 01:34:56.118 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Running startup tasks
[2023-09-07 01:34:56.144 +00:00] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for "Extract Chapter Images" set to fire at 2023-09-07 02:00:00.000 +00:00, which is 00:25:03.8555453 from now.
[2023-09-07 01:34:56.179 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Found ffmpeg version "5.1.3"
[2023-09-07 01:34:56.206 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available "decoders": ["libdav1d", "av1", "av1_cuvid", "av1_qsv", "h264", "h264_qsv", "h264_cuvid", "hevc", "hevc_qsv", "hevc_cuvid", "mpeg2video", "mpeg2_qsv", "mpeg2_cuvid", "mpeg4", "mpeg4_cuvid", "msmpeg4", "vc1_qsv", "vc1_cuvid", "vp8", "libvpx", "vp8_cuvid", "vp8_qsv", "vp9", "libvpx-vp9", "vp9_cuvid", "vp9_qsv", "aac", "ac3", "dca", "flac", "mp3", "truehd"]
[2023-09-07 01:34:56.224 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available "encoders": ["libx264", "h264_amf", "h264_nvenc", "h264_qsv", "h264_v4l2m2m", "h264_vaapi", "libx265", "hevc_amf", "hevc_nvenc", "hevc_qsv", "hevc_vaapi", "mpeg4", "msmpeg4", "libvpx", "libvpx-vp9", "aac", "libfdk_aac", "ac3", "dca", "flac", "libmp3lame", "libopus", "truehd", "libvorbis", "srt"]
[2023-09-07 01:34:56.242 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available filters: ["deinterlace_qsv", "deinterlace_vaapi", "hwupload_cuda", "hwupload_vaapi", "overlay_opencl", "overlay_qsv", "overlay_vaapi", "overlay_cuda", "procamp_vaapi", "scale_cuda", "scale_opencl", "scale_qsv", "scale_vaapi", "tonemap_cuda", "tonemap_opencl", "tonemap_vaapi", "vpp_qsv", "yadif_cuda", "zscale", "alphasrc"]
[2023-09-07 01:34:56.339 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available hwaccel types: ["cuda", "vaapi", "qsv", "drm", "opencl", "vulkan"]
[2023-09-07 01:34:56.417 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: FFmpeg: "/usr/lib/jellyfin-ffmpeg/ffmpeg"
[2023-09-07 01:34:56.418 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: ServerId: "0f138af22ef047dab62b8dc4e4ea5a88"
[2023-09-07 01:34:56.499 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all pre-startup entry points in 0:00:00.0658675
[2023-09-07 01:34:56.499 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Core startup complete
[2023-09-07 01:34:56.598 +00:00] [INF] [10] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Videos/Movies"
[2023-09-07 01:34:56.598 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all post-startup entry points in 0:00:00.0992828
[2023-09-07 01:34:56.598 +00:00] [INF] [1] Main: Startup complete 0:00:02.8699294
[2023-09-07 01:34:56.600 +00:00] [INF] [11] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Videos/TV"
[2023-09-07 01:34:56.605 +00:00] [INF] [13] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Videos/Anime"
[2023-09-07 01:34:56.679 +00:00] [INF] [15] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Music"
[2023-09-07 01:34:59.148 +00:00] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: "StartupTrigger" fired for task: "Update Plugins"
[2023-09-07 01:34:59.148 +00:00] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: Queuing task "PluginUpdateTask"
[2023-09-07 01:34:59.150 +00:00] [INF] [13] Emby.Server.Implementations.ScheduledTasks.TaskManager: Executing "Update Plugins"
[2023-09-07 01:34:59.463 +00:00] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: "Update Plugins" Completed after 0 minute(s) and 0 seconds
[2023-09-07 01:34:59.478 +00:00] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: ExecuteQueuedTasks
[2023-09-07 01:35:24.761 +00:00] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"AccessSchedule"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:35:24.762 +00:00] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ActivityLog"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:35:24.762 +00:00] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"CustomItemDisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:35:24.762 +00:00] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"DisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:35:24.762 +00:00] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"HomeSection"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:35:24.762 +00:00] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ImageInfo"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:35:24.762 +00:00] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ItemDisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:35:24.762 +00:00] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"Permission"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:35:24.762 +00:00] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"Preference"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:35:24.762 +00:00] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ApiKey"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:35:24.762 +00:00] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"Device"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:35:24.762 +00:00] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"DeviceOptions"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:35:24.762 +00:00] [WRN] [15] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"User"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:36:23.804 +00:00] [INF] [2] Main: Received a SIGTERM signal, shutting down
