Issue using USB C combiner with USBC DP1.4 KVM
KVM Model:
CAAB-P3112-12
5
Problem:
I have a L1T USB C Combiner that I recently purchased to use with my L1T USBC to DP1.4 KVM.
However I cannot seem to get a video output from the graphics card through the combiner, through the kvm and to the monitor.
The KVM works with a standard USB C input such as a MacBook or my old 6900xt.
I have had the USBC combiner working with a 5090 graphics card to a USBC input monitor.
But I cannot get them both working together and I have no idea why.
I have tried:
Different DP cable from the video card to the USBC combiner. Tried 3 different ones.
Different USBC cable from the USBC Combiner to the KVM. Tried the one that comes with the USB C combiner plus 3 or 4 others.
WIth USBC Combiner aux power via a separate power supply
Without one and both USB cables
with 4lanes and 2 lanes on the usbc combiner
With 4lanes and 2 lanes on kvm
Different display ports on the gpu
I have basically run out of different things to try to figure out what is wrong.
Some additional quirks.
Since I have had the KVM it has exhibited random black screens that last for maybe 1 second. This was most noticeable with the 6900xt. I tried multiple different usbc cables but the problem never really went away. This black screen also would occur on a MacBook m3 pro as well as a hp specre windows laptop though to a lesser extent.
When I first got the usbc combiner setup with the 6900xt the screen would flicker, it would show a 1 second image and then go black for 5 or so seconds. I figured it was a bandwidth issue and tried to fix it by changing cables, change lanes. Couldn’t get it resolved. After switching/plugging and unplugging for a while it just wouldn’t show a picture at all, but the monitor would have a back light that seemed to indicate the monitor saw a display signal.
Eventually I changed the DisplayPort version on the monitor to DP1.2 and the picture worked. That seemed to indicate to me that it was a bandwidth issue but I don’t understand why. The KVM will work in dp1.4. The same cables from the usb c combiner work with a usbc monitor.
Even with this “success” previously with the DP1.2 adjustment and the 6900xt, it doesnt work with the 5090 + USB combiner. Still a black screen
THe DisplayPort monitor is the 38WN95C-W, and the USBC monitor is the LG 32UN880-B.
At this point I can totally out of ideas beyond maybe firmware updates for the 38WN95C-W.
I guess I could try and use the USBC + Combiner with the 32UN880-B to see if I can rule in or out the monitor.
Any help with this issue would be much appreciated
Thanks
