Is there any fan hub smart enough to report tachometer readings from multiple fans? I figure something would have to report via USB or PCIe, but I can’t seem to find anything.
Like this wonderful device?
“https://www.noctua.at/en/products/na-fh1”
EDIT:
Looks like it does not in fact provide per fan RPM data, just one of them. They are PWM signals, which means any MCU could count them.
I opted for Pi Pico with my 6 fans system(not a computer, but PWM computer fans) with a relay board, it manages temps with about ~$19 in parts. which was cheaper than the $40 Noctua hub
Correct. That’s the way all the hubs I see work–which is exactly the problem I’d like to avoid. Given how expensive everything is now, I want a tach signal to let me know when any fan is down. Notice how all heck breaks loose if you pull out a hot swap fan from a server.
I use an Aquaero from Aquacomputer, it would be overkill and expensive just for a few fans -limited to 4 channels I think-, but it is perfect for monitoring and controlling fans + pumps + temps + NvidiaShittyPowerConnectorCurrent. It has quite flexible software for reporting. They have Poweradjust too, simpler and cheaper, but it is only one channel per device; you can have many but becomes expensive pretty fast.
If you don’t want to deal with DIY options are pretty limited, if you don’t mind tinkering and developing your own software, then there should be lots of options.
They mention each fan being monitored which is displayed through an illuminated indicator on the controller.
Alphacool has the ES Guardian which can be connected to a piezo-buzzer for audible alarm.
Minimal 4-Fan BOM
- 1× Pico $5
- 4× 2N7002 $1.35
- 4× 10k tach pullups $0.20
- 8× 100Ω resistors $0.80
- 1× 100 µF capacitor $0.10
- 4× 4-pin PWM fan headers (hard to find fresh stock, lots of cables and adapters exist. Honestly any 4 pin cnnector works, I used old fan cables and headers)
You need a soldering iron, and a breadboard if you aren’t comfortable floating components.
You also will need to program the pico, but it’s made to be easy, I think micropython is wonderful.
Also you can get the above in a built product for $0.99 “https://www.aliexpress.us/item/3256809348845533.html” with a screen, but you need one per fan. DRO style
