Hi, i'm going to buy a custom built gaming PC from an online site called DinoPC: www.dinopc.com.
They are based in the UK and that is where they ship to. Also (surprise, surprise) that's where I live aswell! What I need to know is whether it's worth spending £30 / $50 more on a motherboard which can cope with SLI/XFire? I thought that I would get 2xGTX 770's but It might just be best to get 1xGTX 780. What do you think is best?
BTW: the £30 / $50 more motherboard would run the cards at X16 X8. Im not sure if that's right but whatever! Thanks!
Always go for a single card over multi-gpu setups so the gtx780 is the wisest choice. Motherboard wise for haswell, any midrange board will do even the hd3 will be fine. As long as you get a quad core cpu you'll have happy gaming for a good while.
I do recommend (over the titan) the 780 just because of the sheer numbers it puts up as a single gpu core... That being said, the red team is doing pretty well for itself in terms of price:performance.
Thanks! So do you think that the GTX 780 will be able to run Multiple monitors off of itself. That was one reason for going with 2 graphics cards, so that I can run multi monitor setups, if you receive this reply, tell me what you think. Thnx again
