I have a Dell Precision 7820 that came with a Quadro RTX 4000 and i installed a 2nd Nvidia GPU RTX 3060 to get more vram for local AI training.
The RTX 3060 shows up fine but, the Quadro RTX 4000 no longer shows up and i find the following error below when i run sudo dmesg | grep -i nvidia. Is there a way to fix this?
ERROR [nvidia-drm] [GPU ID 0x00000400] Failed to allocate NvKmsKapiDevice
Things I have confirmed:
Both cards show up in the BIOS.
Both cards show up when running lspci | grep NV
04:00.0 VGA compatible controller: NVIDIA Corporation TU104GL [Quadro RTX 4000] (rev a1)
d5:00.0 VGA compatible controller: NVIDIA Corporation GA106 [GeForce RTX 3060 Lite Hash Rate] (rev a1)
Both cards can use the same NVIDIA driver I have installed which is 595.71.05.
Troubleshooting steps I have tried so far:
Reinstalling Nvidia drivers with sudo dnf reinstall akmod-nvidia -y
Adding the open driver to kernel and rebuilding akmod(Based on this answer I found on the Fedora forms)
sudo sh -c 'echo "%_with_kmod_nvidia_open 1" > /etc/rpm/macros.nvidia-kmod'
sudo akmods --kernels $(uname -r) --rebuild
