I've heard that there are only like 18 (somethings) for motherboards, and if there are more than that, that they share bandwidth with each other, and in this case that's the m.2 sata and pcie 2 or 3 slot and another thing i think..
So what I was wondering is what are the pros and cons of this motherboard and what are some of the features of this motherboard that are better on other boards?
It's this motherboard but without all the accessories:
I am leaning toward the MSI that Wendell reviewed a couple days ago. I was sold on the audio amp to both front and rear panels. I like my headphones! and it is $100 cheaper
Well I definitely want all of those usb ports for sure, I use a lot of those, I also want that option to have a 2nd graphics card if I ever get the money to put a 2nd one in there and I need a few extra regular Sata 6Gb ports.
I will be using the computer for a mixture of gaming and music production so I want to have at least one SSD for OS and production programs and then I may get a second SSD for production files later (if that would be beneficial?)
And then i'd also have an optical drive and about 3-4 HDDs
What i'm mainly worried about though is this, to quote:]
"*1 : The PCIe x16_3, USB3_E56 and SATAExpress_E1 connectors share the same bandwidth. The PCIe x16_3's default setting is in Auto mode that automically optimizes the system bandwidth. If you use two of these connectors, the system automatically disables the unused connector. *2 : M.2 Socket 3 shares bandwidth with SATAExpress_1"
In the most likely scenario I will be using ALL usb ports, one PCIe lane, 4 Sata ports, and the m.2 Sata port for my OS, would I run into any conflicts there in regards to bandwidth sharing do you think?
