Is the MSI Z170A GAMING M5 Compatible with these parts
Hello Community, I'm wondering if there are any compatibility issues with these parts and the MSI Z170A GAMING M5 motherboard.
SSD: Intel SSD 600p Series (512GB, M.2 2280 80mm NVMe PCIe 3.0 x4, 3D1, TLC)
GPU: MSI GeForce GTX 1070 DirectX 12 GTX 1070
Also is the motherboard compatible with the Asus ROG SWIFT PG248Q 24.0" 180Hz Monitor
I ask because the motherboard says it only has a DVI connection and the monitor has display port and hdmi connection. I am not sure if that will have any compatibility issues.
Thanks!
your gpu will have display port and hdmi and that is what you will plug your monitor into.
Ah that makes sense, thanks
Sure, looks like everything will work nicely toghether. If you have this kind of doubts pcpartpicker can help you to avoid major incompatibilities (doesen't take into account things like spacing issues between parts etc.).
