Hey all,
I’m having a weird issue that when I press “Caps Lock” in my keyboard, my mouse stops working. All drivers and firmwares are up to date and I made tested the configuration with both keyboard and mouse wireless vs wired (and any combination of the two).
I tested the same thing with a different mouse (Logitech MX 3) and it worked fine. Unfortunately, I don’t have another keyboard to test it with the Pro X.
Another interesting fact is that remapping the Caps Lock key with SharpKeys (Windows) and Karabiner (MacOS) makes the mouse stop hanging too.
Any suggestions on what could be happening?
Are you using registry tools to do custom key mapping?
Also is NKRO enabled on the Keychron?
What ports are you plugged into, the HID ports, or the USB Switch/Hub ports?
Which devices are plugged into which?
Yeah, it’s all done via registry changes
No
Both mouse and keyboard are plugged into the HID ports, but the keyboard is connected to bluetooth most of the time.
If I plug my mouse into a USB 3 port, it stops hanging when I press Caps Lock.
I have a webcam (Logitech C922) and microphone (Blue Yeti X) plugged into the USB 3 ports (front and back respectively).
Keyboard and mouse are in the back HID ports (tried different ports and had the same result).
All 4 DP cables are connected. 2 coming from my Macbook Pro using CableMatters USB C to DP cables and 2 from my PC with Club3d DP cables connected to the GPU.
I would start by disabling that. The K8 supports QMK which is much better for remapping keys as its stored on the keyboard firmware. Also you can create macro’s as custom key’s that will pass the KVM HID ports.
Home - SonixQMK Docs (Note Bluetooth is not yet fully supported)
If resetting the Registry does nothing next try plugging the keyboard in directly not via a BT dongle.
So the problem is when I don’t have any remapping enabled. If the Caps Lock is pressed in the base keyboard, the mouse stops working until I reconnect it. It happens both when I’m in wired mode or not.
Remapping the Caps Lock key is the way I found to side-step the issue I’m having.
Also, If I remap any other key to act as the Caps Lock, it also makes the mouse stop working
can you see what is detected when you hit caps lock on this site, and do it with and without the registry hack?
with caps lock → left shift remap
without remap
Ok, been thinking on this some more, can you plug the Mouse into one of the NON HID ports?
Some gaming mice dont like being intercepted by the KVM firmware.
For example I had a razor mouse that would never work on the HID port.
Yeah it works with the USB 3 port, but both are already being used by other devices
Do you know if connecting a usb hub in one of those ports would cause issues? If not, that could be a solution for me
USB Hub should work no issue.
Can you plug both the mouse and keyboard into USB ports direct on your windows system and run USB Tree View?
Expand the nodes I want to see what it reports as the controllers.
For bonus points, also connect the MX3.
And now with the KBD/Mouse plugged into the HID ports on the KVM?
What motherboard, and when did you last update the Bios?
Just realized your on an AMD board!
I’m using a Asus B550-F Gaming (Wifi), haven’t updated the BIOS yet
The whole build is a week old
ok, can you check the bios version? There is a very slim chance that the AMD Bios bug is causing this.
It looks like after v2006 the USB bug is fixed.
BIOS Version/Date American Megatrends Inc. 2403, 6/16/2021
I’m still a bit behind on latest BIOS, but I should have the fix.
I’ll try to update it to the latest version anyway and see what hapens
yep…
Well my best suggestion is a USB hub then. maybe @wendell has another test or guess, but it seems like the mouse is not playing nice.
