JDK 6 for Mac?
Hey, so I found the JRE 6 for Mac on Apple’s website here:
https://support.apple.com/kb/DL1572?locale=en_US
but I don’t see anywhere for the JDK. Anyone know how to get it?
Install brew and run:
brew install java
EDIT: nvm noticed you need an old version. Not sure how you would do it.
The easiest way would be to download the jdk from oracle
k how do u get jdk 6 from oracle
Can’t find the other earlier versions either
Downloads of legacy JREs and JDKs are available from Oracle.
There is no support for macOS or OS X for Java 6 and prior, though. Presumably that’s what led Apple to release their own runtime implementation.
Are you certain there is a JDK 6 for Mac? Perhaps the intention was only ever to enable execution but not development on Mac.
For what it’s worth, there’s was an OpenJDK effort to port JDK 7 to Mac. Also, this Oracle page states that Java 6 for OS X 10.6 and below should be sourced from Apple via Software Update, rather than from Oracle. As far as I can tell, Oracle never supported Mac before Java 7, and I can’t find any trace of a Java 6 JDK for Mac.
https://www.oracle.com/java/technologies/javaee6sdk-install-jsp.html
For Mac OS X systems, the SDK uses the JDK that is part of the Macintosh operating system. If necessary, obtain the required JDK version from the Mac OS X Updates site.
Based on this quote from above Oracle site Java JDK should be included in OSX.
Is there any particular reason why you want to use Java version 6? It’s really old already and probably not very secure anymore.
Aha, see this Stack Overflow question. It looks like Apple only distributes these files via the (authenticated) Developer site. It’s free to make an account, but I can download one of these for you if you don’t want to make one.
Here are the available Java downloads – presumably the “Developer Package” downloads include the JDK:
  • Java for OS X 2013-005 Developer Package
    Oct 15, 2013
  • Java for OS X 2013-004 Developer Package
    Jun 18, 2013
  • Java for OS X 2013-003 Developer Package
    Apr 16, 2013
  • Java for OS X 2013-002 Developer Package
    Mar 4, 2013
  • Java for OS X 2013-001 Developer Package
    Feb 19, 2013
  • Java for OS X 2012-006 Developer Package
    Oct 16, 2012
  • Java for OS X 2012-005 Developer Package
    Sep 6, 2012
  • Java for OS X 2012-004 Developer Package
    Jun 12, 2012
  • Java for OS X 2012-003 Developer Package
    Apr 19, 2012
  • Java for OS X 2012-001 Developer Package
    Apr 3, 2012
  • Java for Mac OS X 10.7 Update 1 Developer Package
    Nov 8, 2011
  • Java for Mac OS X 10.7 Developer Package
    Jul 20, 2011
  • Java for Mac OS X 10.6 Update 17 Developer Package
    Oct 15, 2013
  • Java for Mac OS X 10.6 Update 16 Developer Package
    Jun 18, 2013
  • Java for Mac OS X 10.6 Update 15 Developer Package
    Apr 17, 2013
  • Java for Mac OS X 10.6 Update 14 Developer Package
    Mar 4, 2013
  • Java for Mac OS X 10.6 Update 13 Developer Package
    Feb 19, 2013
  • Java for Mac OS X 10.6 Update 11 Developer Package
    Oct 16, 2012
  • Java for Mac OS X 10.6 Update 10 Developer Package
    Sep 6, 2012
  • Java for Mac OS X 10.6 Update 9 Developer Package
    Jun 12, 2012
  • Java for Mac OS X 10.6 Update 8 Developer Package
    Apr 19, 2012
  • Java for Mac OS X 10.6 Update 7 Developer Package
    Apr 3, 2012
  • Java for Mac OS X 10.6 Update 6 Developer Package
    Nov 8, 2011
  • Java for Mac OS X 10.6 Update 5 Developer Package
    Jun 28, 2011
  • Java for Mac OS X 10.6 Update 4 Developer Package
    Oct 20, 2010
  • Java for Mac OS X 10.6 Update 3 Developer Package
    Mar 21, 2011
  • Java for Mac OS X 10.5 Update 10 Developer Package
    Jun 28, 2011
  • Java for Mac OS X 10.5 Update 9 Developer Package
    Oct 20, 2010
  • Java for Mac OS X 10.5 Update 8 Developer Package
    Mar 21, 2011
  • Dashcode for Xcode - Late July 2012
    Jul 25, 2012
  • Dashcode for Xcode - March 2012
    Mar 6, 2012
Yeah I’m trying to work with 3D software and I have to learn what works for its time and what does not.
It looks like it’s already there. It looks like it bundles with the file; Apple does not say that it does. You can check for yourselves. It is located in the same directory as the JRE.
Macintosh HD > Library > Java > JavaVirtualMachines >
Here you can also find other Java versions too.