[2023-09-07 01:36:23.805 +00:00] [INF] [2] Main: Running query planner optimizations in the database... This might take a while
[2023-09-07 01:36:23.850 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "CoreAppHost"
[2023-09-07 01:36:23.851 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "ExternalPortForwarding"
[2023-09-07 01:36:23.851 +00:00] [INF] [2] Emby.Server.Implementations.EntryPoints.ExternalPortForwarding: Stopping NAT discovery
[2023-09-07 01:36:23.853 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "LibraryChangedNotifier"
[2023-09-07 01:36:23.854 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "DlnaEntryPoint"
[2023-09-07 01:36:23.854 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing PlayToManager
[2023-09-07 01:36:23.855 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing DeviceDiscovery
[2023-09-07 01:36:23.855 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: Disposing SsdpCommunicationsServer
[2023-09-07 01:36:23.855 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing _BroadcastListenSocket
[2023-09-07 01:36:23.856 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" Disposing 3 sendSockets
[2023-09-07 01:36:23.856 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing sendSocket from "0.0.0.0"
[2023-09-07 01:36:23.856 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing sendSocket from "10.0.2.100"
[2023-09-07 01:36:23.856 +00:00] [INF] [2] Emby.Dlna.Main.DlnaEntryPoint: "SsdpCommunicationsServer" disposing sendSocket from "127.0.0.1"
[2023-09-07 01:36:23.856 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "UdpServerEntryPoint"
[2023-09-07 01:36:23.856 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "MusicBrainzAlbumProvider"
[2023-09-07 01:36:23.856 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "RecordingNotifier"
[2023-09-07 01:36:23.857 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "EntryPoint"
[2023-09-07 01:36:23.857 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "SchedulesDirect"
[2023-09-07 01:36:23.857 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "LibraryMonitorStartup"
[2023-09-07 01:36:23.857 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "NotificationEntryPoint"
[2023-09-07 01:36:23.858 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "EmbyTV"
[2023-09-07 01:36:23.858 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "EntryPoint"
[2023-09-07 01:36:23.858 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "DeviceAccessEntryPoint"
[2023-09-07 01:36:23.858 +00:00] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing "UserDataChangeNotifier"
[2023-09-07 01:36:24.587 +00:00] [INF] [1] Main: Jellyfin version: "10.8.10"
[2023-09-07 01:36:24.598 +00:00] [INF] [1] Main: Environment Variables: ["[JELLYFIN_FFMPEG, /usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_WEB_DIR, /jellyfin/jellyfin-web]", "[DOTNET_SYSTEM_GLOBALIZATION_INVARIANT, 1]", "[JELLYFIN_DATA_DIR, /config]", "[JELLYFIN_CONFIG_DIR, /config/config]", "[JELLYFIN_LOG_DIR, /config/log]", "[JELLYFIN_CACHE_DIR, /cache]"]
[2023-09-07 01:36:24.600 +00:00] [INF] [1] Main: Arguments: ["/jellyfin/jellyfin.dll"]
[2023-09-07 01:36:24.600 +00:00] [INF] [1] Main: Operating system: "Linux"
[2023-09-07 01:36:24.600 +00:00] [INF] [1] Main: Architecture: X64
[2023-09-07 01:36:24.601 +00:00] [INF] [1] Main: 64-Bit Process: True
[2023-09-07 01:36:24.601 +00:00] [INF] [1] Main: User Interactive: True
[2023-09-07 01:36:24.601 +00:00] [INF] [1] Main: Processor count: 16
[2023-09-07 01:36:24.601 +00:00] [INF] [1] Main: Program data path: "/config"
[2023-09-07 01:36:24.601 +00:00] [INF] [1] Main: Web resources path: "/jellyfin/jellyfin-web"
[2023-09-07 01:36:24.601 +00:00] [INF] [1] Main: Application directory: "/jellyfin/"
[2023-09-07 01:36:24.706 +00:00] [INF] [1] Emby.Server.Implementations.AppBase.BaseConfigurationManager: Setting cache path: "/cache"
[2023-09-07 01:36:24.715 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Loading assemblies
[2023-09-07 01:36:24.758 +00:00] [ERR] [1] Jellyfin.Networking.Manager.NetworkManager: No interfaces information available. Resolving DNS name.
