Hello, I was looking at the Gigabyte Aorus RTX 5090 AI box to use for work. We run a laptop but need access to a full desktop GPU. We don’t need the bandwidth the TB5 provides, but for the price to include the eGPU enclosure and the GPU/PSU, it is kinda a steal as everything around me puts the GPU alone slightly less and going the route of some of the other boxes would pump the cost up. My question is has anyone actually used one with Linux? The goal is to be connected to a laptop and running the GPU for work when directly connected in high GPU utilization jobs but not for gaming. Any recommendations around other solutions would be helpful as well. I know Nvidia doesn’t play nice with Linux, but we need it for the CUDA cores, and AMD doesn’t run anywhere close to as fast as Nvidia cards for it.
I don’t have direct experience with the AI Box, but after reading its specs, the only concern I can see is related to the TB5 connection and driver support, not Linux–NVIDIA integration.
It’s worth checking whether your laptop supports USB4 eGPU connectivity.
You can also take a look at these resources:
Thunderbolt Linux eGPU
External GPU - ArchWiki
Thanks, this is very helpful.
