temps are like 39c at idle and like 78c during a aida64 stress test. are these temps ok? also im not hitting my boost speeds, getting like 3.89ghz under a load. using a corsair h100i pro cpu cooler
Normal temps
thanks
how about the boost speeds?
Sounds about normal maybe a little bit high on the upper end but also that’s because the new boost methodology is to boost as much as possible within thermal head room
im not getting the boost speeds i should, what do you think?
Then you are likely encountering what we are seeing on another thread I’m going to direct you to it you should refer to myself and mystery Angels conversation.
You might be having issues with voltages. if you are it can lead to higher temps and there are significant issues with the firmware UEFI of the motherboards right now
im using a b450 tomahawk with the latest bios.
What boost speeds are you expecting? There is a big difference between single core and all core boost, and Ryzen cpu’s do not hold the max boost, but jump up to it for a fraction of a second at a time.
ok cool