[2023-09-07 01:36:24.765 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN addresses : "[10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]"
[2023-09-07 01:36:24.765 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN exclusions : "[]"
[2023-09-07 01:36:24.766 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using LAN addresses: "[10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]"
[2023-09-07 01:36:24.771 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind addresses: "[]"
[2023-09-07 01:36:24.771 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind exclusions: "[]"
[2023-09-07 01:36:26.582 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "TMDb" "10.8.10.0"
[2023-09-07 01:36:26.582 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "Studio Images" "10.8.10.0"
[2023-09-07 01:36:26.582 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "OMDb" "10.8.10.0"
[2023-09-07 01:36:26.582 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "MusicBrainz" "10.8.10.0"
[2023-09-07 01:36:26.583 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "AudioDB" "10.8.10.0"
[2023-09-07 01:36:26.614 +00:00] [INF] [1] Main: Kestrel listening on "Any IP4 Address"
[2023-09-07 01:36:26.645 +00:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.Repositories.EphemeralXmlRepository: Using an in-memory repository. Keys will not be persisted to storage.
[2023-09-07 01:36:26.645 +00:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: Neither user profile nor HKLM registry available. Using an ephemeral key repository. Protected data will be unavailable when application exits.
[2023-09-07 01:36:26.806 +00:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: No XML encryptor configured. Key {4a1eddf6-d80c-48d0-a3e6-5f9a5798ea42} may be persisted to storage in unencrypted form.
[2023-09-07 01:36:26.818 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Running startup tasks
[2023-09-07 01:36:26.844 +00:00] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for "Extract Chapter Images" set to fire at 2023-09-07 02:00:00.000 +00:00, which is 00:23:33.1551502 from now.
[2023-09-07 01:36:26.880 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Found ffmpeg version "5.1.3"
[2023-09-07 01:36:26.907 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available "decoders": ["libdav1d", "av1", "av1_cuvid", "av1_qsv", "h264", "h264_qsv", "h264_cuvid", "hevc", "hevc_qsv", "hevc_cuvid", "mpeg2video", "mpeg2_qsv", "mpeg2_cuvid", "mpeg4", "mpeg4_cuvid", "msmpeg4", "vc1_qsv", "vc1_cuvid", "vp8", "libvpx", "vp8_cuvid", "vp8_qsv", "vp9", "libvpx-vp9", "vp9_cuvid", "vp9_qsv", "aac", "ac3", "dca", "flac", "mp3", "truehd"]
[2023-09-07 01:36:26.924 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available "encoders": ["libx264", "h264_amf", "h264_nvenc", "h264_qsv", "h264_v4l2m2m", "h264_vaapi", "libx265", "hevc_amf", "hevc_nvenc", "hevc_qsv", "hevc_vaapi", "mpeg4", "msmpeg4", "libvpx", "libvpx-vp9", "aac", "libfdk_aac", "ac3", "dca", "flac", "libmp3lame", "libopus", "truehd", "libvorbis", "srt"]
[2023-09-07 01:36:26.942 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available filters: ["deinterlace_qsv", "deinterlace_vaapi", "hwupload_cuda", "hwupload_vaapi", "overlay_opencl", "overlay_qsv", "overlay_vaapi", "overlay_cuda", "procamp_vaapi", "scale_cuda", "scale_opencl", "scale_qsv", "scale_vaapi", "tonemap_cuda", "tonemap_opencl", "tonemap_vaapi", "vpp_qsv", "yadif_cuda", "zscale", "alphasrc"]
[2023-09-07 01:36:27.038 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available hwaccel types: ["cuda", "vaapi", "qsv", "drm", "opencl", "vulkan"]
[2023-09-07 01:36:27.117 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: FFmpeg: "/usr/lib/jellyfin-ffmpeg/ffmpeg"
[2023-09-07 01:36:27.117 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: ServerId: "0f138af22ef047dab62b8dc4e4ea5a88"
[2023-09-07 01:36:27.199 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all pre-startup entry points in 0:00:00.0681177
[2023-09-07 01:36:27.199 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Core startup complete
