Hello,
My company currently has an old Arista switch which utilizes 6x QSFP+ ports at a max of 40 Gbps.
Switch: Arista 7050SX-72Q
I was tasked with building my company a new system, and I wanted to purchase a NIC to push higher rates (when we eventually replace the switch).
Initially I was planning on purchasing a Mellanox ConnectX-6, but the ConnectX-6 uses QSFP56 ports which I was told would not work with QSFP+ ports.
However, after some digging online I found that QSFP28 might be backwards compatible with QSFP+ (obviously capped at the upper rate of switch).
I plan on purchasing the following NIC : Mellanox ConnectX-5 Ex - MCX516A-CDAT
…as it uses QSFP28 ports, supports 100 Gbps, plus supports Windows 11 Pro for Workstations (the target OS for my company’s new system).
Does anyone know if it’s possible to connect the Mellanox NIC to my current switch and both pass and receive traffic to the switch?
Unfortunately, my company won’t be able to upgrade the switch for 1 to 2 years, and I’m stuck using the current switch.
However, I wasn’t able to find any NIC’s which worked with non-Server version of Windows operating at rates higher than 10 Gbps (as I tried NIC’s from Intel’s XL710 lineup (which a manufacturer confirms does not work with non-Server versions of Windows) as well as older Mellanox cards (ConnectX-3) with QSFP+ ports (which also does not support non-Server versions of Windows)).
Thank you,
Nelson
