Return to Level1Techs.com
Issues with GPU passthrough on MSI B450M mortar & Looking for X570 buyer's guide
CPU: Ryzen 3900X
Motherboard: MSI B450M mortar
BIOS: tried 7B89v1B, 7B89v1A, 7B89v19, 7B89v17
GPU: RTX2060 Super and RX580
OS: Proxmox 6.0
Configuration:
/etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet amd_iommu=on iommu=pt video=efifb:off rootdelay=10"
/etc/modules
vfio
vfio_iommu_type1
vfio_pci
vfio_virqfd
/etc/modprobe.d/blacklist.conf
blacklist nouveau
blacklist nvidia
blacklist nvidiafb
blacklist snd_hda_codec_hdmi
blacklist snd_hda_intel
blacklist snd_hda_core
blacklist radeon
blacklist amdgpu
/etc/modprobe.d/kvm.conf
options kvm ignore_msrs=Y
/etc/modprobe.d/vfio-pci.conf
options vfio-pci ids=1002:67df,1002:aaf0 disable_vga=1
  1. If I put RTX2060S in slot 1 (cpu) and RX580 card in slot 3 (pch), iommu will broken during os initialization like this:
    It boots when i use only one card (both slot 1 and slot 3 works) or change two cards’ position, so there may be some issues with amd’s gpu and chipset (when there’s also an nvidia card plug-in).
  2. If i start kvm with pcie passthrough, there will be some outputs in dmesg like this, vm will run out of all available rams and no video outputs:
    Aug  2 18:30:27 BelliashPC kernel: pcieport 0000:00:03.1: AER: Uncorrected (Non-Fatal) error received: 0000:00:03.1
    Aug  2 18:30:27 BelliashPC kernel: pcieport 0000:00:03.1: AER: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
    Aug  2 18:30:27 BelliashPC kernel: pcieport 0000:00:03.1: AER:   device [1022:1483] error status/mask=00100000/04400000
    Aug  2 18:30:27 BelliashPC kernel: pcieport 0000:00:03.1: AER:    [20] UnsupReq               (First)
    Aug  2 18:30:27 BelliashPC kernel: pcieport 0000:00:03.1: AER:   TLP Header: 34000000 07000010 00000000 00000000
    Aug  2 18:30:27 BelliashPC kernel: pcieport 0000:00:03.1: AER: Device recovery successful
I have tried the same card on intel platforms and it works, so it shouldn’t be problem with vbios.
It happens whether i put the card in slot 1 (cpu) or slot 3 (pch).
I have tried multiple BIOS with no luck, and i have seen similar problem here for problem 1, maybe it’s not fixed for a long time: VFIO / PCI Passthrough Saga, a tragedy in 3 parts
So i think i should buy X570 instead. I want to buy MSI MEG X570 Ace, because it’s cheaper in my country and I like MSI’s BIOS way more than Gigabyte’s, but there’s very few comments about it in this forum.
I found someone who shows an iommu group with this board:
IOMMU group 10:  [1022:1482] 00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
                            [1022:1484] 00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
                            [1022:1484] 00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
                            [1022:1484] 00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
                            [1022:1485] 30:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
                            [1022:149c] 30:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
                            [1022:1487] 30:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
                            [1022:7901] 31:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
                            [1022:7901] 32:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
https://ngabbs.com/read.php?&tid=18238681&pid=358926295&to=1
It doesn’t look that good, and i’m not sure if it can be fixed in further BIOS updates. This guy also has problem 2 like me. Someone says it appears after flashing 1.0.0.3ABB microcode, but i have this problem also in older BIOS versions.
I also see that Linus Tech Tips uses ASUS C8H as its MacOS+Windows dual boot build.
Can anyone give me some advice? Thanks
I have the ace and will test in a bit.
