My mom needs a program called Blackboard Collaborate. It is written in Java and runs fine however, it has an audio issue. The sound sounds choppy to the point that it make it so she can not understand what is being said on the other end. I look in the sound and volume settings for pulse audio. The program "Java ALSA Plugin" keeps flickering (like a light might do) like it is being started and stopped quickly but at random intervals. This seems to be the cause of the issue. Her computer is running Manjaro Gnome. Does anyone know how to fix this issue? Any help would be appreciated. Thanks in advance.
open up a terminal and type in
alsa-mixer
Should give you a starting point
Thanks for the response @Dje4321. I tried that command but it returned
zsh: command not found: alsa-mixer
I tried
pacman -Ss alsamixer
but it returned nothing so I ran
That returned
extra/gnome-alsamixer 0.9.7-3
Gnome ALSA mixer
Should I install Gnome ALSA mixer, or is there something else I should do?
whoops my bad.
alsamixer
not
alsa-mixer
