Hey guys, i wonder if this would be a fine pc for gaming.
NZXT Phantom 410 CA-PH410-B3 Black Steel / Plastic ATX Mid Tower Orange Trim Computer Case
ASUS P8B75-M/CSM LGA 1155 Intel B75 HDMI SATA 6GB/s USB 3.0 Micro ATX Intel Motherboard
ASUS GTX 560TI-DC20-1GD5 GeForce GTX 650 Ti 1 GB 128bit GDDR5 PCI Express 3.0 x 16 HDCP Ready Video Card
CORSAIR XMS3 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMP8GX3M2A1600C8
CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31 / EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
Dont care with the CD Drive - Just going to grab some random S***
Crucial V4 CT128V4SSD2 2,5'' 128GB Sata II MLC Internal Solid State Drive (SSD) SSD Only
Intel Core i5-3550 Ivy Bridge 3,3GHz (3,7GHz Turbo) LGA 1155 77W QuadCore Desktop Processor Intel HD Graphics 2500 BX80637I53550
Windows 8
Please help me quick
$1000? Where do you live? Could you provide links to where you got those?
I just took a glance at it, but I don't why that should come to $1000....
OS http://www.newegg.com/Product/Product.aspx?Item=N82E16832416550
MB + ram http://www.newegg.com/Product/Product.aspx?Item=N82E16813130644 (the asus board isnt bad but you cant add more than 1 gpu.)
GPU http://www.newegg.com/Product/Product.aspx?Item=N82E16814102983 (if you need cuda atlest get a 660) amd is killing the 600 series right now. with the new drivers the 7000 series got a 15% improvment in fps
psu http://www.newegg.com/Product/Product.aspx?Item=N82E16817153136 (this one is good i put it in a friends pc and he has a 2600k and a 7970 both ocd)
ssd http://www.newegg.com/Product/Product.aspx?Item=N82E16820227791 this one is a S+++ tone faster than the one you picked out.
cpu http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504 so the cpu you had wont overclock very well so for $5 more a K edition (unlocked for overclocking you should get an H100 at some point)
the same case... that one is nice looking and the cass is a prefrence thing and that one will fit an h100 and lots of stuff.
lastly audio if you dont want to get a sound card then atlest get a usb headset
