[img]http://i3.photobucket.com/albums/y92/Terratora/Capture_zpsea33a670.png[/img]
Speccy says 28C.
The warning is from AI Suite 2.
Intel i7-3770K overclocked to 4.2GHz on a Asus P8Z77-V Pro motherboard.
Speccy says 28C.
Now this...
[img]http://i3.photobucket.com/albums/y92/Terratora/Capture_zps4c8b96cb.png[/img]
you need to tweet when asus warns you about temps, I get voltage and fan warnings just because I have not tweaked the asus software to warn when it dangerous
Sorry if I'm being a n00b but i don't understand what you mean.
It's software-related, for sure. Use Speedfan and Core Temp to try and find your ACTUAL temperatures.
I've found AI Tuner to be hit-and-miss on non-ROG motherboards.
8 years later ?
Necros are considered posts bumping a thread older than 6 months. Unless the intended post is directly pertinent to the topic it is recommended to create a new thread.