[2023-09-07 01:36:27.299 +00:00] [INF] [10] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Videos/Movies"
[2023-09-07 01:36:27.299 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all post-startup entry points in 0:00:00.0995339
[2023-09-07 01:36:27.299 +00:00] [INF] [1] Main: Startup complete 0:00:02.8332103
[2023-09-07 01:36:27.305 +00:00] [INF] [13] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Videos/Anime"
[2023-09-07 01:36:27.306 +00:00] [INF] [8] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Videos/TV"
[2023-09-07 01:36:27.387 +00:00] [INF] [15] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/DATA/SHARED/Music"
[2023-09-07 01:36:29.848 +00:00] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: "StartupTrigger" fired for task: "Update Plugins"
[2023-09-07 01:36:29.849 +00:00] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: Queuing task "PluginUpdateTask"
[2023-09-07 01:36:29.851 +00:00] [INF] [8] Emby.Server.Implementations.ScheduledTasks.TaskManager: Executing "Update Plugins"
[2023-09-07 01:36:30.131 +00:00] [INF] [19] Emby.Server.Implementations.ScheduledTasks.TaskManager: "Update Plugins" Completed after 0 minute(s) and 0 seconds
[2023-09-07 01:36:30.136 +00:00] [INF] [19] Emby.Server.Implementations.ScheduledTasks.TaskManager: ExecuteQueuedTasks
[2023-09-07 01:36:54.750 +00:00] [WRN] [14] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"AccessSchedule"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:36:54.751 +00:00] [WRN] [14] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ActivityLog"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:36:54.751 +00:00] [WRN] [14] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"CustomItemDisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:36:54.751 +00:00] [WRN] [14] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"DisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:36:54.751 +00:00] [WRN] [14] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"HomeSection"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:36:54.751 +00:00] [WRN] [14] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ImageInfo"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:36:54.751 +00:00] [WRN] [14] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ItemDisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:36:54.751 +00:00] [WRN] [14] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"Permission"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:36:54.751 +00:00] [WRN] [14] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"Preference"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:36:54.751 +00:00] [WRN] [14] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"ApiKey"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:36:54.751 +00:00] [WRN] [14] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"Device"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:36:54.751 +00:00] [WRN] [14] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"DeviceOptions"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:36:54.751 +00:00] [WRN] [14] Microsoft.EntityFrameworkCore.Model.Validation: The entity type '"User"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
[2023-09-07 01:37:19.605 +00:00] [INF] [28] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "10.0.2.100" request
Current systemd unit file:
$ cat .config/systemd/user/container-jellyfin.service
# container-jellyfin.service
# autogenerated by Podman 3.4.4
# Tue Sep  5 04:02:15 UTC 2023
[Unit]
Description=Podman container-jellyfin.service
Documentation=man:podman-generate-systemd(1)
Wants=network-online.target
After=network-online.target
RequiresMountsFor=/run/user/1001/containers
[Service]
Environment=PODMAN_SYSTEMD_UNIT=%n
Restart=on-failure
#TimeoutStopSec=70
ExecStart=/usr/bin/podman run \
 --detach \
 --label "io.containers.autoupdate=registry" \
 --name jellyfin \
 --publish 8096:8096/tcp \
 --rm \
 --userns keep-id \
 --volume /opt/podvol/jellyfin/cache:/cache \
 --volume /opt/podvol/jellyfin/config:/config \
 --mount type=bind,source=/media,destination=/media,ro=false \
 docker.io/jellyfin/jellyfin:latest
#ExecStart=/usr/bin/podman start jellyfin
