Is this a good burn in option for my first TrueNAS system? (badblocks)
Debating on which exact test to run.
Supposedly this one is a good middle ground, would take 2-3 days for each batch of 3 drives tested.
Would running this badblocks test, that’s ~2 passes, be a good solution? Or what do you guys think?:
  • badblocks -nsv (badblocks non-destructive)
  • 3 drives at a time (out of 6 total, to prevent overheating system)
Exact command I’d run (for 3 drives):
badblocks -nsv -b 4096 -c 65536 /dev/sda &
badblocks -nsv -b 4096 -c 65536 /dev/sdb &
badblocks -nsv -b 4096 -c 65536 /dev/sdc &
My specs:
  • Case: Cooler Master HAF 922
  • CPU: AMD Ryzen PRO 4750G
  • Motherboard: ASRock B550 Pro4
  • RAM: 64GB UDIMM ECC (2 x 32GB Kingston KSM26ED8/32HC 2666 CL19 ECC 288 PC4)
  • NAS HDD Hard Drives: 6 x WD Ultrastar DC HC580 WUH722424ALE604 0F62798 24TB 7.2K RPM SATA 6Gb/s 512e 3.5in Recertified Hard Drive
  • Mirrored Boot OS SATA SSDs: 2 x Intel SSD DC S3700 200GB (used enterprise gear)
  • Fans
    • Front: Noctua NF-A20 PWM (200mm x 30mm Fan)
    • Rear: NF-A12x25 G2 PWM (120mm x 25mm)
    • Bottom: NF-A14x25 G2 PWM
    • PCI-e Cooling: Noctua NF-A9 PWM 92mm Fan
  • HBA Card: LSI 9305-16i
  • PSU: Corsair RM850x
Just run a long/extended smart test on each drive, you’re still concerned just do a pass with dd using a sane blocksize.
The thing I would want to know is this:
Can I read back the same data that I’ve written.
In that regard a non-destructive test is somewhat lacking.
Personally I’ve opted to just write my data and run a scrub / verify occasionally.
I like the smart test idea too though.
I have a few layers of software block antics going on so I like the e2e nature of restic check --read-data and other high level validations, (a ZFS/btrfs scrub is sort of a middle level validation.)
Smart long test only does a full read test, I believe.
you don’t need the non-destructive option on new empty drives. Non-destructive is for drives with data you’d want to keep.
I don’t think it makes sense testing drives 3 at a time. If all drives running overheats you need better cooling, since I assume you’ll use some kind of redundant raid and probably the drives will run at the same time in real use too. See it as a test of your cooling setup..
personally I’ve done a single badblocks test on new drives and then a scrub after filling them. Two full passes with large drives is a lot and takes ages. But if you have the time and motivation why not?
