I just noticed when I turned on the more explicit DoH settings in Firefox, that if you use OpenDNS in your router or network settings on your machine, it seems OpenDNS is now blocking DoH requests.
Is this just me? Which DNS other than Google or Cloudflare should I switch to if OpenDNS has started to block DoH and arbitrarily start blocking sites for “(enterprise) security risks”?
Hi @FurryJackman i belive there is a way to accomplish you goal by subsetuing Open DNS with Piehole and Unbound. I would search the forum for @PhaseLockedLoop networking guies or network how to.
Pi-Hole is in my plans for running a server with a VM container containing Pi-hole. For now I need one that supports the regular DNS ports at the same time as the other secure DNS protocols.
That’s pretty simple as to why. Most people consider Mozilla telemetry and DNS being automatic a big privacy and consent concern
In fact Mozilla even explains to everyone how to do it as DoH is a network consent concern and a good and reasonable one at that
Basically opendns much like my own dns server I run replies with NXDOMAIN to A and AAAA queries of use-application-dns.net to disable Firefox’s automatic DNS-over-HTTP?
You may find the recommendation here
For now it may be more recommended to use a different DNS server that advertises DoH
Also if its being blocked in mozilla you can override that too
Use trusted recursive resolver mode three… Enter a URL… Find the about config entry regarding bootstrapping the URL to the IP (often static) tied to the DoH URL you want and you will not need a DNS lookup to use that service
This is all well known, proven and quite well documented at this point if you do run into issues. Good luck
As for the suggestion about pihole.
I wouldnt do it anymore but thats because my use case has massively out grown it and I find the pihole project to be unsuitable for a real dns server. However I have an alternative for those okay digging into software and getting it working
There are numerous good reasons not to run pihole. Yeah I know its popular. I really dont care that it is. When the developers are unkind to anything but their vision of how to use something… thats not in the spirit of open source
Well, it’s the Elon Musk philosophy which a lot of people disagree with. Not happy with the language used there as I am on the ASD spectrum, but there’s some weird things about some of the stuff I looked on AlternativeTo to point out:
A commenter on OpenNIC felt like it’s a police administered bait program or honeypot… but that’s exactly what you want to say to smear someone’s efforts when you don’t want them to succeed. Russia is an excellent example of this. Regardless, OpenNIC lacks proper maintenance and consistency.
I prefer to run a local instance once I get my always on VMs situation sorted, but need an interm solution that can support regular DNS and secure DNS and DoH and DoT at the same time.
I was pretty pissed off. Will edit when I have time at some point that or it will get buried and wont be much of a in anyones face issue anymore
Wait. He said this about OpenDNS? Im confused.
You dont necessarily need a VM for this? Though if you are insistent have you considered virtualized kubernetes? So you ha e highly available VMs? As in run a kube node in each vm and then deploy services? It would be more robust. That said you dont need any of this for a very basic DNS server that you intend to run. Why put it on a pi or spare machine just to figure it out for now. Give you something to do
They dont. They just dislike him politically
If you watch what every fort 500 company did after elon did that and after they had to have their little public bash of him… they secretly did very similar if not the exact same things. the very corporations, people and influencers that disagree with him. Its kind of funny. More funny in the immature sense because the reality of what musk does is how lean businesses operate. It upsets people because they desire the concept of the mother company.
Yeah opennic is good but it just never picked up steam too much. Its pretty easy to own an entire TLD there if you can run infrastructure but realize due to custom tlds they make being inaccessible by IANA and ICANN traditional root server lookups… The only advantage it offers is a bit of obscurity
Truth is your always logged. The only way is to run a recursive server yourself… No logs. But everything it does will get logged along its path sooo… Not sure why he thinks its a police honey pot
Definitely will look into a VM environment for a LAN DNS server once I have my home server up and running. See my other responses in the 8700G thread for my questions on that.
If you want to explore the highly available vm route through the means of lube running on then (prox mox is great for this)… Technotim and lawrence systems have done great work regarding that. But youll have to dig for their content. They make a lot of it
You can have that control with any dns server. Pihole just made it pretty
And if you dont run your own unbound as you saw in my thread I wrote… Your basically giving up control anyways because if cloudflare or any intermediate wanted to… They could change the response and dnssec fails are not hard fails haha
