Hello there, Level1dwellers.
One day I port scanned all of the devices on my network.
And I’ve found that my ISP router has an SSH port opened, which made me curious. So I tried common combinations to brute-force it, but could not guess the credentials.
So I’ve looked online on how to get there, and I have found that there’s a higher user called ‘superadmin’
I called my ISP to get the creds, yet they played dump or didn’t get what I wanted.
So I looked into an exploit database, and I’ve found a patched exploit dates back to 2015 for an older firmware and an older model. (here)
I read it, and I’ve found that exploit showed that they did use an unencrypted base64 to store the passwords into the config file. (Extremely dump btw
The exploit also explains on how to extract the config file, cause you can’t extract it normally from the UI. You have to do a certain post request.
I tried to extract the config using the post request, but it did not work.
tho after trying my public IP instead it did work, and I got the config.
The password was encrypted tho with something a bit different than an unencrypted base64 (xD)
After further inspection I felt that it was just a salted base64.
So, I kept changing my regular admin password.
- make a new password > plain text password
- check the password change post request > shows an unencrypted base 64 password
- backup > shows an encrypted base64 password
After gathering those samples I was able to generate a simple model to reverse all the passwords from the config. Yep they were all encrypted with the same salt… ![]()
- the firmware is actually not that old…
And wahaaaw I got the superadmin password. Yep as well as the SSH creds
Takeaway here
- ISPs are dump
- Somehow the hardware devs are incompetent.
- Much worse vulnerabilities could happen and a patches like this are insufficient!
- Trust not your ISP’s router.
- A useless ssh session
* * To be fair I was able to figure out on how to automate too many things, but I use pFsense already…
-pakxo.
