Issue playing Fallout 76!
Here goes it…
I can no longer play fallout 76 due to the game stuttering and lagging. As in I’m dead and re spawned just as the you’ve died animation starts to play.
Bethesda’s response was to “upgrade to windows 7 / 8 / 10” as it’s the only supported oses at this time. Regardless of the 1800 hours I have played the game and over 500 of those have been thru linux.
So far I’ve tried reinstalling the game. Reinstalling steam and the game. Reinstalling the os and the game. I’ve also tried the older nvidia driver. Lowering the graphics resolution from ultra to low. Same issue come up! The couple of other games that I’ve gotten up and running seem fine so far!
What I don’t have is a spare video card to try out in case it’s actually the video card starting to die on me. This has also having me ask what tool are there for stress testing hardware that has a linux installer?
Current graphics card is a nvidia 2060 from msi. And I know the card is 5 years old at this time. I don’t have a spare and open to option if I can figure out if it’s actually the card dieing!
Thanks in advance!
What I do in these cases is boot into the last known working snapshot. Will eliminate any software-related problems in a minute. With online games and required mandatory version to play, this is somewhat more difficult. But it narrows it down to hardware or latest version being the problem
Aye. Since I don’t have snapshot setup this was my way of testing / trying to eliminate the client side of any issues.
If other games are fine but 76 is causing problems…I would hazard a bet it’s the game itself or a weird update. I would hold off for about a few months and see if it clears itself out.
Yea… that’s kinda where i’m heading … just what game do I switch to in the mean time? I still need to test with a decent game and not just the games that take 5 minutes or less to download.
I don’t play games as much as I used too however the most demanding game I have played lately is Baldur’s Gate 3. Most games are not very demanding that I usually play.
Try this one
I’ve not played 76 for awhile now so may have to test it and see if I notice anything similar.
I know that Juicehead has done a video on 76 recently stating that there is something broken with the latest update, not sure if this is related or not.
The answer seems pretty clear to me - report the Linux instability and stop playing/supporting games for companies that don’t support the only OS you’ll use. MMOs are like rivers - enjoy the time you’re in them, because it’s ‘sunk cost fallacy’ to believe they’ll be to your tastes forever. Maybe it’s time to enjoy games that do support your OS officially?
I know that isn’t exactly a solution to your problem, but honestly the long-term answer can only come from the parent company. If they aren’t supporting Linux, and you aren’t willing to use the officially supported Operating Systems, any ‘fix’ today is a stopgap measure at best until the next issue happens along(which it will in the ever-changing world of MMOs). Happy gaming!
Thank you! I’ll give it a go!
Be interested in what you find out… Ironically enough a new nvidia device driver was just released… will know in a little bit if that helps at all!
Ok so I did what needed to be done and installed windows 11. That took WAY to long to do so and got everything “configured” down to a useable / reduced spying environment. I’m now confident enough to say it’s the nvidia driver in linux. Once I’m done backing up this instance of windows (never know when I might need to uses it again) I’ll be back on linux in 1/5 the time!!!
Well I may have thought wrong in my previous statement. I’ve reinstalled mint 3 times in order to try and get the nvidia driver and the 32bit i386 libraries for steam installed … still don’t think I did it right. with to no avail!
Then I figured I’d give manjaro a go and see if it’s just an issue with mint. Nope. Same stuttering issue.
I even tried Nobara as a third os as it has most of the stuff configured right out of the box. No dice. Same issue.
So I’m either seriously messing something up or the graphics driver update and the games update have screwed something up with steam / proton and that’s where another update needs to happen.
Wondering if I’m going about this all wrong! Please let me know!
Since Bethesda updated the games after the last time you played, Have you tried using Proton Experimental or the community version of Proton?
Proton experimental is usually what I have steam defaulted to. I tried 9.0.8 or 3 in one of my testing iterations with no luck.
Did you purchase Fallout 76 from Steam or Bethesda? If you didn’t, I might have an idea. Could you try the latest version of Wine?
I’m pretty sure that I purchased the game thru steam. Not many games these days that I don’t purchase thru steam!
Give me a bit to get my system back to a fully functional state and I’ll give the latest version of wine a go!
Ok. So I’ve given wine a go and no changes to the issue.
I did find something that has finally allowed me to play with out the stuttering but not optimal or the way I’d like to play.
The short term answer is to set the display resolution to my monitors native resolution. Turn up the graphics preset to ultra and then turn down the textures preset to medium. This baffles me as to why this issue is creeping up now and if there is something I can do to fix it short of getting a new graphics card (currently running a nvidia 2060 with 6gb memory) and psu (current psu is not a 3.0 type that most new gpu’s require).
Figured this out as the game display options were all screwed up on a clean install and I had just changed the resolution of the screen and launched the game vs setting the resolution and graphics quality at the same time like I normally do.
Any other thoughts / suggestions?
Thanks to everyone for the help.
That worked for a day! I can at least play for 5 - 15 minutes before the issue returns. Then completely exit the game and wait 10 seconds before restarting the game.
My only other idea is that your graphic card’s thermal paste needs to be replaced. I don’t think waiting a few months and hoping Fallout 76 fixes itself won’t fix the issue since stuttering is the issue.
