So I have returned two 980s already, this is my third and all of them have coil whine... I have a Corsair CX 750m PSU so I am sure it is enough power... It is very light coil whine when gaming on ultra, when playing heavily modded Skyrim it gets pretty loud. I am ok with the noise as I use closed headphones, I would like to know, is it safe if I keep playing with the coil whine? I heard both yes and no so I am confused if this is ok...
Some more info: It is the Asus GTX 980 Direct DCO2 Factory OC
The way I installed it was by plugging one 6 pin from the psu to the card, and connecting the other 6 pin to the little split adapter thing that came with it and plugging that into the other 8 pin on the card (I think it was 8) I hope this isn't the cause. But I'n sure I installed it right....
I'm really happy with my PC, and if it wasn't for helpful forums like this I would not be building it because I don't even computer. Thanks all for the help so far.