Did you set iommu to enabled from auto? Auto is often only a partial enablement
Pcie acs may also need to be on
  1. Yes
  2. Sadly not found such option in MSI’s BIOS
    Another weird thing is that when i plug in two cards, it will always use the card in slot 3 as primary video output card, not the card in slot 1 which has x16 speed. Primary video card can also not be modified in BIOS
MSX X570 ACE IOMMU Groups
0 00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 61)
IOMMU Group 10 00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
IOMMU Group 11 00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0 [1022:1440]
IOMMU Group 11 00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1 [1022:1441]
IOMMU Group 11 00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2 [1022:1442]
IOMMU Group 11 00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3 [1022:1443]
IOMMU Group 11 00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4 [1022:1444]
IOMMU Group 11 00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5 [1022:1445]
IOMMU Group 11 00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6 [1022:1446]
IOMMU Group 11 00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7 [1022:1447]
IOMMU Group 12 20:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57ad]
IOMMU Group 13 21:03.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 14 21:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 15 21:05.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 16 21:06.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 17 21:08.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
IOMMU Group 17 2a:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
IOMMU Group 17 2a:00.1 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
IOMMU Group 17 2a:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
IOMMU Group 18 21:09.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
IOMMU Group 18 2b:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 19 21:0a.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
IOMMU Group 19 2c:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 1 00:01.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 20 25:00.0 USB controller [0c03]: Renesas Technology Corp. uPD720201 USB 3.0 Host Controller [1912:0014] (rev 03)
IOMMU Group 21 26:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03)
IOMMU Group 22 27:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. Device [10ec:8125]
IOMMU Group 23 28:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a)
IOMMU Group 24 2d:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] [1002:67df] (rev e1)
IOMMU Group 24 2d:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] [1002:aaf0]
IOMMU Group 25 2e:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP106 [GeForce GTX 1060 6GB] [10de:1c03] (rev a1)
IOMMU Group 25 2e:00.1 Audio device [0403]: NVIDIA Corporation GP106 High Definition Audio Controller [10de:10f1] (rev a1)
IOMMU Group 2 00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 3 00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 4 00:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 5 00:03.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 6 00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 7 00:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 8 00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 8 00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 8 2f:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
IOMMU Group 9 00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 9 00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 9 00:08.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 9 00:08.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 9 30:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
IOMMU Group 9 30:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
IOMMU Group 9 30:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:1487]
IOMMU Group 9 31:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 9 32:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
lhost ~]$ cat /proc/cpuinfo  |grep micro
microcode	: 0x8701013
gonna update the bios & reboot.
Seems like Gigabyte is still the best choice right now.
How about ASUS C8H?
Welllll just because gb offers more historical bioses with flexible iommu. As of latest/Abba on gb the iommu situation isn’t great either.
It’s the agesa … I can’t turn on pcie acs to get the groups back anymore either.
Have to stick with abb agesa version :-/
There is no real perf gain over Abba anyway.
Asus is ‘better’ because they have been glacial about bios updates. :-/
here is the ace IOMMU which is… curiously good?
This is on 1.50 7C35V15
./ls-iommu.sh
IOMMU Group 0 00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 10 00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 61)
IOMMU Group 13 21:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 14 21:02.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 15 21:03.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 16 21:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 17 21:05.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 18 21:06.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 19 21:08.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
IOMMU Group 19 2a:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
IOMMU Group 19 2a:00.1 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
IOMMU Group 19 2a:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
IOMMU Group 20 21:09.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
IOMMU Group 20 2b:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 21 21:0a.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
IOMMU Group 21 2c:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 22 22:00.0 Non-Volatile memory controller [0108]: Intel Corporation SSD Pro 7600p/760p/E 6100p Series [8086:f1a6] (rev 03)
IOMMU Group 23 24:00.0 Multimedia video controller [0400]: Blackmagic Design Intensity Pro 4K [bdbd:a139]
IOMMU Group 24 25:00.0 USB controller [0c03]: Renesas Technology Corp. uPD720201 USB 3.0 Host Controller [1912:0014] (rev 03)
IOMMU Group 25 26:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03)
IOMMU Group 26 27:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. Device [10ec:8125]
IOMMU Group 27 28:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a)
IOMMU Group 28 2d:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] [1002:67df] (rev e1)
IOMMU Group 28 2d:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] [1002:aaf0]
IOMMU Group 29 2e:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP106 [GeForce GTX 1060 6GB] [10de:1c03] (rev a1)
IOMMU Group 29 2e:00.1 Audio device [0403]: NVIDIA Corporation GP106 High Definition Audio Controller [10de:10f1] (rev a1)
at /proc/cpuinfo |grep microcode
I had been onv c14 so I was on an earlier version. This iommu setup seems pretty good for vfio – gpu config is RX590 in primary slot, GTX1060 in secondary slot, blackmagic in last x16 slot and usb controller in x1 slot between two GPUs.
intel nvme in nvme slot to cpu
Thanks a lot for your effort :slight_smile: It’s pretty good right now
Also it’s convenient to message Toppc Lin and give MSI engineers some advice, maybe i can have some expectations for MSI in the future :joy:
Bought MSI X570 Ace Today, Problem 1 disappears, Problem 2 exists
I found this weird workaround and it works:
Is nothing at all plugged into the GPU? You might need a dummy plug because gpus try not to wake up if nothing’s plugged into them (some gpus) I
I have plugged cables into both of them, so i don’t think it’s related.
Maybe wake up from S3 does some job about initialization, which fixes that error.
Neither Nvidia or AMD card works without doing these procedures.
Because both ASUS and MSI board have this problem, i guess it’s yet another microcode issue.