ExecStop=/usr/bin/podman stop -t 10 jellyfin
ExecStopPost=/usr/bin/podman stop -t 10 jellyfin
PIDFile=/run/user/1001/containers/overlay-containers/e18be9e055369e62b96cccaa89d15215f54f0f3914839921392eb35bae12e72e/userdata/conmon.pid
Type=forking
[Install]
WantedBy=default.target
@YamiYukiSenpai I took a quick look at the logs and I did not see anything that would lead me to the reason why JellyFin crashed. I not very familiar with JellyFin, I use Emby Server. I just had eye surgery yesterday, so I do not see very well yet. I will look at the logs again in a couble days. Mean while maybe another person might have a better idea. Why did you use docker to install JellyFin? Why did you not use the instrutions for Ubuntu instead?
Get well!!
Shot in the dark here, since you seems to run this as a user service, have you enabled lingering?
$ loginctl enable-linger username
Otherwise systemd will kill the process when you logged out.
Yup.
Jellyfin runs fine when started up manually
Hi @YamiYukiSenpai, I am seeing a little better today, I looked at the logs again today. I think the reason JellyFin keeps crashing when not sarted manually, Systemd is not setup correctly. I am thinking of creating a VM and try installing JellyFin the way you did and see if I get the same result. Could you please list the steps you used to install JellyFin.
Sorry for late reply. I had other stuff to take care off
  1. I started off by following this: Container | Jellyfin
    a. I only did step 1 as #2 didn’t work for me
  2. I followed this step to create a systemd service: https://www.redhat.com/sysadmin/container-systemd-persist-reboot
    Which resulted with this:
[Unit]
[Service]
Restart=unless-stopped
TimeoutStopSec=70
 --detach \
 --name jellyfin \
 --rm \
 --replace \
 --userns keep-id \
Type=notify
NotifyAccess=all
[Install]
  1. Last time I attempted it:
$ systemctl --user status container-jellyfin.service
× container-jellyfin.service - Podman container-jellyfin.service
     Loaded: loaded (/home/.jellyfin/.config/systemd/user/container-jellyfin.service; enabled; vendor preset: enabled)
     Active: failed (Result: timeout) since Sun 2023-09-24 07:01:17 UTC; 1min 19s ago
       Docs: man:podman-generate-systemd(1)
    Process: 6809 ExecStart=/usr/bin/podman run --detach --label io.containers.autoupdate=registry --name jellyfin --publish 8096:8096/tcp --rm --replace --userns keep-id --volume /opt/podvol/jellyfin/cache:/cache --volume /opt/podvol/jellyfin/config:/config --mount type=bind,source=/media,destination=/media,ro=false docker.io/jell>
    Process: 7494 ExecStopPost=/usr/bin/podman stop -t 10 jellyfin (code=exited, status=125)
   Main PID: 6809 (code=exited, status=143)
        CPU: 212ms
Sep 24 07:01:16 skarletsky conmon[6809]: [07:01:16] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing EntryPoint
Sep 24 07:01:16 skarletsky conmon[6809]: [07:01:16] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing DeviceAccessEntryPoint
Sep 24 07:01:16 skarletsky conmon[6809]: [07:01:16] [INF] [2] Emby.Server.Implementations.ApplicationHost: Disposing UserDataChangeNotifier
Sep 24 07:01:16 skarletsky podman[7448]: 2023-09-24 07:01:16.874678393 +0000 UTC m=+0.020673032 container died 93f929460cb3d59b351f87f83962cb7a709c1894ac1b189e7c9b787f9a5e79de (image=docker.io/jellyfin/jellyfin:latest, name=jellyfin)
Sep 24 07:01:16 skarletsky podman[7448]: 2023-09-24 07:01:16.887669773 +0000 UTC m=+0.033664412 container remove 93f929460cb3d59b351f87f83962cb7a709c1894ac1b189e7c9b787f9a5e79de (image=docker.io/jellyfin/jellyfin:latest, name=jellyfin, PODMAN_SYSTEMD_UNIT=container-jellyfin.service, io.containers.autoupdate=registry)
Sep 24 07:01:16 skarletsky systemd[1043]: container-jellyfin.service: Main process exited, code=exited, status=143/n/a
Sep 24 07:01:17 skarletsky podman[7494]: Error: no container with name or ID "jellyfin" found: no such container
Sep 24 07:01:17 skarletsky systemd[1043]: container-jellyfin.service: Control process exited, code=exited, status=125/n/a
Sep 24 07:01:17 skarletsky systemd[1043]: container-jellyfin.service: Failed with result 'timeout'.
