Alright. I’ve been having issues with this the past five or so hours.
I installed Linux Mint 21.2 on my girlfriend’s computer, as she had to get more storage and then the Windows 10 license stopped working after changing the SSD. No worries, she was fine with trying out Linux, as she’d seen me use it.
Everything worked fine out of the box, except for issues with the built in fractional scaling. Easily fixed by just using 100% scale and then upping the font size.
The issue now is that when the laptop is under heavy stress (sometimes when it’s just idling) White lines appear for a fraction of a second.
Apparently this is caused by the driver wanting to use 2 DP lanes @ 8.10 Gbps instead of 4 DP lanes @ 5.40 Gbps.
[Link redacted]
According to this forum post, it works in nvidia 450. I tried getting that installed, without luck. It’s not supported anymore. I tried using the nvidia-dkms-450-server package instead, that installed and worked. The white lines were gone! The issue is that Steam refused to open, and pretty much every OpenGL/Vulkan application. I saw in the nvidia-settings that it did now run at 4 lanes instead of 2.
I also tried switching from Discrete graphics to Switchable graphics, as a few posts online said it made a difference with other Lenovo laptops. This just made Linux Mint not show anything. CTRL+ALT+F1 gives me a text-prompt as usual, but CTRL+ALT+F7 is just black with a little dash in the top left corner.
Does anyone of you know how to force Linux to use 4 lanes instead of 2? Or how to install nvidia-450 on a modern Linux distro? Or how to switch to Switchable graphics?
(Sorry for the new account, I couldn’t access my old one that only had a few posts anyway)
Thank you for your replies.
