I have done a fair amount of research but I would like to know if I have missed something before I make a purchase. Thanks in advance! http://pcpartpicker.com/user/Mentalevo/saved/1ZbK I'm not really asking for a debate whether Nvidia or AMD is better for I have already made my decision, again I'm only asking if my parts are COMPLETELY compatible and if I will run into problems setting up the build, and again, if so please specify the fix for the problem(s).
CoolMax PSUs are usually garbage. I'd suggest getting a Corsair, XFX, Seasonic, or Antec PSU.
That motherboard doesn't support an FX-8350
That board isn't exactly the best for an eight core CPU. I would recommend something like this:http://pcpartpicker.com/part/asus-motherboard-m5a97r20.
http://pcpartpicker.com/part/asus-motherboard-m5a99xevor20 would be ideal.
http://pcpartpicker.com/part/asus-motherboard-m5a97r20 can work if you don't have the extra budget.
Thank you for responding so quickly! I really do appreciate it, http://pcpartpicker.com/user/Mentalevo/saved/#savedbuild_461195 As long as you are here to help, are there any other major problems that I could run into?
Looks good to me now.