Sep 24 07:01:17 skarletsky systemd[1043]: Failed to start Podman container-jellyfin.service.
Thanks for the information, it will take some time for me to investigate this problem. My second eye surgery did not go as well as the last. Each day I am getting better. I also started remodeling my home office before my surgeries, the remodeling of my office needs to be done before I will have access to my computer. I am really getting sick of haveing only my android tablet available.
Take your time! I’ll try to figure it out myself. Hope you feel better soon.
Thanks for the well wishes. In one of your previous posts you mention your operating software was Ubuntu Server, why did you use Podmon ( which is Red Hat)? Also what was your goal useing docker with Jellyfin. Why not just follow the instrution for Ubuntu and not install Docker?
I figured why not? I did hear good things about Podman, plus I’m just more comfortable in the Ubuntu land, so I went with it
Isolation, and to avoid dependency hell. My server is also a Nextcloud server, which is currently running on Snap. I am planning on switching out of it for the dependencies that aren’t in the Snap (imported it from when it was a Pi server), such as facerecognition & previewgenerator, but only gonna do it when I know i have the time to finish in a day or 2.
And also, I just wanted to use it, and get familiar with it. My workplace uses it and I figured I should learn, and study how I can use it for myself.
Got it working with a newer Podman from this repo: /repositories/devel:/kubic:/libcontainers:/unstable/xUbuntu_22.04 - openSUSE Download
The autogenerated systemd config was better, too:
# autogenerated by Podman 4.6.2
# Sun Nov  5 04:49:17 UTC 2023
[Unit]
RequiresMountsFor=%t/containers
[Service]
Restart=on-failure
TimeoutStopSec=70
        --cidfile=%t/%n.ctr-id \
        --cgroups=no-conmon \
        --rm \
        --sdnotify=conmon \
        --detach \
        --label io.containers.autoupdate=registry \
        --name jellyfin \
        --publish 8920:8920/tcp \
        --publish 7359:7359/udp \
        --device nvidia.com/gpu=all \
        --security-opt=label=disable \
        --device /dev/nvidia-caps:/dev/nvidia-caps \
        --device /dev/nvidia0:/dev/nvidia0 \
        --device /dev/nvidiactl:/dev/nvidiactl \
        --device /dev/nvidia-modeset:/dev/nvidia-modeset \
        --device /dev/nvidia-uvm:/dev/nvidia-uvm \
        --device /dev/nvidia-uvm-tools:/dev/nvidia-uvm-tools \
        --replace \
        --userns keep-id \
        --mount type=bind,source=/media,destination=/media,ro=false docker.io/jellyfin/jellyfin:latest
ExecStop=/usr/bin/podman stop \
        --ignore -t 10 \
ExecStopPost=/usr/bin/podman rm \
        -f \
        --ignore -t 10 \
Type=notify
NotifyAccess=all
[Install]
Just working on hardware acceleration now, but I’m having trouble with my GTX 1060
